Sony mini hifi component system mhc ec99i stuck in protect mode
The system is stuck in protect mode i tried unplugging it and plugging it back in every time it keeps saying protect and will not change
4 Suggested Answers
  • 4234 Answers
SOURCE: MHC-RV5
The repair manual can be purchased from Sony. What is the specific problem. Perhaps a manual is not needed.
Dan
Posted on May 20, 2008
Luis2584
  • 7 Answers
SOURCE: protect push power
you have wires touching. did you drop anything in your radio? water, medal's?? etc..
Posted on Dec 19, 2008
  • 4234 Answers
SOURCE: How can I get the cd changer to stop changing non stop?
Something is out of timing. When powered up, the unit trys to get to a known state and will continue until it reaches that state. If the timing of the gears has been changed, this may not occur.
I'll try to see if I can create a set of instructions to re-time this.
Dan
Posted on Mar 11, 2009
Hello can u help me about my MHC-gzx55d sony hifi component, when you turn on the power, the screen display appear "PROTECT" what is the problem and what is the possible damage of my component. please help...
When it goes into protect mode it has been over loaded. Remove everything from the component and unplug the unit for a minute or two. plug it back in and see if it pops out of protect mode. If this does not work then you will need to do a factory reset or check the fuses on the inside of the unit.
Feb 20, 2015 | Sony Audio Players & Recorders
Tip
My sony 3 disc ex-change/mini hifi component system mhc-rg66 it keeps flashing...
First things first. The unit doesn't switch on.
- Is it plugged in?
- Is the fuse blown?
- Does it look like it's suffered damage?
It switches on, but won't play anything / the lights come on, but no sound.
- We'll start at connections. Is your MP3 player/ iPod/ CD player/ record deck plugged in correctly?
- Are the speakers plugged in correctly/ at all?
- Is it in protection mode - this is a pretty standard thing now, where the amplifier tries to deliver more than it's rated current (ie, into a short circuit), and it cuts out. The only way to fix this is to take it to a local hifi shop, who will reset it (there's usually a small fee involved). The unit will be fine after that.
------- There is no bass. ----------
A few causes for this, so there's a few solutions.
- The speakers are out of phase. This is where one speaker is wired normally, one is wired in reverse. The bass from each speaker is "opposite" and would cancel out. To solve this, Make sure the + on the speaker is connected to the + on the amplifier. There's usually a stripe on the cable to help you determine this.
Cause # 2
The eq settings on your ipod/ unit have been messed with.
Set all the equiliser settings to flat, then readjust them to taste.
Cause # 3 (nasty one)
You've blown a woofer. The explanation is this - the speakers have taken in too much power, the bass unit has got too hot and the glue holding the coil in place has melted. Usually, the woofer can't be physically pushed when this happens. To solve this, it's new speaker time. An alternative is to see if you can get a recone kit for said speaker, and try to fix the voicecoil yourself. This isn't recommended to those who are new to the idea.
I hope this helps the reader.
Chris
on Sep 27, 2010 | Sony LBT-ZX6 Shelf System
Mini hifi sony MHC-GZR5D the disk port is not opening and USB not responding.. A message saying (please wait) always shown on the screen , what I must do?
Try unpluging the power then wait thirty seconds then plug it back in. I have a feeling there is a disk stuck in it.
Terry
Mar 29, 2014 | Sony MHC-GZR5D MINI HI-FI SYSTEM FOR...
I've sony mini hifi MHC-GZR88D. flicker
cold reset your hi fi system, by powering on your system then while holding stop button press disc 3 and power at the same time.
Feb 10, 2010 | Sony Electronics - Others
How to connect MHC-RG222 speakers to my pc
If you have an output function at the back of your mini HIFI then surely you can.What you need is a Dual RCA [from the mini HIFI] to 3.5 mm Stereo Jack [to the PC]. The cable is easily available in the market...go to this site n you'll get the idea http://www.vpi.us/cable-audio.html
Jun 17, 2009 | Sony MHC-RG222 CD Shelf System
Stuck in protect mode
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
May 04, 2009 | Sony STR-D1015
Protection on error message
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Apr 21, 2009 | Samsung HT-TX72 Theater System
It says push power protector on my new sony surround system i cant do anything with it
Bad speaker wiring.
Internal fault.
Regards.
Apr 17, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
232 people viewed this question
 Grubhead
Grubhead
