Question about Bosch 23 in. SHU33A Built-In Dishwasher
Bosch SHU33a won't drain
One day we smelled the typical odour of burning electrical insulation from a motor winding. The dishwasher had been on for a long time, but had not drained. Further investigation revealed some orange seeds, of perhaps unpopped popcorn, jammed in the very bottom outlet. They had not been caught by the filters. I removed these, and tested the system - it still did not pump out the water at the end of the cycle. The solenoid was popping in and out; and I checked this by moving the float sensor. However, it did not kick in the pump out motor. I suspect that the motor is damaged, but not so badly so that a house fuse was blown. I think that the motor may need to be replaced, but there may be something else I can do.?
  • sbailey15 Jan 25, 2009
    I have the same problem only I checked for obstructions ond could find none,I can smell the electricle burning smell also, it seems to go through the cycles but does not drain. help
  • 20 Answers
Try pouring in enough water to cover the screen in the bottom of the dishwasher, maybe a 2 quarts or so, then run the drain cycle. This should prime the pump and at least tell you wether the drain pump is working or not. Just a trick i've heard and worked for me, not my area of expertise however.
Posted on Mar 31, 2009
Electrical burnt smell
If you had a short in the starter motor windings and held the key, you'd get a click and a burning smell. That would be the insulation burning off the electrical windings. There's a 40-amp max fuse in this circuit.
Jul 21, 2017 | 1995 Chevrolet K1500
My Sunbeam mixmaster junior model-jc is smelling when it runs
the smell will be burning insulation on the windings of the motor probably from the brushes being too short and arcing on the armature thereby overheating the motor. suggest you take it to an appliance repair shop for quote on repairs.
Jun 17, 2013 | Sunbeam 2346 Heritage MixMaster Series...
Hobart .5hp kd-18 electric dishwasher motor has a flash from the bottom of the motor when starting. Had motor "meggered" and the tech says it runs fine. Sometimes has very hot insulation smell....
flash is motor start switch it arcs while dis-engauging start windingsis normal. just make sure winding do not appear to look blackish
Jun 10, 2011 | Dishwashers
How do I remove odors from this dryer?
Probably build up of dust and lint inside cabinet. You need to unplug dryer, remove back panel and vacuum out lint. If excessive lint found, would indicate insufficient cleaning of lint filter or restricted outflow vent or hose. If odour is electrical smell or burning plastic check all electrical connections and insulators for signs of browning or overheating. Strong pungent smell could be motor winding overloading or burning out. Will need electrician.
Apr 02, 2011 | Dryers
My dishwasher smells of burning and it tripped the electric
There are couple of things it could be...the most likely is that the motor has gone bad...they will smoke first and then trip the breaker...if you get under the dishwasher you will be able to follow your nose right to the motor is that is the problem...
The other possibility would be that the heating element went bad and melted something before it shorted and tripped the breaker...that to your should be able to see rather easily in the bottom of your dishwasher...
At either rate you should be able to smell the problem or see the burn marks...
heatman101
Sep 15, 2010 | Dishwashers
Heater in 2001 kia spectra stoped working
The burning smell is most likely an issue with the blower motor. These small motors have a hard life and the windings can lose the insulation and short out, hence the burning smell. Another problem can arise if the air intake has filled with leaves and other matter which can be ignited by the fan speed resistor creating the smoke. As this matter rots down, it creates chemicals which can erode the insulation on the motor and cause burning and the eventual failure of the motor. The fan speed resistor is a bank of wirewound or solid state resistors wired across the fan motor which give the individual fan speeds. If these fail then you would lose the fan as well. Search out the fan housing as the resistor is usually fitted into this housing to keep it cool. NEVER turn the fan on if this resistor is out of the housing as it WILL get hot and It can cause a nasty burn..the resistor can have upto 7 wires plugged into it but as to it's exact location, that you will have to find on your own..
Dec 29, 2009 | 2002 Kia Spectra
The unit smells like electrical insulation burning when run
motor cover seal could be defective letting water enter motor
Sep 11, 2009 | Dishwashers
Motor starts then slows and then stops. No indicator fault
few possibilities,capacitor could be burnt out,microfarads are printed on side of can,it will smell bad if it has failed,but can also fail without any ,odour,hope this helps
Apr 25, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Strange odour from dishwasher.
There was a recall of this model for fire hazard - the recall is still in effect
Dec 17, 2008 | Asko 1375 Dishwasher
Bosch 23 in. SHU33A Built-In Dishwasher Logo
299 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
