Question about Fluke Networks Fluke 179 Electricians Digital Multimeter Kit, Voltage Tester
My fluke 179 has stopped beeping - Fluke Networks Fluke 179 Electricians Digital Multimeter Kit, Voltage Tester
    Master:
  • 683 Answers
Needs new buzzer disc, or maybe buzzer disc fell out of its place and just repositioning it fixes the problem.
You can always order one from Fluke - Part Number: 2041050
Posted on Dec 03, 2014
5 Suggested Answers
VtToolMan
  • 704 Answers
SOURCE: WHEN I TURN ON MY FLUKE 179 IT READS ERROR AND
Hi, that is the error message indicating a EEPROM error and unfortunatlely, you can't do anything except have the meter serviced by either Fluke directly, or by an authorized Fluke test equipment dealer.
Since Fluke doesn't provide the specs and coding for their products, you wouldn't be able to repair the meter properly, even if you could burn and program your own chipset.
Here's a copy of the manual for your meter, so you can contact Fluke for servicing and see the other info relating to it (for your future reference)
http://assets.fluke.com/manuals/175_____umeng0100.pdf
Sorry to be the bearer of bad news, but Fluke products are typically quality test instruments and there might be a possibility that you're still covered under their warranty, so checking with them is the best avenue for getting it back to working condition.
I hope you find this Very Helpful and best regards!
Posted on Nov 10, 2009
  • 8404 Answers
SOURCE: I looking for fluke 179 service manual
Go take a look here please: http://www.fluke.com/fluke/usen/support/default.htm I found your manual here: http://www.fluke.com/Fluke/usen/support/manuals/default.htme: but you may not be able to go to this directly. Click on the Manuals tab then search your model number.
I trust this is what you are looking for.
Thanks for your interest in FixYa.com
Posted on Feb 14, 2011
  • 683 Answers
SOURCE: fluke 179 has ---- on the display when ohms or
Switch is the problem here, see if you can clean contacts or check if switch contacts are broken.
Posted on Sep 01, 2011
  • 683 Answers
SOURCE: My Fluke 179 has stopped beeping (mode
Fluke 179 multimeter showing wrong reading in AC, DC voltage, rest every thing working ok
input protection circuit is blown , see if you can find fusible resistor and check for open circuit (should be 1kOhm) - big resistor on the right straight from the Volts input
Mar 15, 2013 | Fluke Networks Fluke 179 Electricians...
No beep on continuity mod
Needs new buzzer disc, or maybe buzzer disc fell out of its place and just repositioning it fixes the problem - this is the likely cause of your problem.Contact local Fluke authorised service centre or Fluke directly if you are in US and ask them for Audio Transducer (Part Number: 2041050). it should not be more than couple of dollars.
Mar 18, 2012 | Fluke Networks Fluke 179 Electricians...
Fluke Buzzer disk -> Can you tell me where can I buy it?
Good on you on fixing Fluke DMM. Contact local Fluke authorised service centre or Fluke directly if you are in US and ask them for Audio Transducer (Part Number: 2041050). it should not be more than couple of dollars. Good luck with you Fluke DMM.
Nov 14, 2011 | Measuring Tools & Sensors
Fluke 179. Fusibles OK. No mide mA.Posible causa.
you can check other components in mA circuit on the board -or return to Fluke for service and repair
Feb 19, 2011 | Fluke Networks FLUKE 179/1AC-II KIT...
My fluke 179 shows batt in any function and it does not go out, with battery even new
send it back to Fluke for service if you are certain that battery is good and connector is not damaged (check Voltage on 2 pins that come to the board)
Feb 09, 2011 | Fluke Networks Fluke 179 Electricians...
Fluke 179 has ---- on the display when ohms or amps selected, but is ok on volts ranges. any ideas?
Nov 30, 2010 | Fluke Networks Fluke 179 Electricians...
My Fluke 179 has stopped beeping (mode switch/continuity/range alert) Any way to fix this?
Nov 07, 2010 | Fluke Networks Fluke 179 Electricians...
IT NO LONGER BEEPS WITH CONTINUITY OR CHANGING ANY
I have the older model but this may have the beep turned off......
Feb 09, 2010 | Fluke Networks Fluke 179 Electricians...
Fluke Networks Fluke 179 Electricians Digital Multimeter Kit, Voltage Tester Logo
209 people viewed this question
Top Fluke Networks Measuring Tools & Sensors Experts
Vuk B
Trevor Turner
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Fluke Networks Measuring Tool and Sensor Expert? Answer questions, earn points and help others
