Question about Compaq Armada E500 Notebook
HDD trouble It will not reconize the HDD, or it complains about cable select. Ok I am a novice when it comes to laptop repair... I recived this laptop from a friend and it had this same problem then. It turns on and trys to boot the HDD, but it cant. The screen goes fuzzy, and then warps then returns to normal. it says that is cant read the disk. I took the HDD out of it and it seems that there is nothing wrong with it. So i changed the jummpers and then it complaned about cable select. I have no idea what that is... I have a toshiba satilite from 95, yes it is old but I knew that the HDD worked.... So I tryed putting it in the compaq, and it did not even turn on... I have no money so I cant go buy a new HDD, or even a used one. Oh and the HDD caddy is in good condition, its not warped or bent or anything. Thank you in advaced, Kevin Lewis
    Genius:
  • 2,985 Answers
Look at the HDD there should be a lable showing the jumpers, But as a general suggestion the drive needs to be set a master. and once more as general advice looking at the back of the drive with the multi connector to your left the small sets of 3 pins with a jumper in one of the sets- master is the left hand set like this ... | ...
Posted on May 22, 2007
Asus repair manual laptop computer
Remove RAM and hdd. Power up and wait for it to complain then power off, refit RAM and fit a new hdd. Install your OS and restore your backups to it.
Never forget a password!
Sep 17, 2016 | ASUS Eee Computers & Internet
So the gateway laptop i have e475m it won't turn on or no lights when plugged in. The battery will charge when the laptop is plugged in.what the issue and how to fix it
Try removing power supply and main battery. Remove HDD and RAM. Plug in power supply and press ON. It should complain that there is no hardware. If it does, replace one RAM stick at a time and repeat powering up. If now OK replace the HDD. If nothing, the motherboard has issues, possibly GPU.
May 27, 2016 | Gateway Computers & Internet
Dell latitude d630 automatically shutting down after 5 secconds
Hardware issues? Try removing the hdd and ram, reconnect power. If in dos mode complaining that it has no hardware, check ram and hdd. If it still does it, I suspect a GPU issue.
Apr 01, 2016 | Dell Latitude D630 Laptop Computer PC...
Hp 6735s disk sanitizer
No OS stated, XP? VISTA,
'ok its HP but old but not too old, 2008\
in the magic year of 2006 HP added the F11 key to the old Compaq line. (hp bought)
so if the PC is still 100% HP and the hard drive not slammed with alien MS disks, from MS. then the recover partition works
so power on F11 hammer f11 fast, and bingo F11 recovery runs. pick fix startup files repair
fails still then reload the whole OS now back to DAY1.
all HP do this 2006 to now.
all do unless is bad or was bad long ago HDD bad, HDD SLAMMED.
my guess you ran DBAN, and why not fess up and say the full name of the product, (app) or there web site you got it URL
then we know what you did,.
DBAN erases it all the HDD is just empty space
and F11 is gone gone for ever more.
then you can do this.
see the 6 ways here, #1 is now erased leaving 5
#2 is gone at HP this old.
4 left.
#3 is your best bet.
http://www.pcdied.com/HP-OS-GET.html
Nov 18, 2017 | HP Compaq 6735s Notebook
M2N32-SLI Deluxe Motherboard: don`t reconize sata hdd...
The SATA port on the motherboard or the SATA cable or the HDD itself could be bad.
May 03, 2010 | Computers & Internet
Maxtor DiamondMax Plus 9 80GB 6Y080L YAR41BW0 Hard Drive ATA/133 HDD Internal HD not reconizing in any computer .think it is not getting any power to HD so the PCB Board i think might be gone.any help be...
Power comes from the power supply. Check yellow and black and red and black. You need both 5v and 12v. Are you sure you have the jumper set correctly for the application? Master or single - master with slave present or some computers require CS (cable select)
Dec 05, 2009 | Maxtor Hard Drive
80 gig maxtor not reconized in computer bios cmos
check the cable & more better way use duel usb cable which occupy 2 usb & i Normal Hdd connector
Dec 05, 2009 | Maxtor Personal Storage 3100 (M01B080) 80...
My gateway MT6821 is down, I'm trying to restore but when I try a repair it says on problem signature 06 "NoHardDrive". What does that mean? I can't reinstall windows because there isn't a drive to install...
ok what that is saying is the hard drive is not being reconized by the bios. you will need to go into the bios by hitting either F1 or F2 or delete . turn off computer as soon as you see it coming on hit one of the keys i mentioned. it should say entering setup.
in setup you will need to load the default settings..
look at the botom or left hand upper corner. sometimes it will be across the top. look for load default settings . select load default settings save and exit. if this fails you may need to replace the harddrive also known as ( HARD disk or HDD.
Nov 14, 2009 | Gateway MT6821 Notebook
Konica Minolta bizhub C352 error code C-D010
enter service mode, select state confirmation, select memory/hdd adj, select hdd format, select physical format, press start button, when displays ok turn off main power for 10 seconds, c-d010 will display again, repeat instructions and do logical format, turn main power off for 10 seconds..should be ok
si
Nov 21, 2008 | Konica Minolta bizhub C250 All-In-One...
About a thomson dth 8555x probleme
my thompson dvd decoder player doesn't play any disk...
it complain disc error
please help me out...
Feb 05, 2008 | Thomson DTH7500U DVD Player / HDD Recorder
Compaq Armada E500 Notebook Logo
35 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
