Question about Microsoft Works Suite 2005 for PC
Works suite 2005 will not start.
'suite cannot find files needed to run.  Files may have been moved,, deleted or renamed.  Try reinstalling...'.  I've been using works for years now all of a sudden this.  I reinstalled twice and still it won't start.
  • 91 Answers
Http://support.microsoft.com/default...b;en-us;247602 this is worth looking at.
a faster fix is:
Uninstall Microsoft works, then go under my computer and search for any other microsoft works folder from before the crash including any other program that came with it ( i.e. microsoft money ect..).
Those old files are interferring with the new files, so deleting them forces works to create new files.
Posted on Jan 05, 2009
Works word processor stopped working
Is it a TRIAL version? After the Trial has expired, 30,60,90 days. It doesn't work until you buy it.
Jan 06, 2013 | MSI Wind Top AE2010 AIO All-IN-ONE Desktop...
Tip
MAKE YOUR S60 DEVICE FASTER AND RECOVER RAM In the next few posts i will...
In the next few posts i will post some tricks to make your phone faster and also recover precious RAM.
1. MOVE HELP FILES TO MEMORY CARD
If you are running low on phone memory and have a lot of apps installed, you can recover a part of it by transferring help files to the memory card.
Enable CAPS OFF
open Xplore or fxplorer and move C/resource/help to E/resource/help.
All the apps will find it automatically in the E drive.
This trick will increase your phone memory thereby making your phone a little bit faster.
2. DISABLE LIFEBLOG PERMANENTLY
first use jbak taskman to kill lifeblogobserver process
make sure x-plorer is set to show hidden files
then go to c/data/lifeblog/database
now delete the lifeblog.dbfile
reboot phone
now use jbak taskman to kill lifeblogobserverprocess once again!
select llifeblog.db file and press 6 tick hidden and read-only reboot phone. You'll notice the phone's boot up is faster and it will also release some RAM.
if you want to use lifeblog again go toc/data/lifeblog/database
and untick hidden and read-only
3. STOP AUTO STARTUP OF APPS ( for a faster boot up)
You can disable the third party applications to boot at start . These applications boot at startup and slow down the phone,s startup. In order to stop them to boot them use the following process.
The info of all the start up apps is stored in c:\private\100059c9\start.dat
whenever you allow any application to start automatically at startup the file start.dat is updated. The simplest method to disable the apps to load at boot up is to simply rename the start.dat file i renamed it to start.dat.txt. After renaming it your phone will boot as it boots after a fresh formating.
When ever you again want to enable the startup apps just remove the .txt extension.
You can also edit start.dat file to enable some applications to boot at start up and disabiling others but i don,t know how to edit .dat file. But you can edit it if you know how to edit it.
The easiest method of editing the .dat file is to delete the old start.dat file and then go to the applications which you want to boot at start up and rechange their setting ie (enable auto start=yes). A new .dat file will be created automatically which will only boot those apps which you want.
You can even further boost up your phone start up by renaming files like
C:\private\100012a5\DBS_101F99FB_NSmlDSSettings.db
C:\private\100012a5\DBS_101F99FB_nsmlagentlog.db
C:\private\100012a5\DBS_101F99FB_NSmlDMsettings.db
C:\private\100012a5\DBS_101F99FE_NSml_Adapterlog.d b
C:\private\100012a5\DBS_101F99FE\NSml_adapterlog?? ?.dat
C:\private\101F99FD\nsmladapterlog???.dat
C:\private\101f9a06\nsmldmtree.db
C:\private\100056cf\clockapp.dat
C:\private\100059a8\nitz.dat
C:\private\100012a5\DBS_101F9A02_nsmldmfotaadapter .db
C:\private\100012A5\101f8683_ScShortcutEngine.db
C:\private\1000850\logo*.*
C:\private\100012a5\DBS_10205030_accpolicydb.db
C:\private\1000c959\localdata\commondata.D???
C:\private\1000c959\localdata\localdata.D???
To .txt files or simply delete them.
Deleting all these files is the other name of restoring your phone to factory setting without losing any application data. Deleting these files also deletes sim data mean the network data of all the sims used in a phone. When you will rename all these files your all phone setting will be lost like clock time ,month date year. When you will again set different settings like adjust the ,adjust the date duplicate files of all the files you renamed or deleted will be created mean fresh data files .to again gainyour original setting as they were before applying the hack just delete all the duplicate files and rename all the above files as they were before renaming and restart your phone all your setting will be restored.
on May 09, 2010 | Cell Phones
I am tryign to uninstall fix it, get error 5006
Installation or uninstallation of an application or game fails and gives the following error code:
This issue is due to a previous installation not finishing properly
Solution 1. Rename the Installshield folder
Make sure you've enabled Show hidden files and folders.
Find and rename the Installshield folder:
Windows 32-bit: C:\Program Files\Common Files\Installshield
Windows 64-bit: C:\Program Files (x86)\Common Files\Installshield
If there is an Installshield file in the Common Files folder, rename that one also (e.g. to Installshield_OLD).
Solution 2. Remove all traces of previous uninstall
If renaming the Installshield folder had no effect, find and delete any traces of uninstalled applications.
Applications that can assist you are: Revo Uninstaller, Windows Installer Cleanup Utility , CCleaner.
Alternatively, do a manual clean-up:
Close all running programs. Then clear the Temp folder (found via input of %temp% in Start > Search or Start > Run).
Use the Windows registry editor to delete registry entries related to the program.
Restart the computer.
hope this helps
Sep 10, 2012 | Microsoft Windows Vista Home Basic Edition...
I want to run Autocad 2010. Whenever i Starts it's execution it says "FATAL ERROR" acdb resource files not found. What to do about it.
The best bet is to try to uninstall and reinstall the program if that doesn't work we will go from there.
Mar 01, 2011 | Computers & Internet
I need to delete protected files from my pc running xp
Those files are protected for good reason, they are usually protected operating system files. Delete those and your PC will stop booting. If you KNOW the files are not essential then you can unprotect them using an unlocker. Windows washer has a file delete on reboot option, as well as malwarebytes and advanced windows care. They can delete the files as the system reloads.
Mar 09, 2010 | Compaq Presario 5000 PC Desktop
Itunes wont open and says cant find needed file?
hi
This usually happens when you have either renamed the file, moved the file somwhere else, or deleted it all together. Sometimes you may forget editing the filename or moving it to a subfolder.
Whenever you do this be sure to go to itunes and either add the file again and delete the old one from the database or "Get Info" and update the current file. tho u ve not mentioned any specific name of the file i m tryin to give u an example..suppose u are cant locate the music file m sure the files are where they are supposed to be then they must have been renamed. You can verify this - Find a track with an exclamation mark next to it
Open your iTunes Music Library.xml file with Notepad (the iTunes Music Library.xml file is usually in C:\Documents and Settings\YOURNAME\My Documents\My Music\iTunes).
Search for the track name
A dozen or so lines below the track name will be the full path to the file and the filename.
Compare this to where you know the file to be. If it is different then that would show that something/someone has moved/renamed the file. hope u will b sorted out wth ur problem... all the best regards.
Jul 15, 2009 | Apple iTunes
Microsoft word 2000 is not responding
Use the Search Option, selecting all files (search hidden as well), to locate the file named Normal.dot. Once found delete or rename the file Normal.OLD. This is the template that Word uses for all documents. It not uncommon for this file to become corrupted and cause problems.
After finding this file in your computer, rename it to something else like Normal.Old or delete it completely and then retry opening word. Word should automatically recreate the Normal.dot template for you. If it works properly after renaming the template file, you can delete the old one since a new one will have already been created.
Normal.dot may be hidden so you may have to go into your Window Explorer options and change them to show hidden files and folders before doing your search
To enable viewing of hidden folders:
MY COMPUTER --> TOOLS --> FOLDER OPTIONS --> VIEW --> SHOW HIDDEN FILES AND FOLDERS)
Hope this information has been helpful.
Apr 30, 2009 | Microsoft Office Professional 2007 Full...
Control Center2 will not start - Error cc025
Had the same problem. The solution was: - uninstall the brother software with the application in the brother folder restart PC - reinstall mfl-pro Suite restart pc - install update to Controlcenter2 - install updated drivers
It then worked and I could finally scan over the network, for the first time ever!
Jan 14, 2009 | Brother MultiFunction Center MFC-440CN...
Cannot install or play Petz 5!!!
Delete or rename Program FIles\Common Files\Installshield I did that and it works.
Dec 12, 2008 | Ubi Soft Catz 5 (Windows) (680901) for PC
I can not install OfficeSuite. I have Windows Vista home Premium. I had downloaded updates all afternoon and it still shows error 1719 Window installer not correctly installed. Help!
Download:Windows Vista Service Pack 1
I tried personally in WIN-XP worked same applies to Vista.
Error Message:
Error 1719. The Windows Installer Service could not be accessed. You may be running in safe mode or Windows Installer may not be correctly installed. Translation:
This message might appear when you’re trying to add or remove a program that installs via a Windows Installer MSI (Microsoft Software Installation) package file. The Windows Installer Service is the standard method for installing and uninstalling software on Windows XP. It keeps track of all of the components that need to be installed for a particular program to run and ensures that any files that are shared by programs are not removed when one of those programs is uninstalled. The Error 1719 is an indication that some Windows Installer Service files are missing or have become damaged. Solution:
The first thing to try is re-registering Windows Installer in the Windows registry. Make sure that no other programs are running and then click Start, Run, type msiexec /unregister in the Open field, and click OK. Next, click Start, Run, type misexec /regserver in the Open field, and click OK. Restart your computer and try installing or uninstalling again.
If you’re still getting the error message, the next step is to try reinstalling the Windows Installer files. In order to do this, you’ll first need to rename the existing files.
First, click Start, Run, and type msiexec /unregister in the Open field, and click OK.
In My Computer, click Search and locate the following three files: msi.dll, msiexec.exe, and msihnd.dll. They are hidden files so you’ll need to select Search Hidden Files And Folders under More Advanced Options. When you’ve found the files, rename them, by removing the .dll and .exe extensions and replacing them with an .old extension(for example msi.dll becomes msi.old).
Once you’ve renamed the files, WinXP will automatically replace them with a new copy from the dllcache (a hidden folder where copies of important system files are kept in case you mistakenly delete or rename critical system files). Restart your computer and try to install or uninstall the program again.
Finally, if neither of the above processes corrects the problem, boot into Safe Mode, and go through the above steps again, first re-registering and then reinstalling.
or
Go through the following links:
http://www.vistax64.com/vista-general/45784-windows-vista-error-1719-help-3.html
Hope this will be helpfull
Please rate me...
Thanks & Regards.
Nandu
Sep 02, 2008 | Computers & Internet
Microsoft Works Suite 2005 for PC Logo
108 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
