Toshiba projector 2000 lumens Use for church services two hours on Sundays. One hour on Wednesdays It started a few weeks ago changing colors from white to a deep lavender. On Wednesday, it started up with a white vertical stripe on the right side
  • 22 Answers
Your lamp is going out. You can buy a replacement lamp for about $300. Just do a search for the specific model + lamp & buy one. It is very easy to replace. Make sure you reset the lamp timer on the menu after replacement.
Posted on Jan 09, 2009
Is the an- xr20lp and an-xr10lp the same lamp or does one have more hours than the other, what is the difference?
the xr20lp is 275W, 2300 lumens
the xr10lp is 220W, 2000 lumens
see spec at
http://www.sharp-world.com/products/data_projector/xr20xs/spec.html
They seem to be compatible as some sellers are selling the 275W version for the XR10X.
Jan 26, 2011 | Sharp AN-XR10LP Projector Lamp for XR-10X,...
Optoma EP719 settings?Colorwheel? Bulb?? Cable?
take the lamp out and shake the projector gently and tilt it in all directions and listen for something loose near the front of the projector. if you hear something it could be the light tunnel has collasped or the colowheel has lost its segments.
May 21, 2010 | Optoma EP719 XGA DLP PROJECTOR 2000L...
The device is an InFocus LP 290 with less than 100 hours on the bulb. I have used the projector several times over the course of two years without any problem, but never longer than 3 hours at a time. A...
there is an issue with the power supply edge connection with the main board. you'll need to have it sent to an infocus service center for repair. try av solutions in ny. they're pretty good. www.avsolutionsny.com
Nov 24, 2009 | InFocus LP290 1100 Lumen XGA LCD Projector...
I do not have remote. Church inherited projector.
Hello
Thank you for using
FixYa for your problem
  1. you need to enter factory Menu.
    You do so by doing the following:
    1).Start the projector.
    2).Press keypad <Source> and <Auto> keys simultaneously, enter " Lamp Hour info" layer
    3). Press <Source> and <Auto> keys simultaneously again, then enter factor menu.
    Do not change anything till you reach Lamp Layer where lamp hour and usage hour is given. If you reset, then all data revert to default - factory reset. you may chage here or under (2).
    Let me know if this solves your problem.
  2. - Press exit for 3 seconds
    - The Menu to reset the Hours rises up
    - Folow the manual on your screen
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 19, 2009 | NEC VT460 Multimedia Projector
I have a TV sony KP-fx432 sometimes it works normal but the other times it doesnt and the led blinks 10 times there is sound but no picture. please HELP! :[
We had a similar problem with the same model a few weeks ago. With the help of a service manual, we just replaced IC8002(MCZ3001DB) on the D-board to solve the problem. The 10 blinks indicates an HV protection has occurred.I do hope this helps.
Jul 23, 2009 | Sony 2000 LUMENS SVGA 500 TV LINES...
Bulb not firing
yes. the lamps are good for 1500-2000 hours. with the projector on, go into the menu and find out how many lamp hours have accumulated.
Jun 24, 2009 | InFocus LP70+ Multimedia Projector
We have a Toshiba multimedia projector. Model #TDP-S8. Use app. 3 hours weekly for church services. Three weeks ago, started with changing color. White looked lavendar/gray, etc. Now it consistently has a...
it needs a good service .all that needs to be done is open the top cover, the main board , clean all the dust possible.there is a glass dlp , clean it with a soft cloth ( like the one used to clean specks).on refiiting the main board make sure to firmly press the 100 pin black connector on the dlp board engine.this is the cause of the vertical flashy line
once repacked start the unit.it should work fine!!!!
Jan 10, 2009 | Office Equipment & Supplies
Projector stopped working
Hi amp422
This wouldn't be a lamp issue at all if there is no power at all on the unit.
Take of the top cover and change the fuse located on the Powersupply Board ( the one where the AC socket goes into)
Should do the trick.
Thanks for using Fixya !
Apr 29, 2008 | InFocus LP530V Video Projector 2000 ANSI...
Projector Lamp
Hi there
Does your Projector go in for regular services ?
Have a technician check out the fans of this unit as well.
I would suggest you hook up a UPS to this Projector , because eventhough you might not have power dips or failures - the power supplied to appliances is not spike free and Projectors struggle to handle this well.
Apr 01, 2008 | Toshiba TDP-TW90U Multimedia Projector
169 people viewed this question
jasbo
jasbo
