Question about Singer 2662
Skipping stitches, needle hitting, can't zig zag
I have a Singer CG-500/550. I bought it because I have a small sewing business. I sew thick fabrics, a thin foam lining, and a few layers of canvas. My sewing machine started to skip stitches, and knot up when I reversed. The zig zag would only sew on one side, so it was a straight stitch. I changed the needle, I had a heavy duty needle, and I put a regular needle in. That didn't make a difference. I noticed the thick thread I use shredded as I sewed. I put the other needle back and it was the same thing. I oiled the machine, but that didn't help. When I sewed, ever once in a while, the needle would hit some part of the machine. When I manually made the machine sew, by twisting the circle on the side, I could hear the needle grazing against a gear that spun around. I realized that's why the thread was shredding. Any advice? Is there a simple adjustment or is my machine defective? The soonest I get an answer would be great, since I have 3 orders waiting on me. Thanks. Rachel
SOURCE: Kenmore 1560 Sewing Machine
Be sure TOP control shows zig-zag. Flip top right bar from red to black or black to red on side of machine facing you. You can then change the widths by changing the numbers on that same circle control.
Posted on Jul 17, 2008
RickE1
  • 202 Answers
SOURCE: Zig Zag Not working on my Bernina 830.
Basically it is a matter of a stuck part. Flip open the top by prying up on the front or ends of the lid. You already noticed the hinges on the back. When you get it open, exercise the right hand lever on top (marked ZZ at bottom and 1-20 at top. If you look just to the right of this lever against the back wall you will see that it moves a little part back and forth into triangle shaped grooves. The part is not going completely into the grooves so drop some oil in there and exercise it a few more times, using your fingers if necessary to make the part move into the triangle grooves at the front and back. After a while it will loosen up where it should operate by itself smoothly . Hope this helps.
Posted on Dec 12, 2008
  • 980 Answers
SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions drivewithken@blueyonder.co.uk
Posted on May 14, 2009
SOURCE: Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
Posted on May 24, 2009
  • 8 Answers
SOURCE: Singer Athena 2000 won't zig zag
Try pushing the reset button underneath the machine. Mine does that too. I had it repaired a few months ago...apparently it needs a circuit board that is no longer available.
Posted on Aug 01, 2009
When i use the zig zag stich, sometimes the stich falls and does not zig zag
try a new needle--one for the fabric being sewed
could be a problem with the cam that does the zig zag, you might need to have the machine checked
if your sewing with light weight fabric also try using stablizer
Mar 18, 2016 | Singer 5532 32-Stitch Heavy Duty Sewing...
Need to now where to put tentions to sew sweat pants.
use a couple of pieces of waste material the same as the sweat pants material and sew about an inch long
adjust the needle tension and do it again
repeat the exercise until the top and bottom thread joint at the middle of the two pieces of the material
tension settings on the machine are a loose guide as the thread thickness, material thickness and needle size all have a bearing in the tensions of the thread
so practice and adjust prior to sewing is the way to go
Nov 07, 2015 | Sewing Machines
Zig-zag settings
you probably shouldn't be using a zig zag for that application. But the multi-stitch zig zag.
Please look at page 40 of your manual for information.
As for needle breaking check to make sure your need is the correct one for the thread and fabric. Also make sure your pressure foot is the one recommended for the stitch. Consider this... most thicker fabrics require a longer stitch.
Aug 21, 2012 | Singer Confidence 7463 Computerized Sewing...
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Sewing Machines
My singer does'nt do dverlockWhat can I do ?
No sewing machine does a true overlock stitch, that is what sergers are for, they trim and form a stitch on the edge of the fabric using 1 or 2 needles and two loopers. Costs more for an additional machine but the finish is much more like a shop bought item.
tally_girl_14.jpgi
Some sewing machines have an overcasting or interlock stitch which looks like stitch 10 in this picture above. Your machine may have this stitch?
If not, does it have a three step zig zag? It looks like a zig zag but the needle goes into the fabric three times as it forms each leg of the zig zag. This stitch is great for neatening a raw edge and I use this a lot myself. Especially on wovens as it is always faster to seam with this rather than the overcasting stitch where the feed dogs move the fabric forwards, then backwards, then forward to make the stitch.
The sewing machine made overcasting stitch can be used to sew knit fabrics, attach rib around an neck line and neaten raw edges but it is always going to take longer than a serger and there is no trimming function so its never going to look like a shop made overlocked item. However, you can sew knit fabrics with a sewing macine with a bit of patience as long as the machine has some "Forwards/backwards" type stitches as these put elasticity into the seams - if you seam knit with a straight stitch, seams can break when under tension during wear.
And use a twin stretch needle and straight sttich to sew the hems, this looks a bit like a cover stitch and has a bit of give in it too.
Hope this helps you a little. You can find some good sewing general info on www.sewing.about.com or invest in a good sewing book. I refer to my Vogue Sewing Manual and my Singer Sewing Secrets often. Or take a sewing class, its a great way to learn new things, get enthused and have fun.
Apr 08, 2011 | Singer 3116 Simple
May 01, 2009 | Singer 5050 Mechanical Sewing Machine
The zag part of zig zag won't work
i believe your machine is skipping the stitch on the RIGHT side as you sew and this is normally a timing problem. Lower your needle about 1/16 inch and try it . It might work to finish your project but it will need to be serviced to have the timing corrected.
sewman7
Jul 28, 2008 | Necchi 3101 Mechanical Sewing Machine
Singer 2662 Logo
145 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
