Question about Kyocera FS-1016 Printer
Kyocera FS1116 engine panic - Kyocera FS-1016 Printer
2 Suggested Answers
aviral_srms
  • 1216 Answers
SOURCE: kyocera fs 1016 engine panic
Disassemble and look the fan side of the fuser, there you will see that the wires pass through a **** that is more of a cover remove it and there's the can on that side is where will the current regulator and the high card that connects to the source card,
Well it happened to me this issue, I found the card and it was high toner developing unit that was discarding, in addition to the seal of the doctor blade was worn out, another issue I found was current leakage, what I did was make the can land top with more pressure to the high card, in addition to not fall toner worn by the seal tape to tape the holes in the chassis, after that I have not been flawed
Posted on Jul 14, 2011
Kyocera taskalfa 1800 call service c7900
Kyocera-Mita TASKalfa 1800 Error Code: 7900DescriptionDrum EEPROM error
No response is issued from the device in reading/writing for 5 ms or more and this problem is repeated five times successively.
CausesDR PWB. Main/Engine PWB.
http://printcopy.info/?l=en&mod=erc&brand=Kyocera-Mita&model=TASKalfa 1800&code=7900
Aug 08, 2016 | Kyocera Office Equipment & Supplies
My jeep wrangler won't start, I think it has to do with panic button malfunction
disconnect the batterie for an hour and see if it resets itself
Mar 23, 2013 | 2008 Jeep Wrangler
My Kyocera FS-1116 MFP says 'printer error'/'engine panic'.
If you get the Engine Panic error message, you need to turn the power switch off and then back on again. If that doesn't fix the error, contact a service representative to help resolve the problem.
Oct 17, 2011 | Kyocera FS-1016 Printer
I HAVE A KYOCERA ECOSYS FS-4000 DN PRINTER. WHEN I TURN IT ON, I GET AN ERROR MESSAGE STATING "CALL SERVICE 0150:0003704". WHAT DOES THIS MEAN AND HOW DO I FIX THE PROBLEM?
The error indicates -
Engine PWB EEPROM error Detecting engine PWB EEPROM communication error.
Causes - Improper installation engine PWB EEPROM. Check the engine PWB EEPROM installation,
- Defective engine PWB. Replace the engine PWB
IF turning the printer off and unplugging then plugging back in and turning back on doesn't correct the problem I would suggest you contact an authorized Kyocera service center such as www.gfbm.net.
Jan 24, 2011 | Kyocera FS-4000DN Laser Printer
I have a kyocera FS-2000D with error code: Call for SErvice 0150:0000049. Help...thanks in advance
0150 is a problem with either the engine board or the EEPROM chip that sits on the engine board. If you want to do it yourself, you can open the printer up and reset the chip on the board as well as reset all of the connectors that plug into the board. Otherwise, your best bet is to call a Kyocera service technician.
Mar 17, 2010 | Kyocera FS-2000D Laser Printer
KYOCERA KM2020 erreur C-4000
cause
Defective harness between drum motor and engine PWB (YC11), or
improper connector insertion.
solution
Reinsert the connector. Also check for continuity within the connector harness. If none,remedy or replace the harness.
cause
Defective drum motor drive transmission system.
solution
Check if the gears rotate smoothly. If not,grease the bushings and gears. Check for broken gears and replace if any.
cause
Defective drum motor.
solution
Replace the drum motor.
cause
Defective engine
PWB.
solution
Oct 26, 2009 | Kyocera Mita KYOCERA/MITA - FS-4000DN Mono...
My Kyocera fs-3900dn has the message: call service 0150:0040557. What does it mean?
0150 - Engine PWB EEPROM error. Detecting engine PWB EEPROM communication error.
Solutions:
1. Switch the printer OFF; unplug the power cable; wait 20 seconds; plug in the power cable; switch the power ON, If the error comes back follow the next solutions:
2. Update / Burn the latest firmware version. You may need to call a Kyocera Service Provider because you need a CF card (compact flash memory card) and the FIRMWARE.
3. Replace the Engine PWB (a board) - again you have to call a Kyocera Service Provider.
Dec 30, 2008 | Kyocera FS-3900DN Laser Printer
Kyocera FS-1016 Printer Logo
64 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
