Question about Sanyo DS20425 20" TV
Xbox 360 stretched screen out and cannot fix it now
I have a sanyo 24 flat and one day my kids were playing xbox 360 and when they were done i went back to watch regular tv and these odd numbers appeared at the bottom left hand corner of my screen. When I tried to make them go away the screen zoomed in and now my tv is stuck all zoomed in and the picture looks tall and stretched out. Please what can I do I emailed sanyo and that was of no help to me all t they said was to just read the manual and well theres nothing in there on that subject.
  • joaquin lomelin May 22, 2007
    well I called customer service and they said to unplug the tv and as I plug it back in while I hold the menu button down and a menu which allows u to make the vertical and diagonal adjustments will appear
Have you checked the aspect ratio?? May be that when the kids had the X-Box hooked up they simply changed the aspect to zoom.
Posted on May 22, 2007
How do I hook up Xbox 360 to this TV? I have no clue where all the plugs go in the back
component leads from xbox to component in on tv
Xbox 360 Component HD AV Cable
http://support.xbox.com/en-AU/xbox-360/system/connect-xbox-360-console-tv
https://www.youtube.com/watch?v=JlE2zHSoQmE
Nov 20, 2015 | Sanyo DS31590 31" TV
How do you get your xbox 360 to play, on a 65'' mitubishi projection tv,its connected but nothing comes on screen when i put a movie in just a blank screen and no sound,if i'm on a channel,the channel...
Hello
The Xbox 360 connects to a TV using either
- COMPONENT (red blue green for video, red and white for audio
- COMPOSITE (yellow for video, red and white for audio)
- HDMI
So, if your TV is on a "Channel", it is not on the correct input to view the Xbox 360.
Check the Xbox and verify which cables it is using to connect to the TV. When you find this, follow the cable to the back of the TV and find the input selection. It should be listed as the type and a number (i.e. HDMI 2, COMPONENT 1).
Have the Xbox on. Use the TV remote and use either the INPUT or the MENU options to change the input to the input that matches the port that the Xbox is connected to.
This should make the Xbox work.
When you are done with the Xbox, use the INPUT or MENU to change back to the tuner to watch TV.
Nov 03, 2013 | Mitsubishi WD-73734 73" Television
How would the easyest way to hook up xbox live for my kid .
First, take out the XBOX 360 and place it so it's sitting horizontal. Do not set it down as it appears in the photo above. A lot of people who do this don't realize that they are covering the air vents, giving your console much less battery life. (In other words you might turn it on one day and see the awful Red Ring of Death.)
Once you do that, take out the cables. The best image you can get is going to be with an HDMI cable. That looks like this:
http://www.inadvance.ca/inadvance/catalog/images/5.hdmi%20cable.jpg
Then take out the power cable. It's the cable that's attached to a big gray box. Plug that into the back of the 360, then plug the other end of it into a surge protector. Do not plug it into a wall because if you have a power surge, you may end of frying a component inside your 360.
Once you have done that, put two AA batteries into the controller. (There should be a clip on the back of the controller that comes right off. The batteries go in there.) Make sure you put them in the right way as labeled on the controller or it won't work.
Once you've done this, turn on the 360, then turn on the TV. Change your TV to the appropriate HDMI Channel and watch how well your kid learns in just a short amount of time. :)
Hope this helps.
Feb 22, 2011 | Microsoft Xbox 360 Elite Console - Black
Screen goes fuzzy when i play games but dvds work.
It's a problem with the GPU. You should contact Microsoft for support.
Nov 21, 2009 | Microsoft Xbox 360 Console
Tv screen keep going black,
did you check the sleep mode on the tv?
Aug 05, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Xbox 360 static lines no picture, but sounds,
Log in to your XBox live account and sign up to return your box for service. Even if it is out of warranty Microsoft has been fixing them for free including covering shipping. Our box just went through, took 11 days total.
Jun 21, 2009 | Microsoft Xbox 360 Console
Cant play my xbox 360 on my 22 inch Insignia tv
Is the TV an High Definition TV?
If it's not an HDMI compatible tv them you will need a regular audio video cable for your XBOX 360
you cn get them all day on ebay or at any store.
May 25, 2009 | Insignia 22 in. Widescreen Flat-Panel LCD...
Xbox 360 no picture but sound, works on another HDTV
did you check to see if the av conponent was on tv/hdtv?
Nov 15, 2008 | Microsoft Xbox 360 Console
Light and dark
hi there, you have a hardware prob. , try the inverter of the lcd, replace it and test it. ty
Feb 16, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Sanyo DS24205 24" TV input problems
I'm sure you know you need the original remote if there is no menu on the front of the set. I suggest doing a search for customer support online for Sanyo products. There you will find contact numbers to see if one is available. Try "Sanyo remotes" on Google or Yahoo etc. Hope this helps
Dec 30, 2007 | Sanyo DS24205 24" TV
Sanyo DS20425 20" TV Logo
722 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
