Question about Goodman Heating & Cooling
Goodman model # fhk030
Fan dont stop running even when the unit is off
    Genius:
  • Goodman Master
  • 1,363 Answers
Fan relay stuck in.
Posted on Aug 14, 2015
jumptrout51
  • 3361 Answers
SOURCE: 2 to goodman ac unit model a24-08
Replace the fan relay switch in the airhandler(inside unit).
Posted on May 20, 2009
FunnyPlumber
  • 43 Answers
SOURCE: fan won't turn on outside unit but has a hum noise
Be sure you have power, 220VAC to unit. You may have blown fises or tripped circuit breaker.
Posted on Jun 23, 2009
  • 340 Answers
SOURCE: I have a Goodman air conditioner. My outside unit
If you are sure of the power then ya have a control problem thermostat set correctly? could be open low pressure switch I would call for service. Tom
Posted on Jul 03, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: Outside unit not operating. Outdoor Unit fan (fan
the fan motor is burt. replace it. it will still spin if you manually engage but it will overheat an may even cause fire, also that waste tremendous amount of electricity now.cap is not defective,
Posted on Jul 04, 2009
james3751
  • 614 Answers
SOURCE: Goodman Manufacturing model CK42-1C won't start.
You ahve a bad breaker or bad capacitor. Check voltage across the terminals at the bottom of the contactor or the wires coming in frm the breaker. If you ahve 220 volts across these terminal then check across top terminals if you have 220 volts on top you have a bad capacitor. Replace it. Russ
Posted on Aug 18, 2009
On a cpkj 48-1B Goodman heat pump I am having condenser fan issues. runs full spedd for a while then cuts down to barely running, Even after changing the motor and capacitor.
Does the condenser utilise head pressure control to maintain head pressure? if so is the unit fully charged...r22. r410 Freon.If the unit is an older model. the fan motor only runs at 850 r.p.m design flaw. The newer units now run the fan at 1075. R.p.m. I have installed many Goodman split systems and was having problems similar to yours. Hope this. Helps you
Jul 11, 2015 | Goodman Heating & Cooling
Goodman furnace a36-20 fan runs non stop
is green wire from thermostat or from outdoor. retrace and change as needed. If not Goodman has a tech support number you can call while looking at unit.
Jun 21, 2014 | Goodman Heating & Cooling
My central want come on inside or out dont even buss
Check all the circuit breakers first. Next, move the fan switch at the thermostat from auto to run. If the unit has power the fan should run. If it doesn't then start by checking the 24vac transformer. Let me know what you find.
Jul 18, 2010 | Goodman CLQ36AR49 Air Conditioner
Fan motor will not run.
Make sure the fan turns freely by hand. It is possible it is overheating and turning off.
May 02, 2010 | Goodman CLJ36AR42 Air Conditioner
I have an goodman model gsc130241ae unit will not
Hello Does the thermostat have a display?Check emergency wall switch and curcit breaker all on.Fan on should at least run if power.
Mar 31, 2010 | Goodman CLQ36AR49 Air Conditioner
May 19, 2009 | Goodman Heating & Cooling
I have a Goodman furnace GMPO75, blower cycles on and off with t-stat in the off position.
disconnect the green wire at unit if stops then stat bad if continues look for fan relay or thermal disk calling for fan to come on let me know if this dont repair it and i will pull up the wiring on that unit
May 06, 2009 | Goodman GMS90703BXA Heater
Gas Package Unit Keeps Running with all T- stat wires unpluged at the unit?
does that unit run heating or just the fan run? if just the fan you may have a bad fan thermostat
Oct 21, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
