Question about Kitchen Ranges
Kenmore gas range 790.7230 makes poof/woof sound when oven ignites
james klgr
  • 362 Answers
SOURCE: Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
Posted on Dec 08, 2007
SOURCE: clock,timer and oven does not work on Kenmore gas Range
I was turning the timer and clock knobs on my oven and now it won't work. I don't know what position they are supposed to be in ... any ideas?
Posted on Mar 11, 2008
docjohn174
  • 943 Answers
SOURCE: oven makes poofing sound when in use
hi. thanks for the question .Yes the igniter is at fault here. replace it. thanks the appliance doc
Posted on Oct 02, 2008
duby1990
  • 367 Answers
SOURCE: Older Tappan range oven not lighting.
There is no way to light the oven manually. The gas valve will not open until the oven ignitor draws enough current. But replacing the ignitor will fix ya up.
Posted on Nov 19, 2008
  • 13 Answers
SOURCE: gas oven makes a fluttering sound when pre-heating and cooking
This is most often due to the ignitor bar aging. With time it draws less current and does not hold the regulator valve open all the way. You can confirm that the regulator is OK if the broiler works. Replacement for nearly all of these ovens is a universal part, about $35 at appliance parts stores, takes 5-15 minutes to change (depending on whether you need to pull the oven out to get to the connector).
Posted on Nov 30, 2008
Turn on gas oven; it lights, big poof/pop comes; then continues to light and heat properly. How do I stop it from popping? The pop is scary!! GE Spectra Gas Stove/Oven
The reason it "POOFS" is because the igniter is slightly weak and some gas enters before it gets lit,this will continue and get worse. To resolve it the igniter would need to be replaced and then as soon as the gas enters it would light it right away without collecting before it lit.
GENE
Oct 10, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Hello, I have a GE profile range JGBP86WEB5WW. The oven is taking an unusually long time to heat up. There is a strange sound coming from the oven also. It sounds like a burner is trying to fire but...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 25, 2010 | GE Profile Spectra JGBP86 Gas Kitchen...
Sears Kenmore Gas oven lights and relights
sounds like dirty nozzle,or not enough air to make combustion, the poof sound is when it builds up with extra gas after flame quits,and re-lights there is a bit of excess gas around igniter.
clean nozzle.altho there is lots of safety percautions built in to stove,MAKE SURE LOTS OF FRESH AIR, AND STOVE AND GAS OFF,when cleaning nozzle.
[could be air intake problem to]
Dec 19, 2009 | Kitchen Ranges
Maytag gas oven slow to ignite,makes poof sound
sounds like the safety valve gas regulator (its where the main gas line attaches in the bottom back)
Mar 25, 2009 | Maytag CWG3100A Gas Single Oven
Problem with oven ignition unit
It works...But I called to have the oven checked out. Thanks, tnf
Feb 19, 2009 | Kenmore Kitchen Ranges
Gas oven makes a fluttering sound when pre-heating and cooking
Nov 30, 2008 | Kitchen Ranges
Oven makes poofing sound when in use
Oct 02, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven makes a poof noise when turning it on.
HI thanks for your question. the poof you hear is the gas sorta igniting because of a failing bake igniter. i would replace it thanks if you need help don't hesitate. thanks.
Aug 08, 2008 | GE Profile JGSP48 Gas Kitchen Range
Kitchen Ranges Logo
117 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
