Question about Sewing Machines
Needles keep break in huskylock 435 overloocker
4 Suggested Answers
kent581
  • 87 Answers
SOURCE: timing on a Huskylock 535D surger
the eyes of the needles must line up with lower looper as they pass (timing) the distance between the needle and the looper must be exact. No distance between them and not touching. yep, that tight. they shouldnt move the needle even the slightest amount as they pass each other, yet no space between them.
Kent
Posted on Mar 19, 2009
  • 9 Answers
SOURCE: Babylock seger machine keep breaking the left side needle.
Try rethreading the machine, and make sure the thread is not wrapped around anything. Then check the tension for the needles. Run a few inches of chainstich off slowly, while watching the thread and loopers make the loops over the finger. Your threads may be in the wrong position, or underneath the wrong parts to start.
Posted on Jun 12, 2009
  • 152 Answers
SOURCE: Need power cord forHuskylock 435 serger and
That serger was made for Viking by the Brother company. Just about any sewing machine repair shop should be able to get you a cord and pedal. Call Viking at: 1-800-474-6437 to see if you can get a photo copy of the manual.
Posted on Nov 02, 2009
Replace needle on a Huskylock 905
Look in your owner's manual for needle replacement procedure. You have to unscrew the small screw holding the needle.
Be careful that the new needle is properly seated before screwing it tight. Otherwise, you might end up with it slightly askew.
Apr 01, 2014 | Husqvarna Huskylock Computerized 905
Manual for Huskylock 910
are you wanting a instruction manual or service manual?
Aug 25, 2012 | Husqvarna Huskylock Computerized 910
Thread coming out of eye of right needle on huskylock 910
Hi:
Are you sure it's coming out? Or is it breaking at the needle?
Try replacing the right needle and do a test stitch. If it still comes out of the needle... loosen that threads tension a little.
Aug 01, 2012 | Husqvarna Huskylock Computerized 910
While quilting with clear polyester thread, the upper bar keeps dropping the thread or the thread breaks. What is the secret?
try these suggestions
the needle top thread tension is to tight
the needle is bent or blunt
the thread & needle are not compatable--here's how to check
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
you said the upper bar keeps dropping the thread--I think you are talking about the thread take up lever-an old sewing machine service tech I knew had a sewing machine that had that problem & he took a pair of pliers & closed the gap in the thread take up lever hole & the customer never had a problem with the thread coming off the thread take up lever again.
Oct 07, 2010 | Husqvarna Huskylock Computerized 936
Huskylock 936 error code
This will also occur if the "needles" and "loopers" lock up as though threads are tangled and binding the machine. If needles and loopers move freely when manually turning the handwheel counter clockwise, you probably need to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Nov 28, 2009 | Husqvarna Huskylock Computerized 936
Hi, I have a huskylock 905 NOT computerized and it's making a "clunking" noise while sewing and then the "D" thread breaks. I've re-threaded many times, changed thread, changed needles, adjusted tention...
Sounds like the D needle is hitting something in the loopers and an adjustment needs to be made. The adjustments are ever so slightly. It could be that the needle bar is twisted causing the D needle to hit. It could be the looper is not within the specs for proper operation, etc. Suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Nov 18, 2009 | Husqvarna Huskylock Computerized 905
Oct 28, 2009 | Husqvarna Viking 1
Timing on a Huskylock 535D surger
Kent
Feb 07, 2009 | Husqvarna Husky 165
Husqvarna 910 won't create a chain.
You may have knocked the machine out of time if the machine does not pick up stitches.
Jan 21, 2008 | Husqvarna Huskylock Computerized 910
Sewing Machines Logo
20 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
