Question about Samsung NV24 HD Digital Camera
NV24HD settings problem
Kevin I have the same problem with the Samsung NV24HD: I clumsily pushed the button on the camera while I was setting it up the first time and that was that: it now records a quite wrong time and date. I don't think there is a solution-- or at least I can't find one.
  • 26 Answers
Go to menu-setup/settings-date time
then change it
Posted on Jan 12, 2009
Camera reset samsung pl55
1. Push the power button.
2. double-tap the play-button at the bottom and the screen should activate. If so, push the menu-button. Go to settings and choose reset.
Jun 09, 2017 | Samsung Cameras
Why won't it start?
Here are a couple of things you can try:
Turn the lens clockwise then push the power button. As soon as you hear a click when you turn it push the power button and it should power up. Or
mendmy com How can fix my samsung camera help plz Cameras Film Cameras...
You may find this thread interesting, and helpful...
Oct 02, 2015 | Samsung ES90 Digital Camera
Lcd display does not work
On the back of your camera, to the left of the display, are three buttons. The top one is the display button. (a square between two standing lines) pressing that button will switch between image & full information, Image & basic information and LCD off. Try pushing that button several times, while the camera is on and see what happens. There is no such thing as reset to factory settings for users. Look on page 29 of the manual. It is still online with Samsung (Retrovo)
Nov 25, 2013 | Samsung Digimax 360 Digital Camera
What do you do if you've got a Samsung NV24hd camera and your new Windows 7 computer is not compatible? Samsung tech support says there's no Windows 7 driver...
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Nov 01, 2010 | Samsung NV24 HD Digital Camera
Simple instructions for Samsung NV24HD
You can download an "easy manual" or a full manual from this page.
Oct 31, 2010 | Cameras
My samsung nv24hd has had its lens stuck open, so I got it to closed carefully. Now whenever I try to turn on my camera, the lens will not open. The screen says samsung, and it freezes. I am able to see...
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Aug 14, 2010 | Cameras
NV24HD - recording videos. I´m using a 16 gb SDHC Adata Turbo Memory Card. I´m having problems recordings videos (1280 x 720, 30 fps). After recording, watching the video, the images goes on ok, but the...
hi all i know is that with samsungs if u try to zoom whilst using video mode the sound will cut out it is not a fault its just the way samsung made it 2 be. Hope it helps
Apr 05, 2009 | Samsung NV24 HD Digital Camera
SAMSUNG SSCDVR ALARM + REC STAY ON
Theres a setting in the menu that makes it do that. I think it might be the scheduled record times that you set in it. to get back to the menu ( the smaller button next to the large round multi button), push stop and when the record light goes out (real fast)!!! push the menu button, then you should be able to change the setting in the menu...
Nov 19, 2008 | Samsung SSC DVR Digital Video Recorder...
Setting the date and time
jfcampbell1; i believe very carefully!!! Just kidding. On the back of the camera, you should see a menu button or setting button. All this information will appear on the LCD screen and you just push on the circular wheel back and forth or up and down until you get to date & time settings. Pushing in on the middle button inside the wheel means OK or Enter. BTW: couldn't find anything on a Digimax A503, so I had to guess it was an A502. Alot of digital cameras are available for review on www.dpreview.com. Hope this helps.
Jul 22, 2008 | Samsung Digimax S730 Digital Camera
Samsung S730 problem.
Mine did that. I just took the batteries out and kept them out for a few minutes when I put them back in it stopped. I think I turned the settings around a few times after I took the batteries out.
Mar 03, 2008 | Samsung Digimax S730 Digital Camera
Samsung NV24 HD Digital Camera Logo
228 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
