Question about Epson WorkForce 545 - Multifunction fax / copier / - C11CB88201
Error code c70 faxing epson workforce 545
Can't recieve fax fax error c70
ljiohy
  • 31 Answers
SOURCE: Need to Fax from my Computer using an Epson Workforce 600
GET YOUR SOLUTION FROM EPSON
HERE IS YOUR SOLUTION
http://www.epson.com/printer/prob676ijt65/solution
a17
Posted on May 22, 2009
GetFaxing
  • 143 Answers
SOURCE: how to send a fax
Assuming you want to use WinFax with your scanner...
in Program Setup, go to Scanners option.
Select your scanner from the list.
You should have "Scan and File" and "Scan and Send" options in WinFax. If you don't, the scanner was not detected.
Troubleshooting WInFax at http://www.getfaxing.com
Posted on May 29, 2009
  • 42 Answers
SOURCE: Communication error Code # 0503 using Epson nx 300
hi,
i do not use this same model, but my colleague who uses this machine had a similar problem. we broke our head on it for 4 days, then turned off the error correction mode. it solved the issue for him. it could solve your problem too.
cheers
Posted on Jul 25, 2009
graysand
  • 558 Answers
SOURCE: I get error 0408 when i try to fax. Using epson
Communication error,try defaulting the machine ,check the line with a good telephone make sure you have dial tone.
Good luck
Posted on Sep 21, 2009
cns assoc
  • 677 Answers
SOURCE: epson fax hooked to magic jack communication error
I had same problem when I used the dual jack. I had to change it. I had the dual jack which would make it easier to use when I was going to send a fax.
Good Luck
Posted on Feb 12, 2010
0x05 epson error code
What us the result of the error? what are you doing to produce the error?
Sounds, offhand, like a driver failure of some kind (ADF??)
Jul 19, 2015 | Epson WorkForceR WF-3540 All-in-One...
How do I connect A Epson WorkForce 845 to NBN & Telephone
If your phone is provided by broadband then it is now a VoIP phone. In order to use your machine, you will need a fax gateway or a digital to analog converter. This will allow your fax machine with uses a analog line to connect to a digital VoIP line. You will need to connect your nbn provider.
Sep 05, 2014 | Epson WorkForce 845 Wireless All-in-One...
Epson 630 workforce won't fax to some numbers.
followed edger allans remedy and now faxes that where not answering before now are. i think mostly because i had it set to, 1 ring to answer and i changed to 6. thanks.
Feb 07, 2012 | Epson WorkForce 600 All-In-One InkJet...
I have an Epson Workforce 610. It used to send faxes just fine with only minimal errors. Now, I only get error 5303 for the last two months. I am using it wirelessly from my computer, and it prints...
Try this : Look for Setup on your printer and press OK button. Go to Fax Settings, press OK, then go to Communication and press OK. Turn off ECM and V.34. Try re-sending your faxes.
Dec 10, 2010 | Epson WorkForce 600 All-In-One InkJet...
My epson fax machine is hooked to magic jack and every time I try to send a fax, I get: communication error 0404
Can I fax using Magic Jack? This is a popular question. They do not support faxes, but the answer is yes. You may need to do some tweaking. However, not much tweaking. First, turn off error correction on your fax machine or program. Then, set the fax machine or program to use the slowest speed available. The slowest speed will ensure a fax goes through. You may increase later to find the highest speed at which a fax can be received.
Feb 09, 2010 | Epson WorkForce 600 All-In-One InkJet...
Epson fax hooked to magic jack communication error
Good Luck
Good luck
Sep 21, 2009 | Epson WorkForce 600 All-In-One InkJet...
Epson WorkForce 545 - Multifunction  fax / copier / - C11CB88201 Logo
127 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
