Question about Yamaha Music
Distorted intermittent volume Yamaha DX7
Recently, my DX7 volume dropped to near zero and is very distorted. Midi works ok so the keys are working. Battery was changed and voices reloaded. Everything else seems to be working. Any ideas?
2 Suggested Answers
  • 133 Answers
SOURCE: Turned on the Privia PX-575R and sound distorted,
You should probably check the bender controller and the master volume potentiometer, they might be dirty / oxydized, in such case, you need to either disassemble and clean them or replace them.
Also check for bad solder contacts on wires, connector pins and any of the components (e.g. voltage regulators, capacitors and/or other components).
Check all connectors for any dirt / oxydation on the pins and clean them if necessary.
Also check the main power switch (dirty contacts may result in erratic behaviour of the unit), and, if we're talking onboard speakers, see if the speaker protection mesh is somewhat loose, it may vibrate and cause the speakers to have dirty / distorted sound (you need to fix the mesh firmly in place to stop it from vibrating).
It could alse be a problem elsewhere in the unit (a bad resistor or capacitor, possibly some other component), these are just some of the things that may cause the unit to have dirty sound.
Hope you can make it sound well again.
regards
3rq8 (Triarcuate)
Posted on Aug 02, 2009
Why does my lowrey organ not make a sound after I have switched it on?
This is a generic answer for this kind of question.
When there is no sound
Check the obvious.
Is there a light on the organ indicating it is on?
  • Plug it in to a known working wall socket, switch on at the wall
  • Switch on at the organ, check light
  • Very old keyboards need a voice to be selected!!
  • Turn master volume up
  • Turn any other volumes up
  • i.e. lower manual volume
  • upper manual volume
  • swell pedals down
Sometimes a sustain pedal plugged into a volume pedal socket will mute the output, check this.
Headphones out, most headphones will turn speakers off, sometimes the headphone switch can be dodgy, work the headphone plug in an out a few times
There maybe a switch that turns off the speakers, look near the output sockets
Software volumes up, check display, if any.
MIDI instruments, check local control is ON
Still no sound?
Can you hear anything from the speakers?
Hiss or hum usually means the speaker is ok
Total silence may indicate speaker failure, but only if there is one speaker, as in older home organs, or smaller keyboards
Try headphones next, TURN Down master volume first just in case!
If there is some sound, very quiet and gross distortion then possible power amplifier failure.
If your instrument has any kind of line out as well as a headphone jack, try these.
The line output will likely be a pair of phono sockets,like you have on HiFi equipment, 1/4 inch, 6.35mm jacks, like the bigger headphone connector, a 3.5mm socket like the smaller headphone connector, or even a DIN connector on older equipment.
Connect these to the aux (or Line or CD) input on your HiFi, guitar amp or similar. (some times these outputs will drive headphones, usually you will only hear anything in the left side). If this works then it is very likely the power amplifier.
Further tests on MIDI equipped keyboards would be to see if the MIDI does anything.
If MIDI out works and there is no sound, and MIDI in makes a sound this points to local being off, buried somewhere in the menu will be local on or off, make sure it is on.
If MIDI out doesn't work then the failure is likely to be internal power supply or something else critical (not nnecessarily major).
Power amplifier failures in newer, low power, keyboards are often the power amplifier chips (i.c,s), older amplifiers may have just blown their fuses but one or more output transistors may have failed.
Cost of repair will be down to the time it takes to get to the fault, taking these to bits and putting them back can take a lot longer than the repair.!
Hope this helps, Chris the Fader
Aug 28, 2016 | Music
Marshall MB4410, with low volume gives no real volume,
Guitar amps have preamp sections (think unpowered audio mixer) and power amp sections (Crown rack-mount amp). An excellent way to isolate audio problems if amp is still producing audio is to check the preamp out (line out). Preamp output distorted = preamp failure. Connect MP3 player to "Power Amp In"...sound distorted = power amp failure. In your case the latter is the case as your "line out" is clean. Also test each speaker for clear sound as speaker cone damage from being overpowered is fairly common. At 300w. I'll assume the failure was not from cranking the volume to loud but a shorted speaker or speaker wiring could zap the power amp in an instant.
Jan 06, 2014 | Marshall MB4410 Bass Combo Amplifier
Keys stick on yamaha wx11
It must have been dropped. Look to see if one side is bent so as to pinch the key. Gently pry it until it moves. Add lubricant if needed
Nov 26, 2013 | Yamaha WX5 Midi Wind Controller
I Have a yamaha dx7 fd with 2 broken keys, they stay down can be lifted manually and make a sound . can I fix this myself
Open the unit CAREFULLY to avoid damaging cables between top and bottom. Inspect the defective keys. It may either be a broken part on the key OR the silicone rubber key contact carriers that can act as springs. Get repair parts from Yamaha America in California. Find number online and call the "parts department"
Sep 27, 2010 | Yamaha Music
How can i play BUP 06PK61 frm yamaha I425 on PC
how can i play .bup file in computer?
ok here is the solution!!!!!!!!
    • we should have a mic pin and audio cable as shown in this pic
    connect these cables,and connect big pin to the piano and small pin to the computer (mic or input jack)
    now take windows movie maker (start-all programs-windows movie maker). click on narrate timeline (as a mic icon below windows movie maker).
    now click start narration on the pc and play your song on the piano. you can see input level highlights. now your song is recording. when your song completes click stop narration and save to the pc. walah if you can't understand this say to me. i can add video. sry for my worst english
Jan 13, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
How do i make daw's program program change messages with a dx-21. or must i buy a keyboard controller.Im using Intel. Pen. 3 with 2.2 ghz win. xp v5.1.2600, e-mu dsp audio processor (wdm). software bundle...
ALWAYS to answer your question, refer to the "MIDI IMPLEMENTATION CHART" for your MIDI instrument.
This chart can be found USUALLY near the end of your user's manual.
This chart, among other things, will tell what can be transmitted and received by the MIDI device.
Refering to the chart for your DX21 it shows that the DX21 can both receive and transmit program changes.
If you don't have a user manual, download one here:
http://www.maths.abdn.ac.uk/~bensondj/dx7/manuals/dx21-man.pdf
Nov 09, 2009 | Yamaha Music
Alesis SR-16 distorted sounds
The distorted and low volume output plus noise is usually caused by using the wrong power supply adapter. The Alesis SR-16 takes a 9V "A/C" supply not "DC". The A/C supply provides a negative voltage swing which wouldn't exist with a DC supply. So check and make sure you have 9V A/C output supply not DC.
Nov 18, 2008 | Alesis Sr 16 Stereo Drum Machine
Music Logo
119 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
