Question about Samsung CLP 300 Laser Printer
Samsung color fading-light on lft side to dark on rt side
When I print (e.g. printing business cards, 10 to page in Publisher), the paper comes out faded on the left side and gradually increasing to full color on the right side. This is particularly noticeable in color printing (very bad) and somewhat noticeable in black. Printer is Samung CLP310.
I want to download the driver softwere of samsung clp-300 series vista ultimate supported
Posted on Jan 05, 2009
I have a Samsung CLP-620ND color printer, only 1085 copies printed. After changing the 3 colored toner cartridges, my print out came out bad. Left side of paper around 3
Dear
Open the individual carts from the printer and visually observe the density of toner on the developer roller evenly. Some times the cleaning blade of ITB over come the problem.
Before this try to adjust altitude and cleaning on EPM or smart panel from PC.
Thanks.
Mar 15, 2012 | Samsung CLP620ND Colour Laser Duplex...
My Business Cards
You need to set the print size to match the size of the card.
you either need to resize the document or change your print preferences to match the size of the card.
May 16, 2008 | Avanquest MyBusinessCards (824592)
My phaser 740 has print that flakes off when you print pictures with real dark areas. I assume it needs more fuser heat or less paper speed. The problem is I can' t figure out how to adjust either of these...
Recalibrate the colors. Flaking is sometimes caused by more ink/toner than can be fused to the media. There's a limit for the total amount of ink/toner. Yours may be set too high.
You'll need a copy of the Printer's User's Guide (also Downloadable from Xerox.com)
Controlling Color Density
When colors look faded, adjust the toner color density to extend the life of the components.
Print and use the Color Reference Page 1 In the printer's front panel, scroll to Calibrate Colors,
press Menu and print the Color Reference Page. 2 Compare the Color Reference Page to the Color Density
Samples on page 39. Make a note of the value (-10 to +10) for each color that most closely matches the samples.
3 Adjust the density for each color: Enter the value noted in Step 2 in the Calibrate Colors menu, under Adjust Each Color.
? Decrease color density: Press . ? Increase color density: Press --->.
4 Reprint the Color Reference Page; check your adjustments
Dec 09, 2010 | Tektronix Phaser 740P Laser Printer
While printing in black middle of page fades out both sides of the page print well. this is about a 1 inch fade out in middle of page.
Replace the drum of the particlular color cartridges. To know which color you have to print in single color one by one. If problem persist then replace transfer belt .
Jan 05, 2010 | Samsung CLP 300 Laser Printer
I am printing business cards and I am using thick paper but colors come out dull looking but if I change the paper to PLAIN then the colors come out just perfect, full, vivid and rich but I am afraid that...
Its most likely the paper you are printing on. It sounds like this is an ink printer. The way ink works is that it is absorbed into the paper you are printing on. Some paper pulls the ink too far into the paper causing it to look dull and faded. You need to make sure you are printing on paper that is designed for inkjet printers. There are a lot of companies that make special paper designed for printing your own business cards. I prefer Avery products since they have a guarantee.
Check this link out for some options on InkJet business card options.
http://www.avery.com/avery/en_us/Products/Cards/Business-Cards/_/Ns=Rank%7C1%7C%7CProduct%20Number%7C1
I hope this is solves your issue....Violet
Jan 23, 2009 | Office Equipment & Supplies
Black Lines running down the right side outside of the print area
It may be the fuser. Take it out and inspect the roller on it:
  1. Switch off the device, disconnect the mains plug and wait for 30 minutes before continuing.
  2. Ensure that the bypass tray is closed, or you will not be able to open the front cover.
  3. Open the front cover by pressing the release buttons as shown.
  4. Pull the front cover down towards you.
  5. Disconnect the green plug - squeeze the sides of the plug and pull.
  6. Push the left and right levers outward to unlock the unit.
  7. Pull the unit towards you as shown and lift it clear of the device.
  8. Check the roller for wear marks, If so replace it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 21, 2008 | Ricoh Aficio CL3500N Laser Printer
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Colors faded on left side of paper black and blue
Is it possible for you to clean the printheads manually with cotton buds and cleaning solution on this unit. Clean all thoroughly and this might just correct issue.
Sep 01, 2007 | HP Color LaserJet 3500 Printer
Samsung CLP 300 Laser Printer Logo
809 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
