Question about Epson Office Equipment & Supplies
How do I present a power point presentation on Epson ex3212 projector
I cannot access the power point presentation on the USB port despite that it is connected to the projector and I can see the file on the screen
tinamarie49
  • 34 Answers
SOURCE: image bigger than screen
Try changing the keystone. Also you may have the projector too far away from the screen. Changing the resolution on your laptop will not solve that particular problem.
Posted on Dec 05, 2007
  • 3 Answers
SOURCE: The projector has a blue screen
Check all your connections to the computer then shut down the computer and restart. Try putting the setting on the remote to Computer setting. Also make sure the video setting are all correct in display on your menu.
Posted on Dec 10, 2008
Master Rod
  • 7 Answers
SOURCE: Power Point Presentation Using Sanyo Pro Xtra X Multiverse Projector
Don't forget to select the Fn key and F4 on HP laptops. It could also be the Fn key and F8 depending on the laptop brand. It is the apple key and the F7 key on a Mac notebook. On Laptops this will toggle the video to the aux port where the monitor cable connects to the projector. There are 3 modes. video on the laptop screen, video on the laptop and projector, or video to the projector only.
Master Rod
Posted on May 08, 2009
  • 6 Answers
SOURCE: Powerpoint video won't play on screen
you can try changing your overlay settings. works with some formats. or you could use the projector as main display (toggle through fn+LCD/CRT)
Posted on Jul 29, 2009
  • 6 Answers
SOURCE: Problem running power point with embedded video file on projector
It may be your ppt files are corrupted. To repair the corrupted ppt files you can use powerpoint repair software. It makes use of the advanced algorithms to repair the corrupted ppt files. It provides very simple interface.
Posted on Feb 10, 2010
I've had this Optoma PK102 for about year and am not able to get desired results! What cable do I need to connect my Optoma PK102 and Apple ITouch. I have 2 Problems. Problem 1- I am unable to view...
Welcome to Fixya. You need to put the file on the projector for you to view the PPT presentation.
You need to connect a USB cable shown on the image below. If you don't have the cable i suggest you purchase on just bring the projector to a store to have a compatible usb cable.
Use the link below for the manual and more info about the product.
Manual
Specification
Thanks for using Fixya
Mar 13, 2011 | Optoma Office Equipment & Supplies
I cannot seem to link up my projector and laptop computer
Assuming that you have all the connections between the laptop and the projector already performed, you should check in you laptop's manual what is the key combination necessary to switch between normal mode and presentation mode.
For instance, some Dell laptops need you to press the function key (key marked with Fn in blue) and, while keeping it pressed, press also the F8 key (marked with CRT/LCD in blue) to cycle between the options.
Some HP laptops will need you to do the same operation, but now using the function key and the F4 key, to select between "Computer only", "Extended (dual) presentation mode" or "Projector only" modes.
If even with these indications you are still not able to make your laptop show its information through the projector, please send us more details on how you connected your laptop to the projector, as well as the brand and model of your laptop.
Hope this information can help you!
Mar 09, 2011 | Vivitek D825MS Projector
My dell d630 won't recognize the infocus lp70+ remote control and I can't advance my power point slides?
Here's what the User's Manual says:
Using the Remote Control
To advance PowerPoint slides with the projector's remote, you
must connect the USB cable on the projector's computer cable to
the computer. See page 8 for more information.
Point the remote control at the projection screen or at the front or
rear of the projector (not at the computer). The range for optimum
operation is about 30 feet. If you point the remote at the
projection screen, the distance to the screen and back to the projector
must be less than or equal to 30 feet. For best results, point
the remote directly at the projector.
If you are displaying presentations in Microsoft® PowerPoint®,
you can use the remote's Previous and Next buttons to navigate
through your presentation while in Slide Show mode.
Jan 26, 2011 | InFocus LP70+ Multimedia Projector
I need to be able to connect my hp pavillion to a projector to display a power point presentation. What is the correct process?
Usually all one has to do is power up the projector, then while the laptop is turned off, plug the projector into the VGA port, boot the laptop, and there it is.
If that doesn't happen for some reason, you'll have to go into display settings and make the projector the primary display.
Nov 29, 2010 | HP Pavilion dv6000z Notebook
How do I connect the laptop to the projector using Power Point.
Connect the data projector to the video port on the laptop. Then power up the data projector and then the laptop, the video data will automatically be diverted to the data projector.
If you want to see the Windows image on your laptop screen as well you need to press and hold down the FN key plus one of the function keys on you laptop which has a screen symbol. Pressing this key will toggle between the laptop screen, data projector or both laptop screen plus data projector.
You can open Power Point and select your presentation as you would normally.
Nov 14, 2010 | Computers & Internet
Hitachi cp-s240 remote question
Hitachi data projectors are able to function as a mouse using either the USB port or the control port located on the back of the projector.
However, they are not intended to be used as a remote presenter. This means that although you can use the remote as a mouse, you will not be able to change slides in a full screen slide show using powerpoint.
I recommend the Targus remote presenter for this purpose. This device will function as a mouse, pointing device, and will allow you to change slides in powerpoint. In addition, it's inexpensive, wireless, and small enough to easily fit in your pocket.
Mar 02, 2010 | Hitachi CP-S240 Multimedia Projector
Changing of slides during P.Point presentation
why not get a wireless mouse? you can get them for power point presentations ;-)
Oct 09, 2009 | 3M X75 Multimedia Projector
I am trying to run a presentation from 2 computers into the projector. one pc as the display and one as the presenter, is this possible
If the projector has two RGB inputs (they will be blue & look like female serial ports and be marked input1 & input2 or possibly RGB1 & RGB2) then both PC's can be connected, but only one image from one of the PC's can be displayed at a time. To change between them use the "input" button on the projector or remote control to switch between RGB1 & RGB2. If your projector has only one RGB connector at the back it is still possible to use the video input for the second PC but you will need a special adaptor for the RGB cable from one of your PC's.
Jul 10, 2009 | Epson EMP-S5 Projector
Feb 10, 2009 | Epson PowerLite 50c Multimedia Projector
Dell Latitude D630 Touchpad/Pointer
Do not check the check box as leaving the touchpad enabled while using an external mouse will not cause any harm.
Dec 11, 2008 | Computers & Internet
147 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
