Question about Bosch WFE 2021 Front Load All-in-One Washer / Dryer
Flickering display panel Boschwfe 2021
Cycle starts then display panel flicks on and off then completely dead. Periodically tries to start, flickers and stops again. Cycle not complete. Help please!
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 21 Answers
It may be the door interlock that is faulty. This is the cheaper solution however it maybe the the electonic board. In any case it needs the attention of a bosch Technician. Cross your fingers its the door interlock.
0417362396 Melbourne metro Area
Regards Sam
Posted on Sep 20, 2009
2 Suggested Answers
  • 1294 Answers
SOURCE: Bosch WFE 2021 machine does not complete wash...
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Posted on Jan 04, 2008
GE Washing Machine won't drain or complete cycle model # WBCH6240F0GG
The power line might flick. That's why not complete cycle.
Before do any repair, samply plug a alarm clock to the outlet that
the washer plug to. Leave there for a while about 1 day. If it blink that mean there a flicker on that line or may be some other line as well.
If power line is flickering. Fix the line (Do not fix the Washer!)
Mai Lor
Feb 25, 2013 | Washing Machines
My LG 500G 15 inch CRT monitor is flicking, I remove all the magnetic thing about 2 feet but it also flicking at 1024X768 (60htz). Please give the hardware repairing techneque to stop flicking from...
Please ensure if the flickering is not coming from the PC. In some cases a fault in the display drivers section of the main board will cause flickering.
If you meant the flicking to be related to lower frequency of the vertical or an interference from the mains line then try and see if there are errors in the SMPS of the monitor. If there is leak of the mains storage/tank capacitor , it is possible to see some flickering.
Select from the menu the vertical frequency and see if there is any change on alteration.
Feb 08, 2011 | Computers & Internet
Flickering Screen
please change the INVERTER card of the screen of your laptop
Jun 02, 2010 | Computers & Internet
Hanns-G HG216D is flickering to black screen
Started working after I d/l the driver
http://cms.hannsg.net/onweb.jsp?prod_no=3333333617&webno=33333333:0
Jul 31, 2009 | Computers & Internet
Lights started flickering battery light came on Dash lights and gages went crazy now wont start
Like you said, battery may be flat. You can check that with a multimeter.
Next check the alternator. Faulty alternator leads to uncharged battery.
May 29, 2009 | 1997 Dodge Caravan
I have pentium computer - D815EEA2 Motherboard P-III, 733 Mhz. CPU Now i purchase viewsonic VA1918WM Monitor and picture is flicking, and only one setting of resolution in 1024 by 768 pixels High (24 Bits)...
The reason you are getting the flickering is because the refresh rate is not set correctly. Click on Start>Control Panel>Display>Settings>Advanced>Monitor. In the middle of the window you will see the refresh rate. It should be set between 60-75. Try setting it between that range and try it a few times until the screen stops flickering.
Thanks for using FixYa. Don't forget to vote on this solution before you log out.
Jan 20, 2009 | Computers & Internet
Display Problem
Inverters On The way Out.
Try gently Pinching the screen at the top and bottom of where its Faulty ( On the Plastic casing ) Not the actual LCD.
Mike @ Compurepair.
Mar 07, 2008 | HP Pavilion zd8000 Notebook
Monitor flickring
  1. Flickering screen display
    Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software, but it can also be caused by interference from external devices. The following examples describe situations in which your screen could start flickering:
    • Screen starts flickering because of interference caused by devices which generate magnetic fields, for instance:
      • a TV set
      • a laser printer
      • another monitor
      • fluorescent lights
      • hidden power lines
    • Apart from interference, an incorrect setting in your system CMOS setup can also cause flickering. On some systems it is possible to distinguish between interlaced and non-interlaced monitors. The setup of your system should always be colour non-interlaced.
    • Proximity to the monitor of fans, air-conditioning units or other devices with rotating motors.
    • The number of devices using power from the same electrical line. Are you overloading the plug?
    • Monitor placed on an unstable surface.
    • Improper video drivers, this is a software problem, see section B
    • An improperly configured or a defective video card.
  2. Reinstalling the video drivers
    1. Start the computer.
    2. Click Start, select Settings, and click Control Panel.
    3. Double-click the System icon.
    4. Select the Device Manager tab in the System Properties window.
    5. Make sure that View devices by type is selected and locate Display adapters and Monitor in the list.
    6. Click the plus sign (+) in front of both items to get a list of installed devices.
    7. You need to remove every device by highlighting it and clicking the Remove button and OK when the warning message appears.
    8. After doing so for both items, they should disappear from the list.
    9. Close the Device Manager by clicking OK, and you will return to the Control Panel.
    10. Double-click the Add New Hardware icon.
    11. Click Next, select Yes when it asks "Do you want Windows to search for your new hardware?", and click Next twice to start searching for new hardware.
    12. This will take a few minutes and, after it is finished, you will have to restart the computer. Windows 95 or higher will automatically set up the correct monitor and video drivers.
    13. If the screen is still flickering, click Start, select Settings, and click Control Panel.
    14. Double-click the Display icon and select the Refresh tab.
    15. Change the Monitor Refresh Rates until the flickering disappears.
    16. If the flickering remains, go to step C.
  3. Troubleshooting
    1. If it is possible, connect a different monitor to the computer. If the flickering disappears, it is a fair indication that the monitor is defective, otherwise go to the next step.
    2. Set up the computer and the monitor on a different place in your house. If the flickering disappears now, it is most likely an interference caused by something in the original location. Check for devices which can cause interference.
    3. If the flickering persists, check the setup of your system. If available in the setup, make sure that the option Monitor Type is configured as Colour Non-Interlaced.
Dec 24, 2007 | E-Machines E17T 17" Flat Panel LCD Monitor
Sylvania 6842-PEM Flickering Problem
Something is breaking down. Possibly a specific ceramic capacitor on the main power pcb that has been troublesome. Usually there is just a loud pop and the screen goes dead. If the set is less than a year old it is still on parts warranty and the technician could just change circuit boards until the problem is gone.
Aug 30, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Flicker-Blinking on picture
Too late now but I hope you had it serviced while it was still on parts warranty. With a couple of exceptions, service on those is by major pcb replacement.
Jun 04, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Bosch WFE 2021 Front Load All-in-One Washer / Dryer Logo
145 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
