Question about HP DM366AV Network Adapter for NX9010
I have a compaq nx9010 and in the device manager there is a yellow ? next to Network adapter and a couple of other things. I have a wireless router and it worked for a different laptop, but I can't seem to get connected to the internet. It won't let me rollback drivers, update drivers or anything.
    Novelist:
  • 180 Answers
The yellow question mark indicates a problem of some type associated with that device. In your case, I'm going to make the wild assumption that you need to install the drivers for the device to work as it came from a different laptop. If you have the original CD that came with it, install from there. If not, go to the manufacturer's site and download from there (using a different pc that does connect to the web). Reboot if necessary and you should be good to go. I'm also assuming the device still is functional- verify that by putting it back into the laptop it originally came from.
Posted on Jan 06, 2009
Compaq presario v2000 wireless card not showing up in device manager
In Device Manager click the tiny arrow beside Network Adapters. This where the wireless card should be listed.
Next, locate the row of small icons just below the View tab at the top of Device Manager window.. Click the icon on the right "Scan for Hardware Changes".
Check again under Network Adapters to see if the wireless card is listed.
Or, check for any yellow exclamation marks in Device Manager list. An item might be named Unknown Device. Double-click it and select Update Driver.
Jul 01, 2014 | Compaq Presario 700 470024-192 Notebook
Hi i cant connect using wireless on my lenovo.
Welcome to fix ya
If you are having problems connecting wirelessly using your lenovo G550 here are steps that you could try
1. Press FN+F5 ( this turns the wireless adapter on/off)
2. Make sure that the wireless switch is toggled on. The wireless switch is located on the front of the laptop.
3. Make sure that the drivers for your wireless adapter is properly installed. To do this click on start then type device manager. click on device manager. click on the arrow next to network adapters. Make sure that the wireless adapter does not have a yellow exclamation point next to it. Also if you dont see your wireless adapter here check for a yellow question marrk in other device. If you dont have the driver you can download it here. www.consumersupport.lenovo.com
Apr 25, 2011 | Lenovo G550-29583AU Notebook
I'm having an issue with my DI-514 wireless router. I can connect fine when the router first boots up. My laptop will stay connected to the router all day. The problem happens when I disconnect from the...
Open Device Manager. In the Device Manager window, click the plus (+ ) sign next to Network adapters to expand the selection. Under Network adapters , click to select the appropriate wireless LAN adapter. On the menu bar, click Action and then click Properties . In the Properties window, click the Power Management tab. On the Power Management tab, click to uncheck the box next to Allow the computer to turn off this device to save power . Some WLAN adapters have another power saving setting in addition to the one on the Power Management tab. Click the Advanced tab and try to locate a power saving setting. If it exists, disabled it. Click the OK button.
Aug 06, 2010 | D-Link DI 514 Wireless Router (DI-514)
My nx9010 will not connect to my wireless router but my gateway will. I have had problems with the router in the past. The signal bars show a strong signal and the wireless light on the front of the laptop...
Most likely your internal wireless card has gone bad. Not to worry, though, they're rather inexpensive on ebay and Tigerdirect.com. A qualified technician may charge quite a bit to install it, though so for the time being there's the option of using a USB type adapter. Here's some examples: http://www.amazon.com/Medialink-Wireless-Adapter-Windows-Compatible/dp/B002RM08RE/ref=dp_cp_ob_e_title_0
http://www.walmart.com/ip/Belkin-F5D7050-Wireless-G-54Mbps-USB-Network-Adapter/3756936
Apr 25, 2010 | HP Compaq nx9010
Can't connect to wireless internet anymore device
Please install the latest wireless adapter card driver and then configure it to your wireless router.
Dec 26, 2009 | Compaq Network adapter
Compaq presario drops internet connection
Try this....
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
Oct 13, 2009 | Compaq Presario Notebook
I have a compaq presario 700 I turned on my computer an the wireless connection no longer works my light stays orange regardless where i move the switch when i asked for a diagnosis the computer tells me...
Windows WiFi Fix,
Windows XP:
Click Start
Click Disable
Windows Vista:
Click Start Logo
Click Disable
Oct 12, 2009 | Compaq Presario 700 470024-192 Notebook
Not being able to connect to Internet still
  1. Check the wireless adapter of your laptop. To do that, go to control panel then go click on System then go to Device manager.
  2. On Device Manager window, look for Network adapter. Check all the Network adapters installed to your laptop.
  3. Look for the wireless adapter installed in your laptop. Once you found it, right click on it and then click properties.
  4. Under the general tab, look for Device status.
  5. Make sure that the wi-fi button of your laptop is enabled.
Hope this helps!
Nov 02, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Problem in wireless network
what exactly are you connecting too,
Axis Point ???,Wireless Device ???,Wireless Network???
Make and model thanks.
This will help better understand your problem thanks
Jul 25, 2008 | HP Compaq Presario V2000 Notebook
Trying to hook up internet
Hello
Please check whether the Wireles s button is on and there are any yellow marks in the device manager.
Click start and select Run. In the Run box type devgmgmt.msc and press enter. This will open device manager. Then click on + sign next to network adapters and check whether the wireless adapter listed and any yellow marks beside it.
If there is no yellow marks beside the wireless adapter and it is listed in the device manager. Then try to install Wireless drivers and reconfigure wireless network.
Thanks
Regards.
Jun 21, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
210 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
