Question about Toshiba DOCSIS Cable PCX1100 Modem
Random Disconnect: PCX 1100U
I have a Toshiba PCX1100U cable modem. My cable company is Cox. My computer is an iBook G4 (Apple). I am frequently disconnected from the internet. The first solution tried: disconnect a FON router. Didn't help. Second solution tried: change splitter for internet & TV. Didn't help. Third solution tried: Cox cable man came out and said the modem was shot. These guys are always trying to sell you something new (and expensive) so I'm suspicious. He checked that the signal was strong coming into the house and at the cable to the modem. He checked all connections. Do I need a new modem or is there a fix?
  • Rizz123 Jan 08, 2008
    I have the same exact problem. I was using a Belkin router, which I thought was the problem, replaced it, and nothing. It does still happen, just not as often. Went from a disconnect time of about every 2 hours to about ever 10 hours maybe. I have looked everyone for a solution, and havent found one. I blame Cox(Now Suddenlink)'s crappy service.
    When this problem does occur, I just unplug the power cord to the modem, and plug it right back in. The internet should work once you do that.
  • 86 Answers
Toshiba 1100 modem are no longer compatible with any service providers anymore. The reason for this is Toshiba quit making cable modems and no longer supports them. Since they no longer support their modems, they don't write firmware to make them DOCSIS 2.0 compatible and since most service providers use 2.0, your DOCSIS 1.1 modem will not function correctly. Actually what is really happening is the 1100 modems cannot correctly decipher the 2.0 and are constantly changing their transmission power levels. You definitely need another modem, and if you are using Cox, ask about their refurbished ones for about 20 bucks.
Posted on Jan 20, 2008
    President:
  • 317 Answers
That's a hard one to say, you won't know unless you purchase a new modem and install it. But I have seen cable modems just quit, so it does happen.
Posted on Aug 01, 2007
How can i play candy crush on my apple ibook g4
machine is too old for the required plugins.
Dec 07, 2013 | Apple iBook G4 Mac Notebook
Apple logo and loading symbol
If you have another MAC computer available, you can create a USB key to solve this problem:
http://www.techrepublic.com/blog/apple-in-the-enterprise/how-to-create-a-bootable-usb-to-install-os-x/
If not, I'm afraid you will have to turn to an authorized apple service center. They will do the repair for you.
Jul 19, 2013 | Apple iBook Laptop G4 iBook 1.33GHz...
Can my apple ibook g4 work without an airport extreme card
If you mean 'work as a computer' then the answer is yes.If you mean 'work on the internet' the answer is yesIf you mean 'work wirelessly on the internet' then the answer is no.
You can use an ethernet cable to connect to your Router and that will give you the internet.
Feb 18, 2012 | Apple iBook 12 iBook G4 1.33GHz,...
My iBook G4 will not turn on though it has a full battery & is connected to a plug socket also..
There are several models of iBook G4. The following sequence applies to the "14-inch Early 2004."
Remove all peripheral cables. Remove the battery. Reset the power manager by pressing the key combination Control-Option-Shift-
power. Then plug the iBook into AC power and attempt to start it with the power key.
If this procedure does not being it back, invasive diagnostics are required, in which case you should being it to an Apple-Certified tech for repair.
Jan 21, 2010 | Apple iBook G4 Mac Notebook
Bought a new laptop; want to connect it to this modem via wireless
is your pcx1100u cable modem is not wireless ready? only router have a wireless lan... buy it...
Jun 16, 2009 | Toshiba PCX1100U High Speed Cable Modem
USB reads wireless modem, software doesn't!
mac doesn't support any data card till date so this is not working . if you want to connect it install windows using bootcamp then your problem will be solved. if something importent rate this article
May 09, 2009 | Apple iBook G4 Mac Notebook
My iBook G4 is tuning diffrent colors when its on. itll switch back and forth from red blue green
The LCD Connector is loose, Bring it to the Apple Genius Bar and have them look at it. Another way is to take the iBook apart and check for loose cables.
Mar 11, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Toshiba Cable Modem PCX1100u
OK. First of all you do not need a special or seperate driver for the Ethernet port. Its factory loaded with your OS.
All you need to do is plug the Ethernet cable into the LAN port on your HP Desktop and then into the LAN port (not the WAN port) of your cable modem.
The second thing is if its only a cable modem, then I suggest you proceed with caution as there is NO built-in firewall on a cable modem. Yes you will get on the net, but you are likely to be attacked with virus the moment you connect. I suggest you check very carefully whether the cable modem (if that's what it is) does/does not have a firewall as you would be very unwise connecting up like that.
Next, forget USB connection to the router/cable modem. That technolgy we've moved on from.. Your Vista shodul be 'plug n play' adn should configure the router for you. obviously that bit isn't so slick on yours.
Let me know how you get on..
Aug 31, 2008 | Toshiba PCX1100U High Speed Cable Modem
Pcx1100u
did'nt get ya
throw some light on it!
you know what sometimes virus/spywares/adwares can slow down you're pc to 486 pc's lol
so do a clean instalation + format ya whole HDD and recreate partitions + when you install windows the 1st thing you've to do is that install Symantec Endpoint Protection or BitDefender Total Security on ya pc
hope it'd be helpfull :)
peace!
Jul 04, 2008 | Toshiba PCX1100U High Speed Cable Modem
Toshiba DOCSIS Cable PCX1100 Modem Logo
859 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
