Question about LG CU400 Cellular Phone
Activating the buetooth function.
I recently purchased a non-brand name Bluetooth device on line. When I tried to activate it, I had no devices listed in the Bluetooth device file. Am I doing something wrong? Can I get the device software to connect the divece?
    New Friend:
  • 31 Answers
First, you should install Bluetooth setup or use windows 7 for easy to connect your device. If you would like see latest Bluetooth check this one Bluetooth speakers and hands free kits Supertooth
Posted on Mar 20, 2015
You have to "pair" your bluetooth device with your phone. This is just a fancy way of saying "sync" with each other. Check your bluetooth headset instructions on how to do this.
I am using a Motorola H700 Bluetooth Headset. To "pair" it with my phone I have to hold down the call button on the actual bluetooth headset itself while the headset is turned off. This puts the headset in "pairing" mode so its ready to detect any phone that wants to sync with it.
Then I have to go to my actual LG CU400 and enable bluetooth settings. Next, go to "Device List" settings and select "new". The phone will scan for the headset. Once the phone detects the headset it will request a numercial passcode. Your bluetooth headset instructions should list this passcode. Enter the passcode and the phone and headset are now connected! I hope this helps. Good Luck!
Posted on Feb 16, 2009
How to fixed buetooth device in my windows xp pentium M
Whats wrong with your bluetooth device?
You can always purchase and install a usb bluetooth adapter from Tiger Direct.
http://www.tigerdirect.com
When the site comes up just put USB Bluetooth Adapter in the search box and hit GO.
May 12, 2012 | Lenovo Computers & Internet
How to fixed buetooth device in windows xp pentium M
May 12, 2012 | Acer Aspire 3690-2196 Notebook
How to activate bluetooth? (driver is installed)
Press the Bluetooth button on the Laptop and it should enable the bluetooth function.
If that does not help, try the steps below.
Click on Start Button, Control Panel, System. Next check to see if your have a "Bluetooth device in your list (should be at the top under Bluetooth Radio's)
If you computer has the device installed it will tell you. If you right click on the device and go in under properties it will tell you if the device is working properly. You may need to just update the driver
Basic steps to check bluetooth connectivity or activity is.
1. first enable/start bluetooth on ur Laptop & Mobile !
2. then search for devices in the menu..
3. it will show u a list or a name of ur single device..dat may be ur laptop/mobile name !
4. select dat device and it will make the connection
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 29, 2010 | Aspire Acer AS5315-2856 Laptop
How do i send pictures via bluetooth between a blackberry and non blackberry phone
just activate bluetooth on both phones then go to file u want to send via bluetooth, click on options then send viz bluetooth, click on search for new devices, select device name for phone u want to send file to then send.
Oct 05, 2009 | RIM BlackBerry Curve 8520 Smartphone
My bluetooth samsung WEP301 is not working with my samsungj700 phone. in applications i turn the activation on.it says bluetooth activated. do i have to do anything in devices in there?coz when i try that...
all you have to do is after activating bluetooth in both the phones, change the visibility "to all" in both the phones' bluetooth settings.this setting will not be set by default in some phones.after setting them then search for the device in one of the phone.you will be able to find them.
Aug 25, 2009 | Samsung J700 Cellular Phone
How to send photo from mobile to our computer
there are 3 ways
1.
You can use the USB data cable to transfer data between
the device and a compatible PC or a printer supporting
PictBridge. You can also use the USB data cable with
Nokia PC Suite.
To activate the device for data transfer or image
printing, connect the data cable. Confirm "USB data
cable connected. Select mode.
" and select from the
following options:
Nokia mode — to use the device for PC Suite
Printing & media — to use the device with a
PictBridge compatible printer or with your
compatible PC
Data storage — to connect to a PC that does not
have Nokia software and use the device as a data
storage device
To change the USB mode, select Menu > Settings >
Connectivity > USB data cable and the desired USB
mode.
2.
Set up a Bluetooth connection
Select Menu > Settings > Connectivity >
Bluetooth and from the following options:
Bluetooth — Select On to activate the Bluetooth
function. indicates that Bluetooth is activated.
My phone's visibility — to define how your device
is shown to other Bluetooth devices
Search for audio enhancements — to search for
compatible Bluetooth audio devices. Select the
device that you want to connect to the phone.
Active devices — to check which Bluetooth
connection is currently active
Paired devices — to search for any Bluetooth device
in range. Select New to list any Bluetooth device in
range. Select a device and Pair. Enter an agreed
Bluetooth passcode of the device (up to 16
characters) to pair the device to your device. You
must only give this passcode when you connect to
the device for the first time. Your device connects to
the other device, and you can start data transfer.
My phone's name — to set the device name for
Bluetooth connections
3. Take off you microSC memory card then read directly to your computer
cheers!
Jul 11, 2009 | Nokia 3110 Cellular Phone
How do I turn ON the Bluetooth fucntion on my phone? How and where can I find the Bluetooth menu with the list of devices on SGH-a437?
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.php
Apr 14, 2009 | Samsung Bluetooth?® WEP200 Headset...
Activating bluetooth
hi.
lahansseynar,
first you have to download the driver of the bluetooth device from the dell driver &utilities cd & then u can recive and send diffrent items to another bluetooth device.
Dec 21, 2008 | Dell Vostro 1700 Notebook
How to activate integrated bluetooth in Toshiba Protege R500?
dear szeee
maybe you can read this
Bluetooth hardware and software (Bluetooth Stack) is necessary in order to use Bluetooth.
Please turn your Notebook upside down and check whether or not a Bluetooth sticker is attached.
Check your product model sticker string above the serial number, if it includes a
"B" (=Bluetooth) near the end. In both cases Bluetooth is built-in.
A internal Bluetooth module should be in your system if the "System devices"
section of the "Device Manager" shows a "Bluetooth ACPI from Toshiba" device.
Have a look at the "Device Manager" picture below for more details.
Ensure that just one Bluetooth hardware is installed.
Read the “TOSHIBA->Bluetooth Hardware” section of the following webpage to find a suitable Bluetooth hardware:
>>> go to PRODUCT INFO
thanks
cropp
Mar 15, 2008 | Toshiba Portege S100-S1133 Notebook
Bluetooth Problem
this will help
go to device maneger
check for your bluetooth device
check if it is activated
if not activate it
you could also check for driver details
just incase you dont know how to go to device maneger
if your using MSwindows any ver. go to system properties
Jan 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
LG CU400 Cellular Phone Logo
324 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
