Question about Maxi-Cosi Familyfix Base Isofix only
Broken lever The pull lever to my family fix base has broken, it has come away from the wire which releases the car seat from the base
2 Suggested Answers
Bruce Boogie
  • 242 Answers
SOURCE: We have a cabriofix car seat on a family fix base
Get back to where you bought it for a replacement - these things HAVE to work perfectly to keep your child safe - don't try to "fix" it you could live to regret it.
PLAY SAFE
Posted on Mar 13, 2011
Why wont my Nissan drivers seat move forward and back?
check for the release wire fully releasing the lock on that side. when you pull on the release lever it is to pull both release locks so the seat will move.
Sep 29, 2014 | 2005 Nissan Murano
How do I replace driver seat lever assembly?
You didn't say if lever was broken or just not releasing the lock. If the latter, remove the seat from the floor, turn it upside down, reconnect the wire/rod to the lever that pulls the lock on the right side of that seat. Wrap a wire tie around it so it won't come out again.
Jul 30, 2014 | 1999 Ford Explorer 2-door/Explorer Sport...
My family fix isofix base will not release the maxi cosi car seat We pull the lever and it doesn't release the car seat Is the unit broken or can it be fixed If so how can I fix it Or if it is broken is...
Hi Melanie
To override release the carseat from the base, use a pair of long nosed pliers to reach the wires that are inside the base. They can be accessed underneath the grey button on the base. Pull the wires toward you and the carseat can be lifted from the base.
This is an issue with the base, not the carseat, so the base needs to be sent in for inspection and repair required. Please contact the customer care team for further assistance. 87985515-e848-4733-8df0-f4baae5e6226.jpg
Jan 15, 2014 | Baby Gear
Maxi cosi pebble broken handle
Hi
The seat must not be used with a broken carry handle. The carry handle provides vital protection to the child in the event of an impact.
If you're in the UK and the seat is under 24 months old return it to your retailer with proof of purchase for them to send to the engineers for inspection / repair required under warranty terms and conditions.
If you're in the UK and the seat is over 24 months old or you no longer have proof of purchase you can book in for chargeable inspection / repair with the customer care team on 01284 413 141 Mon-Thur 08:30-17:30 / Fri 08:30-16:30 (Excluding Bank Holidays) Standard charge is 39.99GBP and this does include courier collection and delivery.
If you're not in the UK please visit www.maxi-cosi.com and select the country you're in, then choose the Contact Us tab on the right side of the screen for your enquiry to be sent through to the customer care team in your country who will assist you further.
www.facebook.com/notes/dorel-uk-customer-service/repair-charges-effective-immediately/360663627314836
Jan 11, 2014 | Maxi-Cosi Baby Gear
Pt cruiser stuck middle seat belt
The problem:
The set belt stop has been lost so the seat belt retracts too far when the seat is laid flat. When laid flat the release mechanism lock as it should when not level. So the seat cannot be raised up as the belt is too tight and locked.
The Solution:
1) Push the two little clips to release and remove the headrests.
Pull the grey lever on the right of the seat base, lift seat base up and forward toward the front seat..
2) See two red capped leversat the back of the two seat hinges and lever them to the upward position, this releases the seat.
Rock the very heavy seat unit upwards and lift complete unit upwards.
3) Take it out of the car and turn 180% so that the back of the seat and base are in the upward position and the seat belt will pull out as it should
4) Replace the missing belt locking stop (I used a tie pin permanently fixed using super glue).
5) Fold seat back down and test then either re-fit seat unit or leave out to decrease fuel consumption..
Aug 02, 2012 | Chrysler PT Cruiser Cars & Trucks
The front bonnet release lever does not release the bonnet. I assume the cable is broken somewhere near the latch, as the cable is still attached to the release lever. How can I open the bonnet? the car...
easiest way could b to peel away layers of interior panels or where cable pops out an follow cable to where u can get some pliers on the broken piece, may have to peel back insulation on cable to access broken wire to pull on with pliers .hope this can help, good luck
Apr 09, 2011 | Porsche 911 Cars & Trucks
We have a cabriofix car seat on a family fix base (purchased new in Dec 2010). The car seat is stuck on the base. One of the clips will not release when the grey handle is pulled. Any ideas why?
PLAY SAFE
Mar 13, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
How do u release seat from base
Good Evening
At the front of the base unit (nearest to the edge of the vehicle seat) there is a large grey release clip. Pull this clip forward (toward the front of the vehicle) and lift the carseat away from the base. Ensure that you lift the carseat completely away before letting go of the release clip as otherwise it may not release fully and the carseat will still be partly attached.
Jan 16, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Rear seat belt is stuck in recline position. I recline the rear seat to make room and I can not raise the seat back up. The seat belt is not allowing the seat to raise
The problem:
The Solution:
5) Fold seat back down and test then either re-fit seat unit or leave out to decrease fuel consumption.. 2_5_2014_8_03_56_pm.jpg 5f6d2b58-2927-4184-9c82-d111e3a9591a.jpg e9f641fc-5fbc-4c21-a371-ff371d942b1a.jpg a357ac71-d6ed-4dc7-999c-04367d3d6e72.jpg
Oct 26, 2010 | 2002 Chrysler PT Cruiser
How do i remove the drivers seat in my 99 chevy silverado? I need to figure out why my seat will not slide back and forth when I pull on the seat adjust lever.
Probablyt because the little wire cable that activates the release mechanisms on both sliders is broken, and therefor only allowing only one slider to release when you activate the seat adjusting lever, and leaving the other one engaged, preventing you from moving your seat. This is relatively easy to diagnose, if you know what to look for... Just try to see what all moves when you press your lever. See if there is a wire cable that is activated anywhere under your seat it should be relativley close to your lever and run across the open space to the opposite slider.
Apr 24, 2010 | 1999 Chevrolet Silverado 1500
Maxi-Cosi Familyfix Base Isofix only Logo
282 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Douglas Dinnebeil
Douglas Dinnebeil
Marc Cohen CPSTI
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
