which of the two water inlet connections are for hot or cold water please. as they both have red...
(More)
which of the two water inlet connections are for hot or cold water please. as they both have red connection caps on. Thanks
zanussi FS1355W beeping after cyle and now doesn't work. NOt filling with water, won't work on drain...
(More)
zanussi FS1355W beeping after cyle and now doesn't work. NOt filling with water, won't work on drain or spin cycle either just makes a humming noise
My machine FS1455W, is beeping 11 times, and flashing the end light, when trying to start. The...
(More)
My machine FS1455W, is beeping 11 times, and flashing the end light, when trying to start. The machine is loaded and the door closed, but it will not start.
I have cleaned the lower filter on the front lower door.
Can you help please
i set up the cycle and pull the timer button, the machine is working, but it failed to run in the...
(More)
i set up the cycle and pull the timer button, the machine is working, but it failed to run in the next cycle, when i pried it a little bit, the machine is running, but it will stop soon, it looks like the connection inside the timer is not good.
My w/machine started to leak - I bought 2 new inlet hoses and have put them on numerous times but...
(More)
My w/machine started to leak - I bought 2 new inlet hoses and have put them on numerous times but the leaking still occurs from the connection when water is turned on. Each time they are connected properly with the correct washer attached but water starts to leak from the connection and is constant. When I go ahead and put a wash on - the leak gets worse and the connection just comes off. I have turned down the water pressure but this doesnt help!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
