Question about Sanyo PLC XU33 Multimedia Projector
Picture is upside down on my sanyo pro projector
  • 84 Answers
SOURCE: Sanyo PRO Xtrax Multiverse Projector powers on but no reflection appears
broken lamp?? check for little cracks in the bulb bar.
If lamp is discoloured( dark grey), overheating is cause, no cooling after using the PJ.
Posted on Sep 25, 2008
Nic61
  • 1073 Answers
SOURCE: my projoctor picture is upside down
http://www.manualnguide.com/dl/14476/
There u will find the manual for your projector, read it and follow the steps how to tunt the picture up and down.
Good luck
Posted on Dec 02, 2008
  • 3 Answers
SOURCE: 2 projectors that have blown their lamps
My guess is with them so high in the air, no one seems to clean the air filter often enough. Also, the projector is at 840 hours which is just a few hundred below the normal lamp expectancy. Also, I would wonder how they are shut down. Do they actually go through their normal shutdown process as requested by the manufacturer, or has someone that programmed the shutdown to just kill the power to the circuit. That would definately be worth checking.
Posted on Dec 29, 2008
SOURCE: Sanyo Pro Xtrax Projector
not all computers are F4 - some are F7... - If there is not a small graphic on each Function button - just press and hold your function button and I'd start with F3 then F4 then F5 and so on - often your image will appear on the projection screen and disappear from your laptop - just re press Function and the appropriate key - you may also need to change your display - go to your control panel then display then settings and you will want 1024x768 - as far as cables you will need a male VGA that will plug into (usually blue) connection on your laptop and then depends on what type of projector you are using - it may take a VGA or RGB (5pin cable ~ red green blue horizontal vertical) make sure that in your menu settings that you have it set to the same as the input you have plugged into
Posted on Feb 13, 2009
projdoc
  • 2237 Answers
SOURCE: picture dull colours incorrect
reset to factory default settings (from the menu). after that if it's not where you want them, you can go into the menu and set them to where you like them.
Posted on Aug 06, 2009
Does the Sanyo multimedia prox-III hook to direct tv
Sanyo connect directv Multimedia Projectors Questions ...
www.fixya.com > Forum > Tags > connect directv > Multimedia Projectors
Sanyo multimedia projectors connect directv related questions and answers. ... 3Answers ... configuration hey...i have a sanyo PLC-SU30 PRO-X MULTIVERSEPROJECTOR and i can't connect it to my laptop,i have connected the cable and ...
Sanyo Pro-X multiverse projector - YouTube
? 1:46
https://www.youtube.com/watch?v=awwXqdPRkNw
Feb 27, 2013 - Uploaded by WeeePC
Sanyo Pro-X multiverse projector start up. ... It was Sanyo at first sight!! ... 3:49. How we setup our LCD projector to reflect onto the kitchen table ...Missing: directv
db:: 5.32::MBP and Sanyo Z2 Projector 19
www.hivmr.com/db/199a98kjjjjz33k9kzk9p8kdfc1cdfjs
i have a hp g60 laptop and want to connect it to a sanyo pro-x projector, but i cant find it on the ... problem: I have a Macbook Pro 2009 running 10.6.3 and an Epson Projector.... You should hook up your projector to the DVI or the VGA. ..... I just bought a Sanyo Multimedia Projector (PLC-XU25A) and I can't get the projector ...
Jan 20, 2016 | Sanyo Office Equipment & Supplies
We have inherited a Sanyo Pro-X multiverse projector without an instruction manual. The projector was fixed to a ceiling but we would like to use it freestanding. When attempting to use the projector this...
You need to turn off the ceiling mode to get the picture to project correctly. This is in the Settings Menu. See page 37 of the manual which is currently available here: http://cncms.com.au/SANYO-IMs/Commercial-Industrial/plcsw30_im.pdf .
Press Menu. Then use the left/right arrows to move to the icon with the projector and screen shown. (Note: right now this row will be on the bottom of your screen and the icon will be to the left side of the row.) Press the down arrow and move to the Ceiling icon with the R. It should be the seventh icon from the upside down "Up" arrow; it's next to the Capture icon with a camera. (Normally, ceiling icon shows as an upside down R when your image is projected right-side up. There is also a rear-projector icon with a mirror image R when the image is right-side up.) Press Select and then use the arrow keys to choose the On/Off options. You may need to press Select again to save the setting.
I hope this helps.
Oct 11, 2017 | Sanyo PLC-SW30 Multimedia Projector
Image upside down
You have to access the menu with the remote and scroll through until you find image page and then reset it.
May 19, 2010 | Sanyo USHIO PROJECTOR LAMP, Projector Lamp...
Whole projector (HD Pro Wide mutliview Model # PLV-70) shuts down after 10 minutes or so of use. Lamp is perfect.What do I do to fix this? . Happens nearly every time. Is there some control button I shoud...
overheating. clean out the projector with canned air. dust keeps in the heat. should be done periodically. about every 500 hours or so, depending on usage and environment. if it happens often after that, replace the thermosensor and check the fans.
Oct 20, 2009 | Sanyo PLC XU35 Multimedia Projector
Picture upside down after installing on ceiling
Try Uninstall the projector and install again.
luciana44
Aug 23, 2009 | Epson EMP-745 Multimedia Projector
I have no reemote and do not know how to invert the picture. I have to have the machine upside down to view it the right way up!
Press menu and go through the settings. Its in there somewhere cause I came across it accidently! Just change them all which you think could be related.
Apr 13, 2009 | Sanyo PLC XW20A Multimedia Projector
My projoctor picture is upside down
Good luck
Nov 20, 2008 | Sanyo PLC-SW30 Multimedia Projector
Nov 11, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo plv z4
look in the projector menu ( should not be backwards) and switch the view to front projection. It might be set in rear projection. That is what my viewsonic PJ-558 projector can do sometimes
Jan 26, 2008 | Sanyo PLV-Z4 Multimedia Projectors
Sanyo PLC XU33 Multimedia Projector Logo
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
