Question about Sony KP-41T65 41" Rear Projection Television
Red and blue gun not lined up
When i moved the red and blue gun i did it from the remote control unit i moved it to the left and it will not move back i did not do it from the actual gun itself
  • Sony Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. Thisred and blue gun not lined up - 2c07611.pngn problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
TV set aftred and blue gun not lined up - 2c07611.pngange
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 28, 2009
Red lines all over the screen
this set(AV56wp74) was first made in 2003----if you use the remote for the set and go into the customer menu---select convergence----once there see if the red and blue will move left/right and up/down----if either color will not move in any one of these directions----you have a bad convergence IC--this set uses 2 of the STK-392-110 output ic chips---both need to be replaced and the set adjusted with the original JVC remote control. I hope this has been helpful.
Aug 11, 2009 | JVC AV-56WP74 56" Rear Projection...
Alignment on the MT1050
You need to take it to a NEC service center or a local professional to get the lcds alinged again.
Jul 18, 2008 | NEC MultiSync MT1050 Multimedia Projector
Red gun convergence problem
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Using your original remote go-to the settings menu then goto the convergence section.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 16, 2009 | Toshiba 65HX81 65" Rear Projection...
Puzzles 130 Too Many Queens 5 --- 132 Princess's Escape
puzzle 130:Assuming on a chess board 8x8 that each square is numbered 1-64 top left to right.Place a queen on each of these squares 3,13,18,32,33,47,52 and 62 bobs yer uncle
Mar 09, 2009 | Nintendo Professor Layton & the Curious...
Toshiba TP50H15
You can adjust the lines and make them straight. You can also in the same process, make them line up.
1. With the TV on, press the mute button the remote control so that you have picture but no sound.
2. With remote in one hand (holding it as far from the TV as you can but still be able to reach the TV with your other hand), press and hold the mute button again, with the other hand, using the control panel underneath the screen, press the menu button on the TV set.
You will notice an "S" on the screen on the right hand side about 2/3 from the left, halfway up the screen (If you did this right).
This means you are in service mode.
With the remote, curse right only once and you will have some information displayed in the upper left. The top line is Item, the one underneath is Data.
Press "7." This will display the built in cross hatch pattern. You can move the line around with the directional circle located at the center of the remote. Using the "3" button, you can decide which color to move. To move the curser to a new location, The number pad doubles as a direction key pad. (2-up), (4-left), (6-right), (8-down). To simplify the process, you can eliminate the red or blue or green lines and only focus on one color at a time. "0" will shut on/off the green line. "100 button" will shut on/off the red line. "CH RTN or Enter will shut on/off the blue line.
"7" will exit the process as well as get you there.
Power off when you are done and turn back on.
Repeat as needed.
Jul 05, 2008 | Toshiba 50HX81 50" Rear Projection...
Convergence problem???
you must move red and blue lines into the green. change red to blue by useing the select button on the remote. till all convergance lines are white
Jan 12, 2008 | JVC AV-48WP30 48" Rear Projection...
Fine tuning grid on my Samsung HDTV with remote.(BP59-00048)
To adjust manual convergence on your projection TV, follow theses steps:
  1. Turn your TV on.
  2. Let it warm up for 30 minutes.
  3. Press the Menu button on your remote. The Main menu appears.
  4. Use your remote to select Function, and then press the joystick.
  5. Select Convergence, and then press the joystick. The Manual Convergence screen appears.
  6. Select Red, and then press the joystick. A series of crosshairs appears on the screen.
  7. Select one of the outside crosshairs by moving the joystick up/down/right/left or by pressing the 2 (up), 4 (left), 6 (right), or 8 (down) buttons on your remote. The method you use depends on the model of remote you have. Note: You must do the outside crosshairs first.
  1. In the crosshair you selected, if you can see a horizontal red line, use the CH up or CH down buttons to move the line so that it is superimposed on the horizontal center line of the crosshair. Note: Make the single horizontal line as white as possible.
  1. In the crosshair you selected, if you can see a vertical red line, use the Vol + or Vol - buttons to move the line so that it is superimposed on the vertical center line of the crosshair. Note: Make the single vertical line as white as possible.
  1. Repeat for all outside crosshairs, and then for the inside crosshair.
  2. Return to the Manual Convergence Screen, and select Blue, and then press the joystick.
  3. Repeat Steps 7 through 10 for Blue.
  4. Press the Menu button on your remote to exit.
Important: The directions above work for most Samsung Rear Projection TVs. Yours may be different. For exact directions to perform manual convergence, see your user's manual. If you don't have your user's manual on hand, click HERE to view your manual on line.
If you cannot get your Projection TV to converge, it may need to be serviced. To arrange a service appointment, call Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your TV's model number and serial number on hand when you call.
Jan 05, 2008 | Samsung BP59-00016A Remote Control
Samsung HDTV
If you changed the ICs you need to adjust convergence, read carefully the instruction and alingn the lines using remote control commands. Is a long process. My tv loss convergence three times , i will never buy another samsung product. I told every body that i know that never buy another samsung product.
Oct 26, 2007 | Samsung HC-P4752W 47" Rear Projection...
Color guns out of alignment
It sounds to me like the convergence amps themselves have failed. Ic7001 and Ic7002, both are STK392-110 Sanyo built Ic's and not an expensive job for a qualified shop. When shopping around for a shop to repair it ask what they charge for replacement of the convergence amps in this unit. And take the unit to them to save pickup and delivery charges...
Have a great day!
Bill
Dec 21, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Sony KP-41T65 41" Rear Projection Television Logo
139 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
