Question about Konica KL-3015 Laser Printer
F63 OHT Sensor - Konica KL 3015
Where is that Sensor located ?
Thanks a lot
dtpb3@lycos.de
If you like to know how to fix the Problem F63 you should contact me and join my assistance plan for 19,95 $ a month. Or you fix the problem yourself
Take a Q-Tipps and brush inside the littel hole/slot below the OHT-Sensor Lever on the left side of the paper pass.
Have some fun with this free advice.
....see ya
Posted on Jan 06, 2009
Hola; como cambio las millas a kilometros??
menu de mantenimiento.
Tome la llave de seguridad a cabo. Hold "Inicio" "Stop" y "Enter" mantener pulsado los botones puso llave de seguridad pulg
Utilice hasta abajo de los botones para elegir "Funciones", pulse MENU ENTER.
Utilice las teclas Arriba y Abajo para desplazarse por las unidades, presione ENTRAR. Seleccione millas o kilometros Pulse STOP para guardar y volver.
Fuente: Manual PDF en la suela sitio web.
Aug 16, 2013 | Sole Fitness F63 Treadmill
How can i print on 2 sided, mean two pages on word i want to print them in one page
Does you machine model KL-3015 have duplex option which allow you to print two sided document.?
Sep 16, 2012 | Konica KL-3015 Laser Printer
F63 sole treadmill, low speed error when inclined
If the calibration does not pass you may need to check the speed sensoralignment. You must understand the instruction for calibration is under the hood for motor.
1) Remove the motor cover hood by loosening the 4 screws that hold it inplace (you do not need toremove them completely).2) The speed sensor is located on the left side of the frame, right nextto the front roller pulley (thepulley will have a belt around it that also goes to the motor). Thespeed sensor is small and blackwith a wire connected to it.3) Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
2) if the problem persist you must Test the main motor for open, ground 3) the main control board faulty. See the block diagram that I did as person like you that understand that 90% of functions the main motor controller board has effect.
good luck. sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Dec 01, 2011 | Sole Fitness F63 Treadmill
Where can I find parts for my hitachi oht-15 air compressor
This is the US-Hitachi service center locater internet address. Just enter your zip code and radius and it will return a listing of service centers close to you. If this answers your question please mark it as solved and you can leave feedback on me.
http://www.hitachipowertools.com/where_search.php
Thanks, Ron
Sep 14, 2009 | Hitachi Air Tools & Compressors
Water leaking
Hi, Its the ac/heater condensate hose and its supposed to be like that. A puddle of water under your car is normal especially when the weather is hot and humid.
Feb 01, 2009 | 2002 Dodge Neon
KL-3015 paper jam at lower paper tray
Hi, the roller is available from this link. http://www.precisionroller.com/search.php?add2cart=19976
Nov 04, 2008 | Konica KL-3015 Laser Printer
"replace transfer kit" for Konica KL-3015
Hi Hexus, http://www.kmbs.konicaminolta.us/eprise/main/KMBS/Support_Center/Manuals/Pages/Attachments/3015gs.pdf Download that manual the directions with diagrams for replacing the transfer kit are on page 40 (in the page numbers on the docs themselves, the Acroreader page number is 51) Hope that helps, El Duderino
Nov 21, 2006 | Konica KL-3015 Laser Printer
Konica KL-3015 Laser Printer Logo
108 people viewed this question
Top Konica Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Andrew Taylor
Andrew Taylor
richie46
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
