Question about Electrical Supplies
How do u check the low oil sensor on a wheelhouse 5500 generator.
2 Suggested Answers
ROMOAS
  • 97 Answers
SOURCE: Wheelhouse 5500 Genarac Generator Replace rear
the gen head will need to be removed if it in on that side and the flywheel side should be done as well the seals can be purchased from any auto parts store with using the numbers off the seal some engines need to be split do to the seal needs to enter from the inside side if this is the case reseal the hole engine i suggest you get a small engine repair manual or the manual for your unit this will be a involved undertaking removing the gen head can be tedious and special tools will be required so no damage to it hope this helps
Posted on Aug 31, 2010
I have an Onan 5500 Marquis Gold LPG generator that runs but backfires and spitfires. Need troubleshooting assistance!
have a gas shop inspect the gas converter / regulator
next check the ignition circuit for shorting / loose connections causing a spark at the wrong time
check the low oil sensor unit as it is known that they fail and cause indications of your problem
check oil level in the sump as it may be making/ breaking the circuit if too low
Sep 10, 2017 | Electrical Supplies
Portable generator won't spark.
replace the low oil level sensor pack
it controls spark
Jul 20, 2016 | Generac Electrical Supplies
We have a Maxa ER 5000 Tecumseh Generator, changed the oil and spark plug, no fire. How do you check the low oil switch?
Nancy, If you think this is the problem, simply unplug it. See links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Disconnect Your Low Oil Sensor
Re Testing Low Oil Sensor on Honda GX Engine
How to Test the Low Oil Pressure Switch on Generator
Generator runs then shuts off
Feb 26, 2016 | Electrical Supplies
Why won't it start or spark?
check the low oil module for operation as it stops spark if the oil is low or the module has failed
Dec 14, 2015 | Lincoln Power Arc 5500 Generator/Welder
Powermax xp8500e will start and run about 5mins quites restart and run about 5mins quites and won't restart (no fire at sparkplug)
most of this generators have a shut off for low oil, so check your oil level to see if this is the problem
Sep 15, 2011 | Watts Onan Portable Generator - 4000 ,...
I have a centurion 3250 watt portable generator it was working fine 2 days ago but it will not start. Will not being on a level and flat surface cause it to not run ?
Hi and welcome to FixYa, I am Kelly.
Your question:
"Will not being on a level and flat surface cause it to not run?
In short YES!
Generators have low oil level sensors that are quite fussy about their orientation. If there are any inclinds a generator is sitting on you can get FALSE low oil level shut downs.
You must make sure the generator is full of oil and I do mean FULL. Additionally do what you have to so that the generator sits level horizontally.
A quick way to find out if the low oil level sensor has been activated is to simply check spark.
If you have no spark:
FILL WITH OIL
Re-orient generator to a level position (15 to 30 second wait)
(Check spark again) If you now have spark your low oil level sensor had gounded the ignition because it sensed a low oil level either from an actual low oil level condition or the unit was on an incline causing a false low oil level senor activation and a subsequent engine shut down.
Thanks for choosing FixYa,
Kelly
Aug 28, 2011 | Electrical Supplies
Wheelhouse 5500 Genarac Generator Replace rear Briggs Stratton engine Oil seal
Aug 30, 2010 | Briggs & Stratton Electrical Supplies
Electrical Supplies Logo
35 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
