Question about Motorola Mobility RAZR V3
Keypad motorola V3x
My problem is that i was properly using the phone then suddenly when trying to use the keypads am unable to do so. What can i do please? i cant even check my message or make a call.. i cant do anything with the phone? any remedy for that please?
    Scholar:
  • 91 Answers
Again a nice fail safe solution is the master reset and the master clear functions. This will remove any corrupt files on the phone. Also, if you aren't experienced modifying you phone with online software isn't a good idea. Even those of us who are experienced get in trouble some times and that's why we always keep backups of our phones on our computers
Posted on May 28, 2007
I have noticed that not even taking out the battery gets rid of the locked keys. i just wait for the lock keys to go back to normal
Posted on May 25, 2007
When the keypad locks up I have found that removing the battery and then replacing it allows keys to reactivate. My phone locked because of a corrupted/modified 'Theme' I tried to use. Once I unlocked the keyboard by the above method I was able to delete the offending theme and I seem to be back in business. Best of luck!
Posted on May 24, 2007
How can reset my motrola razer v3x without secret code plese help me
Hello, You can perform a master reset to dissolve any glitches, bugs or other complications you experience with a Motorola Razr V3x. According to the device's user guide, a master reset will reset all options in the phone, with the exception of the "unlock code, security code and lifetime timer." Back up any data, pictures, or contacts you wish to keep before performing a master reset on the Motorola Razr V3x
1 Navigate to the "Settings" menu using the directional arrows. Click the "Setting" option with the "Center" key on the phone. 2 Press the "Center" key to choose "Initial Setup" from the Settings menu. 3 Press the "Center" key on the keypad to select the "Master Reset" option from the Initial Setup page. Thank you for using Fixya
Dec 28, 2010 | Motorola Mobility RAZR V3x Cellular Phone
Motorola razr v3 keypad won't work
your flash cable has damage. only can repair
Aug 23, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Keypad not functioning
try and replaced the flexcable on the phone to correct this
Apr 19, 2009 | Motorola Mobility RAZR V3
The screen of my mobile phone does not work
just change the belt inside
i hope it will work properly
Dec 17, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Motorola v3x problem
The connection from your LCD to the systemboard might have a loose connection or might be disconnected.
If you have the skills, you can open up the phone (back part or keypad part) there should be a screw at the back and u must use a creditcard or any card similar to slide out the casing.
On the uppermost part of the board should be the flex which looks like a brown film and it has connectors that hooks up with the board. Just try to re seat it.
Hope this helps...
Jul 22, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Motorola V3x won't turn on
ok! battery is problem in your mobile! change the your battery! thats it!
thanking you...........
keep rating meee
Jul 08, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Broken Motorola V3x
have you ever installed a new battery since you have had the phone?
Jul 01, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Handset dead
Upma I have experienced this before and if the phone has been damp by body heat or other moisture then it does do this. try drying it out with a hairdrier on a cool setting. then leave it to dry properly for a couple of days in a warm NOT HOT place. the keypad will start to work and the battery will settle as well. let me know how this goes. t1m0thy
Jun 27, 2008 | Motorola Mobility RAZR V3x Cellular Phone
V3x problem
You have to change the ribbon (flex cable).Take it to technician and for about $15 it will be fix.
Jul 11, 2007 | Motorola Mobility RAZR V3
Motorola v3x
Hi There, If this phone is brand new it is faulty and should be returned to seller. This problem usualyy occurs when u have a faulty flex cable either on the screen or the entire keypad assembly. One of these would need to be replaced by a repair tech for v3 phones.Hope this helps. Sam !
Jun 26, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
629 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
