Lynx screen blank / white
I have a Lynx Touch system installed which had been working fine until a power outage due to hurricane Sandy. The system went on battery backup until that was exhausted. Now that the power is back on the system will not go into the standby state. It runs thru the start up procedure but displays only a white screen - no icons or any info. I've tried unplugging the system and removing the backup battery, I also tried the buttons both before and after startup but nothing has worked. Is there any magic to get it to boot up or at least isolate the problem ? Did something get fried during a brown-out or power spike ? Any suggestions would be appreciated
  • 208 Answers
SOURCE: How to correct error message sram error missing E?
Hate to say this but most likely the Print Engine Control Board has failed.
Posted on Dec 20, 2007
SOURCE: Dead laptop
where is reset button
Posted on Jan 18, 2008
SOURCE: Blank Screen on HP Laptop
HP has identified a issue with the DV6000Z and monitor. I just reported the same problem to HP and even though off warranty, they will fix free. Power up of DV6000Z you will get 3 beeps and no monitor display. External monitor does not work either. This is a known issue woth the DV6000Z.
Posted on May 08, 2008
  • 3 Answers
SOURCE: Any touch will freeze my laptop IBM Thinkpad T42
There is a common problem with this machine; the mother board flexes and the processor mount partly separates from the motherboad. You tube posts a couple of solutions but they involve taking the laptop apart and applying heat from a heat gun to resolder the mount; it is not a solution for the faint hearted. Thinkpad/Lenovo might consider reparing the unit as it is basically a desgn/production defect but don't hold your breath.
Posted on May 29, 2008
ash333ash
  • 68 Answers
SOURCE: Toshiba Satellite A200 28M, the display turn completely white on bootup or during loggedIn session
i think the problem is in your monitor......if your monitor is not working properly these kind of problems will arise......otherwise the problem may be with your graphics card.....but if your graphics card is new means.....the chances of problem occuring by it will be low or none.....i suggest you....to give your laptop from where you have buyed.....that is if your laptop company is sony means....give to sony......this is the best way dude......dont try any other method......give it as soon as possible.....otherwise your laptop will face other problems also.......i am software engineer and i have experience in it.....thats why i am telling you this......try this....it will work 100%
Posted on Sep 19, 2008
My Lynx 24 outdoor refrigerator stopped running It is less than one year old. Any troubleshooting advice?
Is there power to the outlet that fridge is plugged into. If yes you might have a blown relay that's mounted on the compressor
Mar 06, 2018 | Lynx Refrigerators
Lynx touch stuck in arme away -bypass
At the bottom of the touchscreen there should be 4 tactile buttons. One looks like a pyramid with an ! in the middle, one looks like a house with a person standing outside, one looks like a padlock that's unlocked, and the other one looks similar to an old style alarm system keypad. If you press the button with the icon that looks like the open padlock, the screen should come up and give you the option to enter your 4 digit code to disarm the system. Enter your 4 digit security code and the system should disarm. If this doesn't work, or if you don't know the valid security code, you should contact an alarm dealer for service.
Apr 27, 2014 | Honeywell L5100PK - Lynx Touch 5100...
Backlight lenovo ideapad k3 lynx seems burnt out, but will sometimes dim when cooled down
Have you tried resetting it also the fuse or resistor for the backlight might just need replaced
Apr 23, 2014 | Lenovo IdeaPad K3 Lynx Convertible...
How to unlock lynx sh 03c phone ?
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Aug 18, 2012 | Sharp lynx sh-03c unlocked gsm phone
How to send upload
to send an upload on a lynx plus panel, you must have the installer code which is nomally 4112 (system default) or the last four digits of your account number. otherwise you must power the system entirely down, and back up including disconnecting the battery. the safest way if to unplug the transformer. sometimes its in a wierd spot though so its easier to disconnect one of the power wires inside the keypad along with the battery. the battery is located in the upper lefthand corner and normally colored green. it will attach the the panel with a red and black wire.(to reset the installer code if you dont have it you must open the panel and disconnect this backup battery no matter what) the ac power attaches to the black terminal block on the far right side. once the battery is disconnected and the ac is cut, power the system back up and within 30 seconds press * and # at the same time. this enters the program menu which should say 20 installer code which can then be reset by pressing *4112 all this wont be nessicary if the code is already 4112 or the last 4 of the account. ethier way, once you have it simply enter the code, then press #1 upload sent, easy as pie. so to simplify (example: 4112#1)
Dec 15, 2011 | Honeywell | Ademco LYNX Plus LYNX Plus
Lynx plus once a zone is in fault im unable to clear it
if its in fault you wont be able to clear it. the best you can do is bypass the zone until you can get a service tech out to it. put in your code, then the number six for bypass, then the two digit zone cone. it will allow you to bypass the zone and arm it each time until it is fixed. the only other option is to completely delete the zone and render it usless until its fixed. you can do this by entering program mode using the default 4112 then 800 or the last fout of your acct # then 800 normally. if that doest work, open the keypad disconnect the backup battery (usually green in the upper lefthand corner attached with a red and black set of wires.) and power down the system all together, then power it back up. the safest way is to unplu the transformer but if its in a wierd spot like the attic you can simply unscrew a wire from the black terminal block, be careful not to touch the other wire or your transformer will blow. once powered back on, when the system fist beeps, press # and * at the same time, it will say installer code. you can set it to what you want, i always use 4112 (system default) once in main programming, hit *56 to go to zone programing, then hit the two digit zone code, then follow it with *00*1 that will totally delete the zone rendering it usless untill a service tech can be sceduled to add it back in. but, your system will be able to arm the rest of the house.
Oct 15, 2011 | Honeywell | Ademco LYNX Plus LYNX Plus
Can instal a lynx op system but not any versions of windows eh??? tried xp vista and 7 boot and repair discs, keep getting bootmgr missing or insert system disc messages but lynx op system booted up and...
I suspect your pc is not seeing the hard drive. I take it you are using a Sata drive but not installing the sata driver for the motherboard. Try installing on an IDE drive. If this works the above is correct.Good luck.
May 26, 2011 | Computers & Internet
Can't surf web or download in lucid lynx
You have to make a setting of the network through a terminal and it will work fine after this is being done properly. This is happens due to unconfigured setting in the network adapters. You can also directly make setting with the nework adapters settings. Select the proper modem and connections.
May 31, 2010 | Canonical Ltd. Ubuntu
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
