Question about Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 says paper jam but there is no paper in it.
Is there anything I can do?
  • 65 Answers
E-mail the company and request help or call, they usually post a phone number you can call for assistance.
Posted on Jan 05, 2009
I have an Epson Stylus C88 printer that I have loved. But all of a succen it pulls the paper to pint and may get one line and them wrinkles the paper and goes nuts. I hate to not be able to use it. ...
first off check try opening the paper so you can see the tray where the paper feeds in and check if there is some sort of jam or if anything looks loose.
Remove the cartridges and clean the roller/feeder that takes the paper in. If everything looks good then it could be the mechanical part of the feeder that has a problem and usually this happens when it wears out due to time or it has reached the maximum printing allowance.
If that's the case then a replacement would be necessary.
Hope this helps!
Aug 13, 2011 | Epson Stylus C88 InkJet Photo Printer
Tip
My epson cx5900 wont print anything. it takes paper in, the head moves by a few...
Two ways to reset your EPSON printer ink counter, ink cartridge, protection counter and more.
A. SSC Service Utility For EPSON Stylus Printers
This utility allows you to do many amazing things with your EPSON printers:
  • Work directly with CSIC in EPSON Stylus printers cartridges.
  • Reset or rewrite any chip using special add on device.
  • Freeze internal ink counters.
  • Reset internal ink counters even with empty cartridges.
  • Separate cleaning of color and black heads for all EPSON ink jet printers, powerful cleaning mode.
  • Hot swapping of cartridges supported.
  • Resetting of protection counter (even then it is already full).
  • More then 100 different EPSON printers supported.
This program helps people with high printing demands to save money (program works with both black and color cartridges). The software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Click here for the SSC Service Utility for EPSON Stylus Printers
B. Using the EPSON Ink Pad Reset Utility
"Parts Inside Your Printer Has Reached The End Of Its Service Life"
Generally, this error message is caused by the malfunction of non user-replaceable parts within your printer. If your product is displaying the "End Of Life Service" message, please view and complete the required information from the link below to proceed.
Click here for the EPSON Ink Pad Reset Utility
on Jun 08, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson C88 shows red alternately blinking lights
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
Feb 05, 2010 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 plus
Make sure that the head can move on the carriage bar as this indicates a head assembly lock or jam. Make sure all the paper paths are clear and there is no tiny piece of paper stuck. Power it back on. If this does not resolve then you will need a visit to the repair shop or buy a new printer which is probably cheaper!
Sep 11, 2009 | Epson Stylus C88 InkJet Photo Printer
C88+ tries to pick up paper but won't. No jams,
Probelm with pick up rubber. Replace paper feeder or just replace the rubber. Or add thickness of rubber by adding flexible double tape (about 1 mm). Add just for upper rubber.
Jul 25, 2009 | Epson Stylus C88 InkJet Photo Printer
I can't find a paper jam
There's a possibility the paper sensor is stuck up,check if there's piece of paper between the sensor.or the sensor is out of position.
Jun 30, 2009 | Epson Stylus C88 InkJet Photo Printer
My ink is jammed fro epson stylus c88.
i would download the ssc and try reseting your printer
Mar 03, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson c88
Sounds like print head issue; have it serviced or u can try this :
How to Unclog Epson Print Heads
Jan 24, 2008 | Epson Stylus C88 InkJet Photo Printer
The printer jam red icon never stops blinkin
> turn off the printer
> check for obstructions / torn paper
> disconnect the printer from the computer
> turn the printer back on
> if issue still persists, the printer needs service, contact the vendor
Jan 02, 2008 | Epson Stylus C88 InkJet Photo Printer
Epson c88+
Ther is a obstruction in paper path, something has dropped down where paper goes in, or a fragment corner of a removed paper jam is in paper pathway
Nov 16, 2007 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 InkJet Photo Printer Logo
338 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
