Question about Samsung PN42A450 Plasma TV
Samsung PS42C91HX/XFA AV2 stopped working
Hi, my AV2 input on my Samsung PS42C91H stopped working. I cannot see the AV2 channel in the setup menu. Certain menu functions have also stopped. I cannot tune channels for example. When I try selecting the menu item it is skipped. Is there any way to restore the factory settings before I call out a technician?
5 Suggested Answers
SOURCE: Digital Tv is stuck on a channel
I have found the solution at last :)
Put the TV in standby and press these buttons in order
Info, Menu, Mute and Power on.
You will then see a hidden menu, on line 12 select reset
Bingo :)
Posted on Dec 30, 2007
SOURCE: DTV locked on ITV1
do a reset in the service menu the turn the tv off and press..
info>menu>mute>power on
and go to the reset option. don't mess with any other setting in this engineer menu.
Posted on Apr 16, 2008
SOURCE: need help
ensure the tv is in analogue mode, not dtv and turn it off. with the remote: press info then, menu, then mute then power. these buttons need to be pressed sequentially not all at the same time and in quick succession. a menu will appear on the tv. navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button) the tv will reset itself and turn off. turn the tv back on & it'll re tune all its channels. DTV should be working again.
Posted on Mar 28, 2009
57 varieties
  • 1653 Answers
SOURCE: 'satellite' icon not available to retune digital channels
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Posted on Oct 02, 2009
57 varieties
  • 1653 Answers
SOURCE: samsung le26r74bd won't retune digital channels
Olevia 537-B11. Why is there a blue screen with a "no signal" message?
try main menu look for input should be Air (antenna) ,cable, av1, av2, hdmi1, hdmi2 and perhaps more. do an automatic channel scan if you have an antenna hooked up. will take several minutes scanning
Oct 09, 2015 | Televison & Video
I have connected the audio optical cable from my TV, but I couldn't get the koss system to work. Are there any other settings need to be set? Which channel should i use to get the sound AV1 or AV2?
AV1 & AV2 are the Video Inputs from your external devices such as DVD Player, Freeview etc.
I presume you have something connected to your TV and want to get this sound from your TV to output through your Koss.
Their should be a menu to activate the Optical Input but I can't find the manual to advise the correct menu.
I'll keep looking for a manual so if you can't find the menu let me know and I'll see what I can do to guide you in the right direction.
Jul 25, 2011 | Koss KS5190 System
Cannot access 'channel'' menu in samsung DTV menu to carry out retune. The menu jumps from 'sound' to 'setup', the 'channel' icon is greyed out and cannot be accessed.
This is becouse you had done some Channel Child Lock first open all child lock than try to tune channel.Or possible that you are in some other input mode.select TV mode than you can try.
Jan 22, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
What input or channel does my samsung plasma tv need to be on to play the nintendo wii
If you have the AV inputs, use them. Use AV1, not AV2.
(If you use the AV2 input, there might be action delay between the controllers and the Wii.)
If you don't, just select VIDEO 2.
Dec 26, 2009 | Nintendo Wii Console
When I try to set our TV to locate digital channels, the menu skips the channel selection when I scroll through options of picture, audio, channel, lock, setup. All the options are available.
It sounds like your TV is on a different input. If you watch your cable from an external cable box, and this box is plugged into your TV using wires that are yellow, red, and white, or red, blue, green, red and white, you're currently watching TV on a different input than the one used for the antenna. Channels in a TV are controlled by the tuner. The tuner is the silver, threaded, post on the back of a TV, DVR, converter box, or VCR, that you plug an antenna or cable wire to. The tuner contols channels while the other inputs on your TV carry a direct signal like a computer to a monitor. So when you use something other than coaxial cable to connect cable to your TV, you can't access the channel menu while on that input. To access that menu, change the TV's input or source to TV or stop when you see a channel number on the screen. You have to be on the TV or tuner input in order to access the channel menu. If you're on any other input such as, S-Video, AV1, AV2, component (Yp Br Cr), HDMI, etc. you will not be able to do a channel scan. You have to be on the right input or source.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 27, 2009 | Televison & Video
Input Problem
Mine was the same, except i also could not access HD Components.
Unfortunately i had to get some one in, as the circuit board at the back of the tv was burnt out.You might have to get a technician in to service and replace the burnt circuit board.
Jan 16, 2009 | LG 50PX5D 50 in. Plasma HDTV
RCA F32450 TV can not get the TV to display the DVD menu
You can get a remote from Electronicadventure.us for $29.95. The remote number you are looking for is RCA-GE-PROSCAN 242524
Nov 15, 2008 | RCA F32650 32" TV
Can't switch from AV2 to AV1 with Samsung DVD-VR375 DVD Recorder / VCR Combo
To be able to select AV1, you have to first go into the setup menu and set the control set top box setting to OFF. I think you go to the menu >> setup >> features >> set top box control >> select OFF. Note that this has the side effect of erasing any previously stored timer settings.
Sep 05, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
Samsung PN42A450 Plasma TV Logo
398 people viewed this question
Jerry Greenberg
Jerry Greenberg
