Question about Microsoft Visual FoxPro Professional Edition 7.0 for PC
Can we using Visual FoxPro commands to convert our database to mdb.... if we can, whats this command
I need visual foxpro converting tool available
Posted on Jan 07, 2013
  • aniruddh Jan 07, 2013
2 Suggested Answers
  • 401 Answers
SOURCE: visual foxpro to access
I have many friends and one of them had problem with dbf file, but I advised him a tool, which relieved him and probably might aid in this issue also - dbf recover.
Posted on Dec 25, 2010
Database file appears corrupt: Page is of wrong type
At the start you could try have an environment under which the table is NOT validated when it is opened. This can be achieved with the command -
SET TABLEVALIDATE TO 0
0 being - Do not perform table validation.
Now the table can be opened, you need to reset the header record count to the correct value.
If it doesn`t work, you may recover it with help of third-party program, for instance Recovery Toolbox for DBF https://dbf.recoverytoolbox.com/
Feb 03, 2015 | Microsoft Visual FoxPro 9.0 Professional...
How to add a picture in a field in Visual foxpro. I could do it earlier in Foxpro for Windows with the APPEND GENERAL command but now it only saves the filename and not the actual picture. Please help.
The type of the field should be GENERAL.
Try this command: APPEND GENERAL <fld_name> FROM <url_file>
For example: APPEND GENERAL my_gral_fld FROM 'c:\my_file.jpg'
Jan 11, 2011 | Microsoft Visual FoxPro Professional...
HOW TO SOLVE VFP FILE CURRUPT WHEN POWER FAILURE
At times, you may view that your MS Visual FoxPro 9.0 database is behaving abnormally. Some of the abnormal symptoms could be an error message while opening any database table, invalid characters in place of pre-defined values, and and more. The main reason for abnormal behavior of the database is its corruption due some logical crash. Few common reasons for corruption of MS Visual FoxPro 9.0 database are abnormal termination, faulty network devices, simultaneous modifications, conflicting third-party software, and incompatible service packs.
To overcome such database corruption scenarios, the user can use an up-to-date backup and perform restoration. However, restoration fails in cases where the user either forgets to create a database or the database backup itself gets damaged. In such cases, the database users can use a third-party DBF File Repair application to repair his/her corrupted database.
To illustrate the above case, consider a real-time scenario wherein you execute a query to modify your MS Visual FoxPro 9.0 database. While the query was performing the modification, the system shutdown due to power failure. However, the next time you tried to mount the database, you encountered an error message that did not allow you to access the database records. Moreover, the same error message appears every time you try to access the database.
Cause:
The root cause for the error message is MS Visual FoxPro 9.0 database corruption due to improper system shutdown.
Resolution:
The database corruption error message can be surmounted by following the below steps:
Use a complete database backup and perform restoration. However, in case of database backup unavailability, you will need to search for a commercial DBF File Repair utility.
A third-party DBF Repair application uses effective repair techniques to repair logically damaged MS Visual FoxPro 9.0 database and restore it at a new and safe location. The original database during the repair process remains intact. The tool is easy-to-understand and allows even a non-technical person to perform repair.
DBF Recovery Software is a comprehensive solution to repair databases created in MS Visual FoxPro 9.0, MS Visual FoxPro 8.0, and MS Visual FoxPro 7.0. The tool also repairs databases built in dBase III, dBase IV, and dBase V. Supported by Windows 7, Vista, 2003, XP, and 2000, the DBF Repair tool creates a new repaired file that can be attached to existing database.
Tanvi Sharma is a self employed Internet entrepreneur and product reviewer. This DBF Repair utility is extremely useful when the dBase and Foxpro database gets corrupted due to internal program errors, hardware malfunctioning, accidental deletion of data and more. This DBF Repair software repairs all types of database components including table name, column name, column data type, indexes and primary keys.
May 31, 2010 | Microsoft Visual FoxPro Professional...
Foxpro 2.5 Application can't direct print in xp cause in my print Dot Matrix with Epson LQ-2180 using USB to Pararel Port...
share the printer then search for your own computer and you should be able to open it and see the shared printer like. \\server\printer
then use net use command...
net use lpt2: \\server\printer /Persistent:yes
then tell foxpro to print out lpt2 and it will act like dos
you can add net use command to autoexec.bat or windows startup if you will do this often
Nov 08, 2009 | Electronics - Others
Convert my database from dpf to mdb
Use access to import external data. It can read dbf and create mdb
Jan 06, 2009 | Microsoft Visual FoxPro Professional...
Visual foxpro to access
hi
you need to use a ODBC conexion to trasport your tables into table .dbf in fox
or
you need to copy tur tables to excel documents an then import in vfp
bye
Jan 05, 2009 | Microsoft Visual FoxPro Professional...
Create access mdb file by vfp code
Try this
#define dbLogical 1
#define dbNumber 2
#define dbInteger 3
#define dbLongInteger 4
#define dbCurrency 5
#define dbSingle 6
#define dbDouble 7
#define dbDateTime 8
#define dbBinary 9
#define dbText 10
#define dbOLEObject 11
#define dbMemo 12
#define dbReplication 15
#define dbDecimal 16
if file("C:\accesstest.mdb")
delete file c:\accesstest.mdb
endif
public oAccess
oAccess = createobject("Access.application")
oAccess.visible= .t.
newMDB = oAccess.NewCurrentDatabase("C:\accesstest")
newtable = oAccess.CurrentDb.CreateTableDef('testtable')
with newtable
.fields.append(.CreateField("Field1", dbLogical))
.fields.append(.CreateField("Field2", dbNumber))
.fields.append(.CreateField("Field3", dbInteger))
endwith
oAccess.CurrentDb.TableDefs.append( newtable)
dbc2Convert = "\\tpdfiles\data\dfreeman\tip\data\rta\rta"
open database (dbc2convert)
dbgetprop(rta,"table",)
After it runs you will need to close the MDB and reopen it.
Oct 15, 2008 | Microsoft Computers & Internet
Make Softwere
hi
am programer in vfp9.0 you need to download manuals and examples
y have many
Apr 24, 2008 | Microsoft Visual FoxPro 9.0 Professional...
Visual foxpro
there can be some setting .by which it can be ....
Mar 10, 2008 | Computers & Internet
Microsoft Visual FoxPro Professional Edition 7.0 for PC Logo
135 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
