Question about Acer AL1717 17" LCD Monitor
It is all black, as if off
When computer is turned on it shows the windows logo. Then imediatly goes black, and displays a box stating input not supported ....It was working fine last evening.
  • wrongway5420 Jan 05, 2009
    I will definitly try this solution as soon as someone can help me. Thank you very much
  • 33 Answers
When starting windows press f8 key before the windows logo shows up > go to safe mode > click start>control panel> display>adapter>list all modes> choose 800x600 x 16 colours > apply > close > reboot to normal xp. OR When f8 key pressed > choose VGA mode. If this does not work then change the VGA Cable (borrow from someone if its TFT to test)
Posted on Jan 05, 2009
My Acer aspire turns on shows windows logo then goes to black screen, what can I do?
Depending on your version of windows, I would trying starting in safe mode to see if the computer does boot. If it does, then you want to restart again, go to advanced boot options and select "start windows with last known good configuration." Access advanced boot options following the steps at this link. Need to Start Windows 7 in Safe Mode Here How
Jul 18, 2015 | Acer Computers & Internet
I have a Polaroid TLX-04240B It comes on and Displays the Polaroid logo, then it goes to a black screen with the HDMI1 input box on the top right hand corner. THis box eventually disappears, leaving me...
Buy another HDMI cable.Try another HDMI cable with another HDMI hub on the tv port.If u still have the same problems,mean the whole main tv Tuner signal board have problems and the caused.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv Tuner signal board for the replacement.
May 19, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
All of a sudden, the screen display went black. When we restart the computer (Windows XP), we see the initial windows logo but nothing else -- EXCEPT, pressing and holding the screen's "INPUT...
Very doubtful. Either you have a defective or corrupt display driver, or possibly a malware infection. Is that a laptop or notebook computer? If so, is there a VGA port for an external monitor? If do, try using a known good external monitor.
Apr 28, 2017 | Sony SDM-HS74P/S 17" LCD Monitor
The screen goes very dark within a minute after booting up = I can just barely see the menu page
When you say screen goes very dark when it booted to windows so it means that when you turned on the laptop when the dell logo flashes the screen was fine? if thats the case could you please try this. after turning on the laptop you will see the dell logo flashes immediately keep tapping on F2 and then it will show you the BIOS setup utility, please check if in BIOS setup display goes dark as well. If yes then try this, after turning on the computer when dell logo flashes keep tapping on F12 to boot menu then select utility partition to run the diagnostics. Please run test on the LCD check if display goes black when running the LCD test. Then try this when you sees the dell logo keep tapping on F8 to boot in safe mode check if in safe mode display goes very dark. Try this too, boot in F8 then select last known good configuration check if the settings on your display will be fix. If you can boot to safe mode no problem then uninstall the display or video driver. then restart computer.
You can also try to connect an external monitor if you have one just try to isolate if issue is on the LCD or the video card. If the display is dark as well in external monitor then video card needs to be reseated if fails then replaced. In situation like this most video cards is integrated to the motherboards. So replace motherboard.
Dec 08, 2009 | Dell Inspiron 2200 Notebook
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Westinghouse LCM22W2 shows a display then turns off after half a second
I have the same problem and have traced it down to a potential power supply issue.  I bought mine at Best Buy in '06 and was told today that they will test the power supply for free.  It may range from $50.00 to $100.00 depending on where you can get it.  This does not include labor for those not qualified to work with electronics.  Hope this helps you.
Aug 13, 2008 | Westinghouse LCM-22w2 Television
Computer problem
may be u have problem with the display driver or u have a corrupted windows xp try to run the windows in "ENABLE VGA MODE" if it works fine then just reset the display settings else u have to try to repair / reinstall winxp
mai me ur response @ vishwas_4u@rediffmail.com
May 01, 2008 | Compaq Evo N610C Notebook
Acer AL1717 17" LCD Monitor Logo
183 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
