Question about Culligan Measuring Tools & Sensors
Culligan Water softener Model WG2169
Need operating manual
BillB-SA
  • 2761 Answers
SOURCE: I NEED A SERVICE MANUAL FOR MY CULLIGAN WATER
Your best course of action is to contact Culligan here:
http://www.culligan-store.com/contact.asp
Posted on Nov 15, 2009
  • 175 Answers
SOURCE: No salt leaving Culligan softener during regen
It sounds like your salt in your salt compartment is stuck. Poor about a couple of gallons of hot water on top of your salt and see if that will break it up and fall down to the bottom of your salt container. Then regenerate your softener after about 3 hours have gone by. You should be back in business.
Posted on Nov 20, 2009
SOURCE: I have a culligan,gold series water softener.The
call your culligan service department. they will tell you what to look for.
Posted on Dec 22, 2009
  • 8 Answers
SOURCE: water softener is inoperative and is displaying E1
Usually, an E1 error code means the circuit board is bad. Try unplugging the unit for 5 minutes. Upon plugging it back in, if it does not reset itself, that means you need a new board. It is really easy to replace ( just a few wires) and will cost around $160.
Posted on Jul 21, 2010
h2oservices
  • 306 Answers
SOURCE: I have a Culligan water softener and noticed
There is a problem with the piston/seal pack assembly pack in the valve. The seals get worn or some debris gets stuck and causes softener to run to the drain. The seal pack assembly needs to be replaced. If you are handy, you can do this. It takes about 1/2 hour for a novice.
Parts are only available from Culligan.
RJ
Posted on Jul 03, 2011
My softener is a Culligan Mark 89. Water looks clear but is real salty. I bypassed the system and purged the lines to get rid of the taste.
Call Culligan for service. You have a serious problem as it sounds like your resin bed is not going through the backwash cycle before returning to operate mode.
Normally when your water softener goes through a recharge cycle, a solenoid operates to bypass the system while brine (extremely salty water) is drawn into the resin tank to perform the ion exchange process. This is a timed process. Once it completes then your softener switches into backwash mode where the resin bed is flushed with clear water. Finally at the end of the recharge cycle the softner switches back into normal operation.
This is not something that you can fix yourself. Contact Culligan immediately.
Nov 01, 2014 | Measuring Tools & Sensors
WHERE IS OUR SOFT WATER!? A few years back we had the Culligan man out to check our water because it was not soft (at the time, we had the Culligan Mark 100 model). After testing our water, the suggested...
The most frequent causes for intermittent hard water would be the gallon settings set too low causing the softener to run out of capacity or a meter that is not measuring the gallons. I would set the "hardness" setting on your culligan softener 30% higher than actual hardness. The softening resins they use are low in crosslink and very inefficient. Also make sure there are no toilets leaking causing hard water to "bleed" through softener. Iron filters require regular maintenance to clear oxidized iron from nozzles and the valve. Generally it is better to have the iron filter regenerate at least every 3 days to keep the bed refreshed.
RJ
Mar 01, 2012 | Culligan Sediment Water Filter
Need to reset auto timer for back flushing for culligan model # FA-1054 would like online manual
That model # does not work. 10x54 denotes the size of the tank. Is this a Gold Series, Medallist?
Softener, Filter?
RJ
May 30, 2011 | Culligan 34" Whole House Water Filter...
Have a water filter by culligan ..a 01014042 ser # 0703k0196 need a user manual
This is a Medallist series water softener. Her is the link to Culligan for your owners manual.
http://www.culliganwater.com/residential/resources/timers_manuals.php
For future reference it is more helpful to provide the Model and the year it was installed.
RJ
Sep 09, 2010 | Culligan Sediment Water Filter
Culligan 01010091 (mark 89) softener will not auto
clean the drainage filter then it will work correctly again
Mar 05, 2010 | Culligan Sediment Water Filter
I NEED A SERVICE MANUAL FOR MY CULLIGAN WATER SOFTENER. MODEL# 01014556 SERIAL# 2903H0010
Nov 15, 2009 | Culligan Sediment Water Filter
Manual
May I get the model # to help you more
Feb 12, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Measuring Tools & Sensors Logo
164 people viewed this question
Top Culligan Measuring Tools & Sensors Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Culligan Measuring Tool and Sensor Expert? Answer questions, earn points and help others
