Question about Brother DCP-7040 Laser Printer
How do you print from brother DCP -7040 for the iPad?
komguy
  • 2306 Answers
SOURCE: Toner Life End message on DCP-7040
If your cartridge has a lever on the left side near the rear, it needs to be reset, and there's a lever inside on the left that can stick and cause that error. You need to wiggle and pull that lever until it moves freely again.
Posted on Jan 04, 2010
komguy
  • 2306 Answers
SOURCE: how to check the toner level of Brother printer
It has no accurate measure of the toner left, it is reset when you put in a fresh toner and just counts prints. The Brother shines a light thru a little window from right to left and when the toner is empty the light shines thru and it says it's empty.
Posted on Jan 13, 2010
Testimonial: "Right to the point. Thank you."
  • 159 Answers
SOURCE: I have a DCP-7040 Brother Laser printer. I am
Two likely possibilities:
1. The drum is scratched by particles caught under the drum cleaning blade. Every copier or printer that has a drum leaves a little bit of toner on the drum that didn't get transferred to the paper. A soft plastic blade scrapes off that excess. If a chunk of fused toner or something gets caught under it, it can scrape a groove around the drum, resulting in a black line. Take a close look at the drum for scratches matching the lines you get. The cure is a new drum unit.
2. The fuser roller is scratched. Open up the back of the printer. The fuser is the assembly with labels warning about how hot it is. The final stage of the print process is to press the page between those two hot rollers, melting the toner into the paper. The hot roller is coated with Teflon to prevent pulling toner off the page and laying it back down where it doesn't belong, but like the drum, it can be scratched. You might be able to look for scratches on the hot roller with the help of a strong flashlight and magnifier. If it's scratched, you need a new hot roller or a complete new fuser.
Let us know what you find.
Posted on Apr 21, 2010
funkyagain
  • 24 Answers
SOURCE: Brother Toner Refills
Yeah you can refill your cartridge. It is really easy and consists of removing the plug on the side of the cartridge, dumping out any old toner and dumping in the new toner. Its very easy. I have purchased refill kits from both of these sites in the past and its worked great:
www.tonerrefillstore.com
www.lasertekservices.com
They also have great customer service. I hope this helps!
Posted on Apr 30, 2010
vickyakon11
  • 68 Answers
SOURCE: brother dcp-145c blocked ink jets
http://welcome.solutions.brother.com/bsc/public/eu/gb/en/doc/manual_top.html?reg=eu&c=gb&lang=en&prod=dcp145c_eu_as
from this link u will download the manuals and drivers then i think it will start working................good day sir
Posted on Aug 02, 2010
Brother dcp 7040 prints and then prints too light
Before refilling, clean entire cartridge units. Remote its cleaning blade and clean it with an IP solutions and make sure no bends in cleaning blade. Do not mix new toner powder with old one. Also clean plastic portion below the developer roller also. Then the same complaint found, clean the LSU unit of the machine. Now it work properly.
Feb 10, 2015 | Brother DCP-7040 Laser Printer
Dcp-7040 printing too light
check powder , control panel , check printing faults .
Jul 19, 2014 | Brother DCP-7040 Laser Printer
Brother DCP-7040 Laser Printer Issue
With the computer off will the printer still make a copy? If the printer can still make a copy stand alone, then try deleteing the printer and reinstalling the printer driver.
Mar 31, 2014 | Brother DCP-7040 Laser Printer
Brother dcp 7040 prints grey film over the page
someone cheaped out and got the el cheapo paper.
The low quality paper has paper dust on every page....
when the printer feeds this cheap paper thru the machine it drops the dust onto the tonor cartridge rollers and causes the roller to accumulate toner on the roller... this in turn is transfered to the pages being printed.
check your machines operation manual. There may be a clean cycle you can try to run to clean the rollers...
I had to buy a new toner cartridge for mine when this happened.
Apr 17, 2013 | Brother DCP-7040 Laser Multifunction...
THE DVD ROM OF MY PC WAS DAMAGE AND I CANNOT INSTALL THE DRIVERS OF DCP 7040 WHAT SHOULD I DO SO THAT I CAN PRINT THE DOCUMENT FROM MY PC TO DCP?
Hi there!
You can download the software & drivers from this website:
http://welcome.solutions.brother.com/bsc/public/us/ca/en/dlf/download_top.html?reg=us&c=ca&lang=en&prod=dcp7040_us_as
After downloading you just have to install it to your computer. Before installing it you have to make sure the printer is turned OFF and the cable is not connected.
Hope this helps, Thumbs up if it does, Thanks!
May 05, 2011 | Brother DCP-7040 Laser Printer
How to use in print this scanner dcp7030,dcp 7040?
Hello, it looks like you are wondering how do you print with it? When you bought it did it come with a cd? Thats the setup cd for your PC. Just load it into the cd drive in your PC and follow the instructions. You should have no trouble in setting it up. If you didnt get the cd or youve lost it, just download it from the internet. Hope that helps.
Mar 29, 2011 | Brother DCP-7040 Laser Printer
My Brother DCP 7040 printer can only print 1 copy... even if input request to print multiple copies of something
I've had the same problem with my Brother MFC-9440CN and XP Pro.
Try changing Printer properties (Control Panel\Printers) and click Advanced\Printer Processor button. Here you can try to change Printer processor: WinPrint, ModiPrint, hpzpplhn, LMPRTPRC.
I solved my problem choosing hpzpplhn (RAW).You can also try to deactivate 'Enable advanced printing features' in the printer, advanced, properties...
Feb 18, 2010 | Brother DCP-7040 Laser Printer
How to check the toner level of Brother printer
Jan 13, 2010 | Brother DCP-7040 Laser Printer
Brother DCP-7040 Laser Printer Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
