Power light comes on keeps beeping wont fill or start prgramme
SOURCE: I need an operation manual for a proline logic
www.espares.co.uk/usermanuals.aspx?c=1084&ma=1169&mo=451471&sa=1 - 50k - Cached - Similar pages
www.howtomendit.com/answers.php?id=196053 - 58k - Cached - Similar pages
OR CONTACT THE COMPANY DIRECTLY AND ORDER ONE
SOURCE: Kenwood Slimline Dishwasher KDW8ST2A
I have a Kenwood Kdw8st2a and have been constantly plagued by the E4 overfill error.
Lifting the front of the dishwasher and tilting it backwards seemed to clear the E4 error only for it to come back after the next wash.
I found eventually that the connection to the U bend under the sink was too narrow and was almost blocked hence the dishwasher was not emptying properly.
I disconnected the dishwasher waste pipe and ran the waste into a bucket for about 6 cycles and it worked fine.
Eventually drilled through the kitchen wall and fitted a lower direct waste pipe to the drain. Overkill maybe buit it hasn't done an E4 since.
SOURCE: wont go on to programme when switched on starts
Check that you have tuned on the inlet water tap(faucet usa).
SOURCE: After selecting a program, the
Basically the dishwasher is telling you there is a fault - Not so useful I know! Plug out the machine and leave it for five minutes and see will it reset. If that does not work, you will need to reset it manually. To do this consult the manual. If you don't have a manual, go to http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do and down load one. Good luck!
