Question about Exercise & Fitness
Ac adapter for champion c84e elliptical trainer
SOURCE: I am looking for an owner's manual for the Champion Elliptical
Did you find a manual? I have the same problem.
Thanks.
Posted on Oct 28, 2009
SOURCE: what is the output of the ac adapter for the
It should be at the bottom of the machine in the front facing away from you if you are on it.
Posted on Nov 12, 2010
  • 28 Answers
SOURCE: What is an elliptical trainer?
An elliptical trainer or cross-trainer is a stationaryexercise machine used to simulate stair climbing, walking, or running withoutcausing excessive pressure to the knees.
Posted on Jul 09, 2012
SOURCE: How many calories can I burn on an elliptical trainer machine?
how many calories you burn depends
a) on your weight
b) on the exercise speed
c) on the exercise level
d) as a combination of all factors on your heart rate
For example, I at 80kg usually do about 400 cal in 27 minutes @138 heartrate :-)
Posted on Jul 23, 2012
  • 28 Answers
SOURCE: How do I clean my elliptical trainer?
You will notice that dirt accumulates on both the wheels and track. First, I suggest reading you user manual. To avoid dirt build-ups, I recommend wiping the machine after each use. This is not instead of a cleaning, but will limit the time you spend cleaning the machine. If your manual is not helpful, I found a great article called "Keeping Your Elliptical Machine Clean" - this should help.
http://www.abcarticledirectory.com/Article/-Keeping-Your-Elliptical-Machine-Clean-/896160
Posted on Aug 02, 2012
Why is the Precor AMT 100i Adaptive Motion Trainer Elliptical primary belt making noise and should I adjust it?
SOmetimes belts make noise when they are worn out and need to be replaced - belts like that are considered 'wear' items, like tires on a car - they have a very limited lifespan compared to the other parts.
Jun 18, 2014 | Precor AMT 100i Adaptive Motion Trainer...
What voltage does this model run on,24volts?
The details regarding volts current etc should be in the back of your manual
Jun 17, 2014 | Exercise & Fitness
Will using an elliptical trainer hurt my knees?
Quite the opposite. Elliptical trainers are great for people with knee injuries. Elliptical trainers limit the strain on your knees because it is a non-impact machine.
Aug 02, 2012 | Exercise & Fitness
Just got used champion c84e...how does computer work..should there be an electrical cord?
There is no electrical cord for this elliptical. It is powered by the runners motion. If the computer doesn't turn on when you start running, check the connections underneath it. If they are tight, you may need to replace the fuse. If after replacing the fuse and it still doesn't work, the computer may be broken.
Mar 06, 2011 | Computers & Internet
What is the output of the ac adapter for the schwinn 430 elliptical???
Nov 02, 2010 | Schwinn 430 Elliptical Trainer
I have an Eliptical Trainer BY-430E. I keep getting Error 1 every time I turn it on to use it. Does anybody know how this can be repaired. Thanks in advance
Error 1 on a schwinn is a generic electrical error. Check your ac adapter and make sure you're getting the proper voltage off of it. Typically an error 1 warrants a replacement of either the ac adapter, the wire harness (wires that connect the power to the console) or the console itself. If the console has batteries, change those first, then check your adapter. If the problem persists, you're looking at a more in depth problem that will require taking the casing off the machine and individually testing each component of the machine. It's usually worth at that point to pay a tech to look at the machine for you.
Jun 28, 2010 | Schwinn 430 Elliptical Trainer
Thanks.
Aug 22, 2009 | Exercise & Fitness
Exercise & Fitness Logo
360 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
