Question about Teac Audio Players & Recorders
Teac lp- u200 cd player doesn't work
I just bought new lpu200, but cd player doesn't work, i put disk in, according to instruction, but i can see only blinking word ''reading...'' forever, no info about my cd (how many songs, how many paths...) on the screen, no sound of music, i tried different cd,all of them playing well someplace else, but not on this lpu200, if i try lpu200 as radio, i do, have sound.
  • Anonymous Mar 31, 2014
    CD player spins very fast and doesn't slow to play CD. Display light in square box out but 4 button lights below work.
  • 4,234 Answers
Sicne this is a new system, don't waste time on it. Return it for an exchange. The CD portion is not working. The reading message indicates that the unit detects a disc, but can not read it. This is usually a problem with the optical assembly or the processing board. Neither should be a problem at this time. Replace it under warranty.
Dan
Posted on Jan 05, 2009
Which fuse is it to take out if the cd player reads unreadable disk for any cd I put in...2006 Hyundai sonata...
Kirk, I am not aware of any fuse to remove to make player work. Try cleaning the lazer/head. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CD player doesn read disc
2007 Sonata Ltd CD player won read discs
How to Fix Car CD Player
May 19, 2016 | Hyundai Cars & Trucks
Brand new LPU 190 Teac hooked up to my computer but it won't playBrand New comp windows 8
if its brand new check your warranty papers for a number to customer service they could talk you thru it
Sep 20, 2013 | Teac LPU200 Turntable
I have TEAC LP-R500 Rec LPtoCD ?set tracks record 2 side of album
It may have recorded but in order for you to see it the disc needs to be finalized. This is when the TOC- Table of Contents is written and when the files/track show up.
Dec 20, 2012 | Audio Players & Recorders
I have a Teac LP200 and the turntable will no longer turn when I lift and move the arm over. Is there a belt to replace? How does one access it?
your unit has "The efficient belt-drive system provides accurate play and control" and normally the belt lasts for long time ..i.e at least 5 years..
If you sure that it is belt ,you need to take the turntable disc (should be a security pin in the middle ) than you can access underneath of disc or some models needs to access from bottom of the turntable ,inside the receiver..
just in case ,if you need detailed user manual in pdf format pls visit he URL below..
Hope this helps! Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
User Guide for Teac LP-U200 View Table Of Contents»
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Jun 25, 2011 | Teac LPU200 Turntable
Cd x-9 teac will load cd spin but not play lcd reading says 'no cd'
If this problem occurs only at this cd/dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alcohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case you can, use a Q-tip with isopropyl alcohol to clean up the cd lens manually. In case this doesn’t solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 14, 2010 | Audio Players & Recorders
NEED TO FORMAT MY SD CARD ON MY TEAC LP-U200
I'm not familiar with this device, but if the SD card is REMOVABLE, you can try putting it in a digital camera (that supports SD cards) and format it using it, OR use an adapter (or a built-in slot if you have) and connect it to a computer, then simply format it by right-clicking on it's icon in My Computer and selecting "Format".
Mar 13, 2010 | Teac LP-U200 Shelf System
CD player won't play disk and says "no disk"
The problem of "'no discs'"displayed is in the mechanism in the roller thats moving back and port bringing the lense set .The old grease thier is already hardened that cause the problem.Clean that by using a lighter fluid or like that fluid to take the old grease,and put it with a new one first class grease type-A grease put only a little grease and wipe the lense with a cotton buds without any chemicals on it .Try this solution so performance will be better.
Jun 18, 2008 | Teac CD-P1250 CD Player
Questions
Swop the CDR into the tape outputs on the amp and use it just like the tape recorder you had hooked up. Also do a direct digital link to a CD player for digital copies.
Aug 18, 2007 | Teac CD-RW880 CD Player / Recorder
400 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
