Question about Elna 3210 Mechanical Sewing Machine
How do I remove the face plate from my Elna 3210 to change the light bulb?
I have removed the screw, and the instructions say Remove the face plate, but it wont budge, I don't want to snap it!
  • Enid Tremear
    Enid Tremear Dec 02, 2013
    help, cannot do it either!! Any suggestions........
SOURCE: I need to replace the light bulb on my Elna SU 62C
Switch power off first. On the top left hand side of the machine towards the front is a small hole. Insert small screwdriver in hole and push down. The light bulb will appear underneath just to the left of the presser foot. Whilst holding down the screwdriver firmly, turn bulb anti-clockwise pushing slightly upwards at the same time. Bulb should dislodge.
Posted on Mar 07, 2010
Tally Girl
  • 1125 Answers
SOURCE: Elna Supermatic 1960's/cream and blue.
There may be threads jammed up in the bobbin holder area causing the jam. But removing the inner bobbin holder is a bit tricky if you haven't done it before. There are two little screws holding the silver inner down onto a black ceramic piece (inner guard ring), and you need to get these lined up the right way to get the bobbin holder back into position afterwards.
I would suggest that you join the Yahoo group Elna Heirlooms, then check out the files and photos loaded up by other members who work on their Elnas.
You shouldn't need to remove the feed dogs, just give them a clean with a little brush. But internally the machine may need a good clean and lube and without a service manual or good guide this can be challenging.
If you go this link http://www.arizonaexpressionz.com/elna_service_manuals.html you can down load the manual for this machine, the Star Series SU. Go to page 7 of the first part to see about removing the bobbin holder and inner guard ring.
It is a case of lining up the cut out of the black plate to the front, then putting the bobbin holder on top with the little arms facing front also, then replacing the two screws.
I'd suggest you take photos with a digital camera before you start to help you get it back in the right way.
I hope this helps you with the Supermatic, did you get the discs and accessories with it too? lovely Swiss quality machine with great stitching so if you can't get it unjammed, you may wish to find an experienced Elna Technician to take a look.
White Sewing Center stock lots of parts for these machines too, www.whitesewingcenter.com
Posted on Jun 19, 2011
Tally Girl
  • 1125 Answers
SOURCE: Elna 683 overlocker spare parts
I can see a needle plate
http://www.sewingpartsonline.com/needle-plate-janome-788601007.aspx
from sewingpartsonline.com, but it is marked as being for Elna 664. They don't have your model listed on their website.
You could email them and ask if its compatible with your model or just look at the part and see if it looks the same to you?
Other option is to contact Elna head Office in your country and ask them for price and availability; often this is best course of action as any sewing machine dealer will probably need to order in the part anyway.
Visit www.elna.com, then go to your country, then "Contact Us" page to find their contact details.
Hope this helps you get the overlocker going again.
Posted on Nov 07, 2011
SOURCE: I have a Elna 344 serger. The stitch finger has
check with sewvacdoctor.com
Posted on Feb 20, 2012
SOURCE: How to remove the Elna needle plate?
very gently use a butter knife or a flat screw driver to try & lift up the needle plate, do not use a lot of force
Posted on May 30, 2012
How to remove the bulb fro my jamone J3 18
  • Power off - unplug
    • Allow bulb to cool a few minutes
  • Left side of machine
  • With small screw driver, carefully Pry off/Remove the cap and the screw. Remove the face plate.
    Keep the 3 parts to replace = Cap, Screw, Face plate
    Push and turn the bulb counterclockwise to remove the bulb.
    Push and turn the bulb clockwise to reinsert new Light bulb
Apr 19, 2015 | Janome Sewing Machines
Change bulb elna 6003q
removed plastic plug (with a small screw driver,so the plastic plug
does not get damaged) on the side of the face plate
carefully removed screw behind plug--be sure not to strip the screw head
carefully pull or wiggle loose plastic cover until it comes off
giving access to bulb.
Jun 03, 2012 | Elna Quilter's Dream 6003Q
May 29, 2012 | Elna Sewing Machines
Hello, I need to replace my light bulb. How do I remove the face plate?
the face plate either has hinges at the back so you gently pull on it to open
or there is a plug with a hidden screw,,carefully use a screw driver to get the plug out & then remove the screw & take off the door & change the bulb
Nov 23, 2010 | Janome 6019QC Mechanical Sewing Machine
How do i open the side door on my janome 1018s where the neddles and light is
On some sewing machine the door is called Lamp Cover Door & has a hinge at the back of the door,, gently pull toward the back of the machine to open the door & the light bulb should be easy to get to.
Some are called Face Plate-there should be a plug in the middle of the door-remove gently with a small screw driver- there should be a small screw to remove-the door should come off easily--change bulb--replace screw-replace plug
Oct 07, 2010 | Janome Memory Craft 10000
Need to change light bulb
some machines it's called the lamp cover door --these machine have a hinge at the back, carefully pull the door toward the back of the machine & it should open to show the bulb
some machines call it the face plate--there is a hidden screw under a plastic plug, gently pry the plug with a screw driver & then take the screw out, & remove the plate & the bulb should be easy to replace,just put the plate back on after changing the bulb & replace the screw & plug
happy sewing
Sep 30, 2010 | Husqvarna Huskystar 207 Sewing Machine
I have an Elna 6003Q sewing machine. My light bulb went out and I need to replace it. How do you get it out and replace it?
some call it a lamp cover door or face plate it's on the left side of the sewing machine
some sewing machines have a hinge at the back of the face plate, you can gently pull it open to change the bulb
some machines -in the middle of the face plate there is a plastic plug, use a screw driver to gently lift the plug & then unscrew the screw & change the bulb.put the face plate back on put the srew back in & put the plug back in to concile the screw
Sep 27, 2010 | Elna 2007 Mechanical Sewing Machine
HOw do I change the light bulb?
on the left hand side of the sewing machine is the lamp cover door( face plate)
some have a hinge on the back & they just pull open
others have a hidden screw(there a tab you have to remove with a screw driver) then just unscrew the screw & take off the face plate & change the bulb
don't loose the tab or the screw
Aug 31, 2010 | Kenmore 11101 Mechanical Sewing Machine
Elna carina how to remove light bulb
There is a small hole on the left side of the top of the machine. Using a thin rod such as the L shaped edge guide that came with the accessories, push down in the hole and the lamp socket (which is spring loaded) will go down to allow you to grasp the bulb. Replace it with a similar long bulb available at any sewing machine repair shop.
Jan 09, 2010 | Elna Sewing Machines
Cannot get to the lightbulb on an Elna SU sewing machine to chang
On the left hand side of the machine on the end cap.
Changing the Light Bulb
The sewing light is located behind the face plate.
UNPLUG THE MACHINE. Wait until the bulb is COOL before you touch it!
1 2 3 Remove screw cap , screw and face plate .
To remove: pull out bulb from socket.
To replace: insert bulb into socket.
Attach face plate and insert screw and screw cap.
NOTE: Replace bulb with same type rated 12V, 5W.
I hope this helps. Don't forget to rate my answer.
Jan 31, 2009 | Elna 2007 Mechanical Sewing Machine
Elna 3210 Mechanical Sewing Machine Logo
66 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Derek Massey
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
