Question about Waterway Pool & Spa
Connection wires plan for a waterway 1 1/2 model sd-15-1a11d5
The rirght way to replace connection wire from on off switch to pump motor
KMusselmann
  • 247 Answers
SOURCE: got a waterway 1.5 hp 1 speed 115/230v, wired 115 need 230
Is there a coverplate where the wires come out of the pump? If so, remove the plate and there should be a wiring diagram inside.
Good Luck
Kurt
Posted on Mar 18, 2009
  • 59 Answers
SOURCE: I am replacing a waterways pump and motor
on the motor is a label giving the hp and motor specs. there is also a figure on the label showing the wiring for low voltage and hi voltage.
David
Posted on May 25, 2009
muralme
  • 20 Answers
SOURCE: I am Replacing a pump motor and I'm not sure of the connections
high speed phase neutral should go to High speed {phase} neutral low speed {phase} should go to neutral .....Low speed and high speed {phase} need not be connected
Posted on Jul 12, 2009
john224
  • 1378 Answers
SOURCE: Low/High Switch wiring for Hayward Superpump
I do not read anywhere that you have a 230V DPDT switch which you will need in order to select the high or low speed. You will have 6 terminalas on the switch. Line connections usually go to the middle set. Put put sides of one pole to the common terminal and put one of the other posts to the hi and the other to the low terminal. I prefer to use am on-off-on switch so the switch in the middle turns off the pump. Flip it one way for hi and the other for low. If you post your stock number from the two-speed motor I could give you a more accurate diagram if you need it. Generally, 1 is common, 2 hi and 3/4 low.
Posted on Apr 26, 2010
  • 1388 Answers
SOURCE: I am replacing a 161 - 193uF starter capacitor in
Depending on the brand/model of the capacitor, it could have only one blade connector or two connectors per pole. Notice that the capacitor has two small rivets where the blades are attached. Each rivet is a pole. You motor uses AC (alternating current) so it does not matter which pair you connect to a pole. Take your pairs of leads and attach one pair to one side (pair of blade connectors with rivet in center) (use either side of capacitor no matter). Then attach the other pair of wire to remaining twin connector. Motors that use start and run capacitors also have two sets of stator wiring and a centrifugal switch. If the switch contacts are dirty or burned, the motor will not start and act as if start cap. is bad. If you are replacing the start cap without testing the old one, and motor still acts as before, suspect start switch. Good luck
Posted on May 05, 2011
I have a Waterway Insulated wetend pump 1 HP. Model # SD-10-2N11MC It has power to the pump but doesn't work. 118 Volts per wire. Makes no noise but keeps blowing fuses. A Balboa VS501Z power unit.
You have a short some place or the motor or pump itself is shot or seized causing it to shut itself down by blowing fuses. Could be bad bearings.
See if you can turn the shaft on the motor.by hand with it not plugged in that will tell you where the problem could be. .
Apr 12, 2015 | Waterway Pool & Spa
Waterway ez48 wiring
see side of motor for voltage wiring
Sep 01, 2013 | Waterway Champion 1 1/2 Hp 230v Energy...
230 volt waterway spa pump model#sd-20-2n22cd electal scamatic
check voltage if 220 between two hots its 220 if only 120 low voltage if 220 ok then 1st hot to L1 then 2nd hot to L2 then green to ground or case if white you might have 120 volt then see side of case of motor for low voltage wiring
Apr 20, 2013 | Waterway Pool & Spa
I have just bought a waterway 3/4 hp. Can you give instructions ( or Diagram ) for changing wiring in motor over to 110 V from 220 V. Thanks, Pat
Is there a coverplate where the wires come out of the pump? If so, remove the plate and there should be a wiring diagram inside for both the 110 or the 220V convertions.
Jun 03, 2011 | Waterway Champion 1 1/2 Hp 230v Energy...
Jun 15, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
I am replacing a Waterways Pump and Motor 220v with a new Pentair 220 v 2 hp. I need to know how to wire it.
David
May 03, 2009 | Pentair 3hp Whisperflo Pool Pump In -...
Got a waterway 1.5 hp 1 speed 115/230v, wired 115 need 230
Good Luck
Kurt
Mar 18, 2009 | Waterway Champion 1 1/2 Hp 230v Energy...
Pool & Spa Logo
29 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
