Question about LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive
My Lacie 1TB drive won't boot up anymore
Greetings,
My Lacie 1TB Firewire drive will not boot up and appear on my MAC G5 desktop.  I just bought the unit on June 20, 2007.  I have 2 other Lacie drives (160G & 120G) that I've owned much longer and are working fine.   The blue light is still blinking, indicating that the drive is not kicking in.  I've noticed recently that when I am saving data, either from the internet or work on my desktop, that the 1TB drive has been taking a little longer to 'wake up' before I can save the data.  I usually leave my Mac and the drives on most of the time 24/7.  I have an UPS, and that protects my drives from power outages and spikes.  I did have a recent (and very brief-maybe 30 seconds) power outage 3-4 days ago.  Coincidentally, the problem I'm experiencing now occurred after that outage.  The other drives are fine, so I am led to believe that's not the problem.
I also recently ran my Disk Warrior program on all of my drives as a routine check about a week ago.  Everything looked good at the time.
Is there anything I can do on my end to fix this problem?  Since I can't even see the drive, I don't know what to do.  I guess I could run the Disk Warrior program again to see if the 1TB drives shows up.  Right now it's still blinking and is not visible.
  • 679 Answers
Try to reset jumper setting; one thing more to do>chack logic card of the hdd by using multimeter for voltage regulation. if the problem is in the logic card than need to replace logic card.
Thanks for using FixYa.
Posted on Jan 05, 2009
  • rockfixya
    rockfixya Jan 12, 2009
    thanks for using FixYa.
  • 33 Answers
You say that it does not boot and appear on your desktop, Next you say that it takes longer to save data as the drive takes longer to "wake up". Now i would like to know that when you got this drive was it working perfectly of it was raking more time to access and further it stopped working after the outage. Is this correct. I think that the drive may have developed a bad sector or the box has experienced power surge. May be u should get it to the service center and get it replaced
  • LaCie Master
  • 19,396 Answers
Run the software again, and see if the disk does show up.
If it does show, it should be recognised and work fine.
If the disk is not detected, then it is either a faulty Lacie enclosure (disk inside is good) or a defective disk.
In this case test the disk on a different computer to ensure it is working.
Good afternoon Customer Support, My 1TB USB 2.2 External Hard Drive has disappeared from my Desktop (Mac OS X). I installed my Lacie two years ago and it always appeared on the Desktop every time I...
Hi John
This situational you have to do only one thing change you USB cable and try, if your drive is appeared its mean you solve the issue. otherwise take the drive and go to the lacie nearest service center because the drive have internal problem (may be Capistrano fault).
Cheer
Sep 02, 2011 | Computers & Internet
I just bought my LaCie 301888KUA 1TB Starck Desktop USB2.0. I was following set up directions in the manual until I realized that my Mac OS X (version 10.5.8) is not recognizing the hard drive . It's not...
the problem is that your lacie drive operates using the NTFS (New Technology File System) under USB which is the standard file system of Windows. Apple mac is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac if you wish to use it via the USB connection.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
download and install the software then restart your mac.
//javaftper
Jul 31, 2010 | LaCie 301888KUA 1TB Starck Desktop 1 TB...
Will not mount on a Mac Book Pro 17"
try to connect lacie to windows base computer if it work, there a problem, with your mac book check if device manager recognize lacie drive if not check for the fire wire port.
Apr 10, 2010 | LaCie 1TB D2 HD Quadra FireWire 400 Hard...
My lacie mounts on the g5 but when i click it, it doesn't open.
It would be a good idea to look at the Mac system log so from a v bad memory do...click Apple (top laft hand corner) then about this Mac then System Profiler then Logs and take a look and see what errors you are getting. If this doesnt give you any clues my advice with external disk problems is where possible to remove the disk from the enclosure and install it in the Mac. if you can, THis will eliminate the USB cable, interface, and box. See if it mounts then. If it does run disk utility to double check it but get your data off first onto the Mac. Hope this helps....Mark
Aug 21, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
Can't read my LaCie, and it sounds like going up and down inside.
sounds like the USB/Firewire controller on the drive set is TOAST.
get a new enclosure, and move the drives to it. heat could have caused this to happen.
Mar 19, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Mar 09, 2008 | LaCie Big Disk Extreme with Triple...
My Book firewire not bootable on mac
I picked up a couple of My Books lately( via Ebay), and noticed that i can not get them to work on the Firewire interface with my Dual Core Intel Mac. Shows up on USB2.0 fine however.I found an online reference that said Apple changed some things on the Firewire interface year or two ago, and that vendors had to update their firmware (it related to Firewire devices reporting a unique ID to the Mac).
Jan 12, 2008 | Western Digital My Book Essential Edition...
Can't accept Quadra 500 on my owerMac G5 Quad
Scrap LAcie!! Sounds like in this case, it may have been jostled around during shipping. None the less, Lacie drives are nothing more than bricks waiting to fail. Go Western Digital, but if oyu can, zip straight for Seagates!!!! Professional grade!! ALways check the cables, the ones that come with them are bottom bin cables, made by little singapore children with no fingers..... Invest in a good cables...a drive is only as good as the weakest datalink.
Cash on the warranty!!!
Keep me posted.
Dec 13, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Firewire ports malfunction
Boot the machine from external hard drive with known good OS installed.
If issue persists then, then logic board has issue.
Dec 13, 2007 | Apple Power Mac G5 Desktop
Lacie 1000gb external drive
I own a Lacie product that does the same thing. It uses firewire but it was clicking a few times and then would not display as a drive. I moved to another computer (with a different firewire card) and it worked. I decided that the firewire card was the issue at the time, but the card still read other devices like digital video camera. I know you are using the USB 2.0 cable. Can you try your drive on a different computer? That would narrow the possible solutions down.
Jun 26, 2007 | LaCie (300951U) 500 GB Hard Drive
LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive Logo
96 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
