Question about Canon ImageRUNNER 1670F Copier
IR-Adv-C7055 open toner replacement door - Canon ImageRUNNER 1670F Copier
2 Suggested Answers
canontech
  • 1219 Answers
SOURCE: i need photo coppier "
I would recomend You the two second hend refurbished iR 3300 Copier ( B&W ) or Ricoh AF 1045/2045 and color clc 3200 for color, for the beginning and if you want later take stronger 50ppm i.e. IR advance 6055 for B&W and IR ADVANCE C2030L.
Hope that helps!
Posted on Jul 28, 2011
How to compleat reset canon ir adv c5045 copier machine .images coming shadow.how to solve this problem
Hi , i don't think resetting the machine will help you, there is a lot of things that may be causing that problem , dirt/ dust , toner spilling in the laser unit, or worn out drum units. i recommend you to get technical support
Apr 27, 2017 | Canon Office Equipment & Supplies
Canon ir 2016 toner bag full
I'm assuming it is the waste toner full message. Power down copier- Main Power. Open front door and gray handle to open left side door and pull out drum. On the top there should be an opaque disk to be removed and then you can dump the waste toner into the trash. BE VERY CAREFUL THIS COULD GET MESSY.! Slide the drum back back into position, close the left door and front door. Power up the copier and all should be good.
Mar 13, 2017 | Canon iR 2016i Black and White Copier
Canon ir-adv c5240i when there is no jammed paper it shows me paper jam how do i fix it fixya - did not match any video results.
Make sure you have opened the drawers and opened and closed all the doors. Look for little levers and light sensors throughout the machine to see if any of them are blocked by a torn scrap of paper.
Jan 20, 2017 | Canon Office Equipment & Supplies
Replace waste toner IR Adv 6055
You have to replace waste toner bottle,which is full
Jul 25, 2014 | Canon Office Equipment & Supplies
Canon c7055 jammed
if you already checked & opened all the door then probably there is none. try flicking the sensor flag, usually its broken or maybe not moving freely as it should. all in all if you're absolutely sure those flags are ok then most probably its the main pcb's fault.
Aug 09, 2012 | Canon Office Equipment & Supplies
Error code E000005-0001 cannon ir-adv 6055
I have a problem with my machine,
Canon IR 6570 with error code E000005-0001
beg for a solution
Nov 09, 2011 | Office Equipment & Supplies
Where are the cartridges located to install new ones?
http://software.canon-europe.com/products/0010476.asp
try to download the manual from the above link and check there.
Howver you can also check it on the lid. instructions are given. This should be very easy as we need to pull out the tray and replace the cartridge. signs and signals are given on the printer itself.
Apr 29, 2011 | Canon iR 2022i Printer
CANON IR-1210 IN THE DISPLAY IS STANDING: CONTR. TONER/DRUM HOW CAN I FIXED THAT? JOHAN THE NETHERLANDS
try to open the front door were you put the toner and close.if still showing the message replace he drum.
Oct 21, 2009 | Canon imageRUNNER 1210 Copier
Canon ImageRUNNER 1670F Copier Logo
154 people viewed this question
old marine
old marine
