The compressor motor is rattling around in it's shell. It had mounts, but they wear out. It may be ok, but I would price replacing the compressor, or the whole unit, depending on what shape it is in.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
well to be honest its a "no, no" a 10 year old unit is not very good and is costly to run to fix it would cost half the price of a new one, and by now you must have had your money's worth out of it, so its best all round to buy a new one to fix your unit it would need a new compresser a re,gas and maybe a thermostat as well, ,,see what i saying,,,lots of money for an old unit
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
You need a qualified technician for this problem. - Your unit may have leaking try to check for oil traces. - The system maybe restricted, system reprocess is needed for this unit. - If the unit is no frost try to check if there is an air circulation inside the unit. If no air is present then check your fan motor inside.
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
