Question about LG WD-1280FHD Front Load Washer
Removing the bearings from my direct drive washing machine
Hi i am trying to replace the bearings and seal on my DD washer, i have taken the back off, but cannot get the bearings out, can you please advise me, the washer is sitting in the middle of the kitchen, with a basket of washing waiting. please help. Thanks, Thelma
  • thelma brown May 25, 2007
    did try to rate, but unable to as the site was not available. however, i have decided to purchase a new washer,one with a belt and bushes. shall steer clear of direct drives, only had it for 3 years, cost £550, a very expensive mistake.. would not recommend direct drive. on a final note, i would just like to say thank you for all your input and advice, this is a brilliant informative site.
  • 5,911 Answers
If you're talking about the rear drum support bearing, they are usually not removable. They are molded into the plastic tub shell. When the bearings go bad you generally have to replace the entire back shell of the wash tub.
Posted on May 23, 2007
  • Jeff Rockwell
    Jeff Rockwell May 28, 2007
    Thanks for the feedback. Sorry I couldn't have been more help for you. Good luck with your new washer.
SOURCE:
Bearing replacement
One of the biggest jobs to do on a washing machine. Remove the drum from the machine, remove the washer drum, knock out bearings, replace drum spider (shaft) fit the new bearings, and drum seal, put everything back together again. Job for a experienced engineer.
Oct 03, 2014 | Washing Machines
Automatic washer won't engage in wash cycle or spin cycle. Amana washer Manu model PALW880QAW1
Yes surely that could be one of the reason (due to over tightening) also i request you to carefully check if there is any crack on the body since it is a bit aged. Also try to apply lubricant to all the necessary joints and moving parts.
Thankyou
Apr 07, 2008 | Washing Machines
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
How do i remove the bearings
Hi
In a washing machine, the bearings protect the drive shaft from over rotation due to the forces applied to the washtub.
Unplug the washing machine from the power outlet. Turn off and disconnect the washer from the water pipes. Pull the machine forward so that you have easy access to the entire machine.
Unscrew the lid's top two screws and remove the machine's top panel.
Slide out the machine's back panel.
Slide off the fan belt and set it aside.
Unscrew the drive shaft's end bolt. This is the bolt that holds the pulley into position.
Remove the pulley by placing the screwdriver underneath it and gently leveraging it off.
Remove the drum's three bolts that hold its spider bracket into place. If the bolts are sticking use, rust remover and degreaser to loosen them. Do not apply too much pressure to the brackets or you will strip them.
Tap the spider joint gently with a hammer while pulling on it. The entire joint and the bearings should slide off.
Clean up the spider shaft, removing all rust and debris using cloth diapers and rust remover and degreaser solutions.
Tap the new bearings into place.
Tap the new drive shaft seal into place. The drive shaft seal should always be replaced with the bearings to ensure water-tight protection for the machinery.
Reassemble to washer.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 02, 2011 | Indesit W 123 Front Load Washer
My Maytag Nuptune fav6800aww won't spin. I followed the directions to replace the clutch, but that didn't fix it. The tub will not rotate in either direction. I have taken the transmittion out and it...
Maybe the Outer Tub bearings are seized. With the Clutch Pulley removed the wash basket should rotate within the Outer Tub bearings with one finger in CCW and CW direction does it?
"" I followed the directions to replace the clutch, but that didn\'t fix it. "" Was it my post Clutch Fix post? If your FAV6800A used the Upper Bearing One-Way roller clutch bearing ring do you feel on reassembly the parts are seated correctly.
What are the first two digits of you s/n of your machine?
Was the Clutch Pulley One-Way Roller clutches bearing rusted up severely or only slightly? I'm trying to get a feel for a Tub Seal leak........Rich
Oct 05, 2010 | Maytag Neptune FAV6800AW Top Load Washer
We have a Whirlpool Duet Sport Front-Loading Automatic Washer and it makes a pretty loud noise when in the spin cycle. The volume is directly proportional as to how fast the washer is spinning. It's a...
The symptoms that you describe are caused by bearing failure. The water seal in the wash tub has failed, allowing water to leak into the bearing causing the bearings to rust. As the bearings start to rust, they will not roll properly and start to make a rumbling sound. The sound get louder the faster the bearing turns.
It a major job to repair since the washer has to be taken apart and the wash drum needs to be removed to replace the seal and bearings. Get a few estimates before deciding whether the washer is worth the cost to repair or replace. Sorry.
Oct 04, 2010 | Washing Machines
Noisy bearing while spinning
The seal in the drum has failed allowing water to leak into the bearings causing them to rust. Once the bearings are no longer round, the bearing noise will get louder. To replace, the washer needs to be taken apart and the drum needs to be removed in order to replace the bearings. Can be a difficult and expensive repair. Get a few estimates before deciding whether it is worth reparing. Sorry.
Oct 04, 2010 | Maytag Neptune Washer
Washing machine very noisy when spinning
Probally the bearing seal failure causing water to seep into the bearings. You will need to replace the seal and bearings to fix. It is a big job since the washer needs to be taken apart to replace the bearings.
Sep 09, 2010 | Indesit Washing Machines
My washer leaves oil spots on my clothes
The only place where oil can enter the wash would be if the bearing seals have failed. It's a major repair, and the entire machine has to be taken apart to replace the bearing and seal.
Jul 30, 2010 | Kenmore HE2 Plus Front Load Washer
Removal of the bearings
Those bearings are almost impossible to remove.  You would be better off replace the rear half of the tub assembly as it comes with everything.
May 22, 2007 | LG WD-1280FHD Front Load Washer
LG WD-1280FHD Front Load Washer Logo
278 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
