Question about Digital Lifestyle FA1B32Z 32 in. LCD Television
Lg tv says to check external link input status
I try to hit input on my tv remote and the only thing that pops up is a little box stating to check external link input status i dont know what that means i am able to go to my menu on my tv but i dont know what needs to be changed in order for my cable to work my tv says no signal
2 Suggested Answers
  • 8457 Answers
SOURCE: the remote control does not power the TV on and
Tv remote probally have dead CPU chip,all remotes devices heavily depended on it CPU chips.Try website like Remotes.com to buy an exact remote or very close to the original remote.
Posted on Feb 05, 2011
Testimonial: "thank you for your quick response- the information really helped me solve the problem"
My zenith 50in. tv keeps saying check external input link status.what does that mean?
The main board needs replacement. you should be able to get the replacement main board from www.tvcircuitboards.com
Dec 11, 2012 | Zenith P50W28B 50 in. Plasma Television
I have a small elemet tv with a en21645e remote control. My grandson did something to the remote and now I only get the local channels not cable channels although I have cable hookup
The little tyke has most likely pressed the INPUT button on the remote control and switched the TV away from the external input setting required for watching cable TV.
You did not state the model number of the TV and some TVs function differently with regard to the selection of external inputs, but you should be able to return to watching cable by pressing the INPUT button slowly but repeatedly until you can see the picture from the cable channels again. The INPUT button is located in the top right corner of your Element remote.
If an input selection menu appears on screen when you first press the menu button, use the arrow keys to highlight another input, then press ENTER to select it. I can't tell you which will be the correct input as I don't know the model number of the TV and it depends on which type of cable you are using to connect the TV to the cable box. You should try each input in turn until you are able to see the cable channels again. Please make sure the cable box is switched on when doing this!
If you are still having difficulty, please reply to me from within this page with the model number of the TV and the type of cable you are using to connect the cable box to the TV. I will then be able to provide exact instructions for switching your TV back to the cable input.
Hope this helps.
Regards,
BElectric
Jan 28, 2011 | Element Televison & Video
I have a 32" RCA 32V432T TV that only shows snow now. I've checked everything externally but still no picture. Any solutions?
There could be several things that can cause this: 1. There are no analog channels in your area. 2. Check the menu setup and verify that you select the proper input (antenna, cable, etc). 3. The TV tuner is defective Try using the composite input on the TV (there are normally 3 jacks per input). Yellow for video and red and black for audio. If you dont have the proper cable, pick one up in you local 99 cent store or an electronic store.
Connect the "output" of your device (VCR, cable box, Tivo, dvd player, etc) to the "input" on the TV. Then use your TV remote to select the proper input.
Hopefully this helps. Good luck.
Sep 27, 2010 | RCA 32V420T 32" TV
I want to go from ant to cable how do i reprogram i dont have the
There are two ways you may do this. First, if you have a cable box then all you have to do is hook up your cable box to any of the input and go to that input on your TV and it should come up. Second, if you do not have a cable box, hook up the cable coax to your coax on the TV. On your TV, hit the menu button, then go to TV selection, then scroll down to tuner mode and select cable, then auto scan. once scan is complete, your cable is ready to watch.
Jun 16, 2009 | Toshiba CT-90157 Remote Control
LG TV renote not worknf on 4 new sets
If you have a cable box (otherwise known as a set-top-box) that you have to turn on when you turn the tv on, and you use to change your cable channels, the LG remote will not control it. The LG remote is strictly for the tuner built into the television, and is not capable of controlling the cable box.
You probably see "function not available" because you are viewing the picture on an external input of the tv (component, composite, etc). Your tv cannot tune stations in when it is set to an external input that you use to watch DVD's, cable boxes, games, and other devices. The tv is telling you that you can't change channels if it is on an input.
I hope this helps you...
Jan 20, 2009 | LG Televison & Video
I dont have vchip code fof my used tv
1. Hit the Menu button on the TV. 2. 'INPUT SECRET No.' should appear. 3. Press and hold both VOL (+) and CH DOWN on the TV set simultaneously until the message 'INPUT SECRET No.' disappears. 4. The vchip settings should be disabled now and the Parental controls menu should be presented, 'disable' Status if need be
Remember do it on the tv not the remote
Nov 14, 2008 | Televison & Video
Problem with sanyo tv
Check the menus in the TV. Look for a Display menu. There should be an option somewhere to turn this off. I don't know this TV personally, but it CAN be turned off.
Feb 05, 2008 | Sanyo DS32224 TV
Game Mode
not familiar with this model but ill try try in the menu puting it on game mode then look for external input mode in the menu and turn it too dont work fix ur remote or bye a new one (be sure that the new remote will activate the game option) good luck windman
Jan 02, 2006 | Sylvania W4913LT TV
Digital Lifestyle FA1B32Z 32 in. LCD Television Logo
508 people viewed this question
Top Digital Lifestyle Televison & Video Experts
CoppellTVRepair.com
paul
paul
Are you a Digital Lifestyle Televison and Video Expert? Answer questions, earn points and help others
