Question about Packard Bell Computers & Internet
Monitor Display Hi there,i have a P/Bell monitor,model no: FT500,the display does not show,i.e. blank screen,i believe it may be the display inverter that's faulty.Would lke to know is there any way to repair this,Many thanks.Jay.
  • ken arjoon
    ken arjoon May 11, 2010
    is this a lcd or crt type monitor
  • 158 Answers
First check all the cable connection and if all is perfect then press "J" at the system boot.
Otherwise, attach this monitor in another system by which you can clearly understand whtzs going on.
Posted on Jan 05, 2009
I have a TJ68 packard bell Easynote laptop, it will power up, but display screen is black and flickers. I connect a vga cable to an external monitor and can see contents of laptop on external monitor.
The fact that you can see the desktop on the external monitor means your LCD Inverter on the laptop is bad. The video card in the laptop is good, otherwise you would not be able to see the desktop on either screen.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
The lcd inverter can be purchased on ebay for less than $15. It is located at the bottom of the lcd screen. You'll have to remove the plastic strip that is around the lcd screen by removing the plastic or rubber bumpers that have screws under them. Normally there will be bumpers at each corner and maybe along the insides on the plastic strip. Remove the bumpers, the screws and pry the plastic strip off with a little force with your fingers. You will then see the lcd inverter at the bottom of the lcd screen.
Just put your computer's name and model in the ebay search followed by lcd inverter.
Actually it looks like your laptop uses the LED screen instead of LCD so it will not have the LCD Inverter. You will have to purchase a new screen. I found the one below on ebay.
http://www.ebay.com/itm/Packard-Bell-EasyNote-TJ68-AU-065UK-LAPTOP-LED-LCD-SCREEN-/400293582889?pt=US_Laptop_Screens_LCD_Panels&hash=item5d335b5829
May 13, 2012 | Packard Bell Computers & Internet
Screen blank with white dot
Problem with;
1) Video cable:
A) Video cable connection on motherboard side is loose, and/or on back of LCD screen.
B) Video cable is damaged.
2) screen Inverter:
screen Inverter is bad.
3) LCD screen:
LCD screen is bad.
4) Graphics chipset:
Graphics chipset is bad.
Suggest you connect a VGA monitor to the VGA port (Connector) on your laptop.
See if the problem is the graphics chipset, Or video cable, Or display assembly.
You didn't state what manufacturer and Model Number of laptop this is.
All I can do is state generic information.
This is an example of a VGA Cable, and VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
The VGA connector will be on the side, or back of your laptop.
For the VGA monitor you can use a CRT type monitor, (Looks like a small TV), or a flat LCD screen monitor that has a VGA cable.
Laptop OFF, monitor OFF, connect the external VGA monitor to the laptop.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should show on the external VGA monitor.
IF not;
There are at least 3 display options.
1) Laptop internal monitor ONLY
2) Laptop internal monitor AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold down on the Fn key, and at the same time tap once on the Display Toggle-Over key.
(For an example HP's usually use the F4 key for a Display Toggle-Over key)
Display shows the same on the external VGA monitor?
You have a bad graphics chipset.
[ Some laptops have been erroneously stated as having a graphics card, when in fact they do not.
The GPU (Graphics Processing Unit) is soldered directly to the motherboard.
This is Integrated Graphics.
http://en.wikipedia.org/wiki/GPU
There is no changeable, replaceable graphics card. Therefore the solution is motherboard replacement ]
IF, the display is good on the external monitor, you have a problem with the Video Cable, and/or in the Display Assembly.
After diagnosing with an external VGA monitor, post back in a Comment.
Also post the manufacturer name, and model number of the laptop.
Regards,
joecoolvette
Apr 22, 2012 | Computers & Internet
When i switched on my computer,my desktop will no fit onto my screen i have to scroll from side to side with the mouse or up and down to view the complete screen.
This can happen if your display resolution settings in windows are set higher then your monitor can support. The display is meant to be set at 1024x768. You can set this by going into the control panel, select display. You will find the option to set the resolution in there,
Regards, Chris
May 19, 2011 | Packard Bell FT500 15" LCD Monitor
I have a hp laptop. was on line and screen went black. and will not show again. it strats up sounds but black screen.what do i do
1) Do you have a VGA monitor that you can use for an external monitor?
{VGA monitor is also referred to as a CRT monitor. Looks like a small TV}
The back of the laptop, or side, has a VGA port. The VGA monitor is plugged into it.
{Laptop off}
Then the VGA monitor is turned on, and allowed to 'come to life'.
Now turn on the laptop. Press the Fn key down on the keyboard, and hold it down.
Now press the Monitor toggle over key.
Since you did not state the HP laptop Model Name, and Model Number, I can only give you generic guidance on this.
The monitor toggle over key has a monitor screen symbol on it. It will be one of the F keys.
(It's an External Monitor toggle key.
Press it one time and the display toggles over to an external monitor.
Press it again, and both the laptop LCD screen, and the external monitor have a display on them.
Press it once more, and the display goes back to the laptop's LCD screen )
If display shows up on the external monitor, you have a problem with the display of the laptop.
Primer:
An LCD screen cannot produce enough light by itself. It needs an additional light source.
A Backlight is used as an additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp {Bulb}
Similar to the fluorescent lighting used in homes and businesses, but on a MUCH smaller scale.
{Average Backlight is 3 to 5 inches long, and half the diameter of a No.2 pencil.
The Backlight is located on one edge of the LCD screen}
An Inverter is used to provide power for the LCD screen, and the Backlight.
90 percent of the time the problem is the Inverter.
Inverters are relatively cheap, and if I knew the Model Name, and Model Number of your HP laptop, I could give you a link to HP Support where you could download the Service Manual for free.
This way you would have a manual to show, and detail how to replace the Inverter, and I could guide you.
I could also give links for your perusal for Inverters.
There is one more thing however.
HP Pavilion DV2000, DV6000, and DV9000 series laptops, have a graphics chip overheating problem.
The laptop comes on, the blue indicator LED lights light up, but the LCD screen is black.
This video explains why, shows a solution to fixing the problem, and details out a lot more than I am privileged to state here,
http://www.youtube.com/watch?v=bnkQNmKauEc
Have further questions regarding any of the above, please state in a Comment.
(Believe upper right of your page)
Regards,
joecoolvette
Dec 02, 2010 | Computers & Internet
I have a second hand packered bell laptop, how can i check the batery power?
for xp go to start, settings, control panel, power options, power meter will display it. start, settings, control panel, power options, advanced, then checking display on task bar and applying will put it on task bar.
Aug 10, 2010 | Packard Bell FT500 15" LCD Monitor
My packard bell monitor keeps presenting a blank screen. When the computer is turned on, it starts up as normal but then just after the MS screen appears, it turns off and won't show anything on the...
Try this for starters. Shut down the computer like you normally do. Next turn it on and while its booting up press the F8 key(keep tapping it). You should get a menu and on that menu, one of the choices is Safe mode. Select it and press enter. This will boot your computer into a Diagnostic mode where you can troubleshoot hardware software and windows problem in general. If you successfully get into safe mode answer yes to the question it asks and then goto your Device manager..you can get there by rightclicking the mycomputer icon and select properties from the drop down menu then select the Hardware tab on top.and click DEVICE MANAGER. In this screen look for your display adapter..higlight your graphics adapter and right click...then select uninstall...now reboot your computer normally this time dont press the f8 key..gointo WIndows normally. This should reinstall your graphics card and possibly fix the problem.
Jun 17, 2010 | Packard Bell FT500 15" LCD Monitor
Monitor screen keeps jumping up and down
Download and install the most recent driver for both your graphics card and your monitor from the respective manufacturer's websites.
You will most often find these under "support". You will have to know the exact make/model for both to find the right drivers.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jun 01, 2010 | Packard Bell FT500 15" LCD Monitor
Lcd blanks out
Yes, that is one possibility. It could be the cable from the motherboard to the display. Inverters are fairly common problem.
May 14, 2010 | Toshiba Satellite 1805-S204 Notebook
Acer Aspire One notebook model zG5, i hear the hard drive come on, but screen is blank and the keyboard does not respond.
connect the laptop to an external monitor, turn it on see if the monitor will display.
If the monitor displays, then it means your screen inverter or screen bulb is the cause of the laptop screen being blank.
Also if the monitor does not display anything, the maybe the graphic card is the cause of the problem.
This would involve you taking the laptop to a repairer
Take care.
Apr 15, 2010 | Acer Aspire One PC Notebook
Screen goes blank
Hi jkm007, Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 12, 2006 | Videoseven V7 L19PS 19" LCD Monitor
Computers & Internet Logo
65 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
