Question about Seiko Mantel Clock
My elgin anniversery clock chimes the hourly chime at38 minutes after the hour
SOURCE: Chimes are nine minutes slow
Take the minute hand off and turn hand over. There is a brass bushing that attaches to the aluminum hand. Take a small screw driver and place in the square hole of the brass bushing. Turn either direction and test on the minute post of the clock. Keep adjusting until the clock chimes right on the 1/4 hour position. Make sure to put the hand back on the right 1/4 hour.
Posted on Apr 01, 2009
SOURCE: seiko mantle clock (switchable chimes)
See this site
http://www.theclockdepot.com/seiko_westminster_clock_instructions.html
Posted on Apr 22, 2009
escapement
  • 2334 Answers
SOURCE: Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
Posted on Jul 29, 2009
  • 61 Answers
SOURCE: How do you syncronize the chimes to the actual
Are the hands held on by a nut? usually you can remove the nut with your fingers or a pair of pliers wrapped in cloth or duct tape to prevent scratching.
Before removing turn the minute hand (minute hand only and clockwise only; do not manually turn the hour hand and never counter-clockwise) turn the minute hand clockwise until it chimes at an hour mark.
Then remove the hands and and place them pointing to the correct time.
If you are uncomfortable with this I recommend taking it to a clock shop or jeweler that sells clocks. If it is inherited, it may need some maintainence (oiling and regulating) anyway.
Posted on Oct 17, 2009
SOURCE: I have a Strausbourg chime mantel clock. It chime
I lost directions to my clock, it takes two double a batteries for the chime but i dont know how to set it.
thanks
Posted on Jan 10, 2010
After spot cleaning mantle clock with German movement (circa 1960), the clock chimes properly on the hour but does not chime on the half hour.
I am hoping that you oiled it also? One trick I have found is to gently lift the hammers and release, sometimes the hammers will release and strike the chimes/gong. Do this 4-5 times and hopefully it will get it chiming for you again.
UsedClockParts.com
Nov 09, 2016 | Home
How do I make my clock chime the correct number of times?
whenever the battery is weak the chime changes....whenever you change battery the clock chimes to the last time it chimed so...try setting your clock to next hour of chime n then move the hands of clock to next hour n your clock will chime accordingly.....
in this way waiting for chime to finish ...set to clock to present time ....waiting for it to chime every time the minute hand passes 12
Dec 09, 2015 | Home
My clock chimes on the half hour and counts on the hour. It chimes 2 minutes late on each. How to I get the chime on the half hour and hour?
Get it to chime then loosen minute hand then move hand back to the 12 or 6 position tighten minute hand and test to see if that works
May 08, 2015 | Watches
Elgin Anniversary clock chimes early
take the big hand off and move it back one square on the shaft
Nov 11, 2012 | Watches
The chime of my Howard Miller mantle clock are not w/the actual hour set.How can I reset the chimes? Daylight Savings time has messed me up.
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Nov 06, 2011 | Seiko Mantel Clock
How do i synchronize chimes with clock on westminister whittington clock .
The Westminster/ Whittington clock means that it has 2 or 3 settings.
1. Silent
2. Westminster Based on the music My redeemer liveth by Handel
3. Whittington
Set the clock onto the westminster setting, this is the easiest. At quarter past the hour it should sound 4 notes. The half past should be 8 notes. Quarter to the hour should be 12 notes and the hour should be 16 notes then the striking of the hour. For example on 8 'O clock you should hear 16 notes then the clock should chime 8 times. Sometimes if the hour is out just gently stop the pendulum, check what hour the clock is striking then without taking the hands off move only the hour hand to the hour. Do not do this with the minute hand.
I hope this helps you! If you are not sure please email me yvonne.finch@gmail.com I fix these clocks.
Apr 30, 2010 | Seiko Mantel Clock
Rate me, please.
Jul 29, 2009 | Seiko Mantel Clock
Elgin grandfather clock chimes not working
I'm not positive about this, but I seem to recall that these type of clocks have two "silence levers" on the movement. These levers are located at the upper left and upper right corners of the movement as you face the movement from the back. The movement back panel has to be removed if it has one.
If the levers are pushed toward the chime rods, they will silence the hour or musical chime, depending on which one it is. I believe the silence levers are supposed to be moved away from the chime rods so the rods can retract and then strike the chime bars.
Mar 29, 2009 | Elgin 0518709FA
Home Logo
Top Seiko Home Experts
k24674
Jerry Greenberg
Jerry Greenberg
Are you a Seiko Home Expert? Answer questions, earn points and help others
