Question about Nordic Track Nordictrack Nt Audiostrider 990 Incline Ramp For Model Number
I NEED TO CALIBRATE INCLINE ON NORDICTRACK AUDIOSTRIDER 990
  • 14 Answers
SOURCE: nordictrack apex4100i level incline will not work
Try this calibration procedure.
Turn the power switch on. Remove the safety key. Hold the Stop and Speed Up or Speed Plus buttons down then insert the safety key.
The display should show some numbers.
Press the stop key one time and the display should show some other numbers and some 00's. Press the Incline Up button and see if the Incline begins to move, if it does let it go all the way up and then all the way down, wait a few seconds after it stops, then hit the stop key 4 times. It should be calibrated. If it didn't move then the board or the incline motor is bad.
Posted on Jul 08, 2009
  • 103 Answers
SOURCE: I NEED THE NORDICTRACK 9600 INCLINE TRAINER TREADMILL SCHEMATIC
contact me @ swflafitnessrepair@yahoo.com I will send this to you.
Posted on Nov 13, 2009
outfield502
  • 79 Answers
SOURCE: Nordictrack Model A2550: Incline function!!??
this function is to give a little more intensity exercise, while helping to raise the heart rate and thus burn fat. watch it more practical as a stress test.can use the runner at a speed of 3.5 mph and an elevation of 7.5 of inclination and see good results
Posted on Feb 09, 2010
2manyhobbies
  • 128 Answers
SOURCE: I have the EXP 2000 NordicTrack incline treadmill
Manuals can be downloaded at http://www.iconservice.com/CustomerService/manuals
First perform an incline calibration.
Insert the safety key/magnet. Press the incline up button. While the numbers are changing, remove the key. Release the incline up button and reinsert the key/magnet. The machine should go to the top and then back to the bottom.
If it only starts then stops, the incline sensor may be defective. Be sure all the plugs are secure on the controller board.
If the sensor is defective, you will need to order a new incline motor..
If the incline motor does not move at all, the controller may be defective..
Posted on Dec 15, 2010
ercupa190
  • 12223 Answers
SOURCE: i have a nordictrack audiostrider 800 that i just
The way to tell if your NordicTrack digital console is bad is to troubleshoot it first. If nothing works, you've got a bad console. The digital console is an important part of exercising. A manual machine will still work even if the console doesn't, but an automated machine needs the console to work so you can adjust things like speed, resistance and incline. You also can't use programs or see your time, distance or estimated calories burned without a working console. The two most common reasons that a console will be dim, display bad results, or won't turn on are bad batteries and a problem with the reed switch.
  1. Replace the Batteries
    • 1 Replace the batteries first, if your machine has batteries. A manual machine such as the NordicTrack MTN 740 will not need batteries, and instead the console is powered by your moving the steps. Check your manual if you are unsure of which batteries to buy. Different machines will require different batteries. The NordicTrack Mini Stepper uses watch batteries, but larger machines will likely need AA or D batteries.
    • 2 Take off the cover to the battery compartment. Remove and discard the old batteries. Replace all of the batteries, not just one if you happen to have one good one. Align them correctly with the "+" and "-" signs as shown on the compartment.
    • 3 Replace the battery cover and attempt to turn on the console.
    Reset the Circuit Breaker
    • 1 Check the circuit breaker. A machine such as the NordicTrack CXT 990 will have a circuit breaker located on the front of the machine. The console will not work if the circuit breaker is tripped.
    • 2 Push the circuit breaker in if it protrudes until it sticks.
    • 3 Try to turn on the console. Check the circuit breaker for your house if this does not fix the console problem.
    Adjust the Reed Switch
    • 1 Inspect the reed switch as the information on the display will not be true if the reed switch is too far from the flywheel on NordicTrack machines such as the MTN 740.
    • 2 Unscrew the two M10 by 82mm button bolts on the right pedal bracket. Unscrew the two M10 nylon locknuts. Pull off the pedal bracket and set aside.
    • 3 Remove the two M4 by 38mm screws. Remove the three M4 by 25mm screws. Slide the right side shield off to expose the flywheel, magnet reed switch.
    • 4 Unscrew the screw that holds the reed switch in place but do not remove it. Slide the reed switch toward the flywheel but leave enough space that the magnet can move freely. Replace the shield and bracket
Posted on Nov 08, 2011
How to recalibrate 8600 incline trainer
To initiate the calibration routine, hold down the SPEED +
button and the SPEED - button simultaneously for three seconds. During the calibration routine, the INCLINE
TRAINER will automatically rise to the highest incline level and then return to the lowest incline level.
P.S. This is listed in your user manual in the "Troubleshooting" section if you don't have a user manual then you can get a pdf copy of it here
http://www.ereplacementparts.com/images/nordictrack/CTK59020.pdf
Aug 31, 2014 | Nordic Track NordicTrack Treadmill, A2550
Why is my elliptical not gliding smoothly?
I do not know anything about your machine. But from a general mechanical standpoint. It sounds as if the belt is not routed properly, or is the wrong size. You can also inspect where the belt rides for debris from the old belt. Something could be stuck somewhere. Hope this helps. Good Luck!
Jun 10, 2014 | Nordic Track NordicTrack AudioStrider 990...
What does the "code" 5E mean on the Audiostrider 990 Pro
Go to Nordic track and find out:
http://www.nordictrack.com/
Jan 20, 2013 | Nordic Track NordicTrack AudioStrider 990...
On my nordictrack a/2350 the incline stoped working what could be wrong?
Follow the instructions found in your manual for incline calibration first. With the safety key/magnet in, press incline up, remove the key while the numbers are changing, release the incline button then reinstall the safety key. The incline should calibrate.
If the motor moves, then stops b4 completing it's cycle, the incline sensor may be defective. The sensor is the black cap/wire coming out of the top of the motor. Make sure it is connected properly.
If the sensor is defective, you have to order the complete motor to repair the problem The sensor can be replaced without replacing the motor, but it is not available as a replacement part..
Part #249516 around $110....
Dec 15, 2010 | Nordic Track NordicTrack A2350 Pro...
Nordictrack apex4100i level incline will not work
May 31, 2009 | Nordic Track Nordictrack Apex 4100i...
Nordic Track Nordictrack Nt Audiostrider 990 Incline Ramp For Model Number Logo
222 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
