Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
Cannot connct xbox 360 wireless adaptor
I am using a TP-LINK TL-WR340G wireless router which appears to be working fine on pc
PC is telling me there is a wireless connection to the router .
However i`m trying to get an xbox 360 to be picked up by the router ( using the appropriate wireless adaptor ) but i am having a lot of problems achieving this.
i`m not 100% sure of the right settings for the router the wireless set up part i have wep setting and open system is this correct?
also need to know what ip address etc i should use for the xbox 360 adaptor ,,, any help would be appreciated ....john
  • john
    john Jan 05, 2009
    hi thanks for the reply , i will give this a try later on and let you know how it goes .....many thanks again for your help..
  • john
    john Jan 06, 2009
    hi webdevil tried what u said but to no avail,
    was looking through all the wireless router settings but not sure what it all means,
    security type has WEP,WPA/WPA2,WPA-PSK/WPA2-/PSK
    security options has SHARED KEY ,AUTO , OPEN SYSTEM
    wep key has HEXADECIMAL,ASCII
    ive tried all that i can think of changing all settings and also putting back to factory resest and starting all over again but same thing .. it just wont connect.
    also have checked SSID all appears ok
    my only other way of thinking is that the ip addresses may be wrong ..
    LAN and WIRELESS i.p are the same ,
    WAN i.p is different
    went back to the shop today where i purchased the router and the guy told me to try another ip address in the xbox adaptor which i did but again no connection.
    maybe you could assist me with the right way in setting up the ip addressess if poss... many thanks ...john
  • 43 Answers
Your XBOX 360 adapter should automatically be assigned an address by the router's DHCP server. I think you may be having a problem with your wireless configuration. Check the wireless settings on your router to confirm that it is indeed setup for WEP. If it is setup for WEP on bothe the router and the XBOX and the key is typed in correctly on the XBOX it should work. If it still doesn't however, disable the wireless security on your router, then restart your XBOX and see if it will connect without WEP. Many devices will have problems over WEP and not connect at all. If it connects fine with no security enabled then we will know that was the problem and I would sugest changing the security to WPA.
Posted on Jan 05, 2009
  • Johnathon Haywood
    Johnathon Haywood Jan 06, 2009
    OK. For troubleshooting purposes, disable any wireless security on the router.
    You mentioned that the IP addresses may be wrong, and that the game shop suggested you change it? This part might be part of the problem since your router is responsible for setting up the address of your XBOX automatically. The wireless connection on your XBOX should be set to Auto/DHCP and you shouldn't be able to change the IP if it correctly setup for auto.
    When you test your connection on the XBOX, which tests are successful? Are you able to access the internet on the PC you are connecting wirelessly?
Connecting a tp link wireless usb adapter to xbox 360
It is not possible to use generic usb wireless adapters with the Xbox or Xbox 360 game console. By 8246b47.jpgJohn Anderson Jun 20, 2012
The post John Anderson is correct that this would not work with a XBOX device. These are intended for and installed on computers (laptop or desktop) with which you would need to install drivers for it on. There is supported drivers that will allow the installation of this device into either a XBOX or PlayStation gaming console.
Best Regards!TP-LINK Support Team
Jun 20, 2012 | TP-LINK TL-WN727N , 150Mbps Wireless Lite...
How to configure TP-link TL-wr340g on tata broadband
If you don't have any internet access, you can reset the router by unplugging it from power and then plug it back in. Do the same for your ADSL or cable ISP modem which you have connected on your TP-Link router.
RESET FIRST YOUR ADSL MODEM and then your router.
Other solution might be to do ipconfig /release and ipconfig /renew on your command line window from your computer.
You can find your wifi router's user manual (PDF) on this link:
Please mark as solution if this helped you at all.
Jan 29, 2012 | TP-LINK Computers & Internet
Tp link wireless router Ethernet not working
Make sure the TCP/IP settings on the PC's LAN gets an IP address automatically, don't use a fixed IP address.
Apr 21, 2009 | Computers & Internet
I cannot connect my xbox 360 to my tp link router(tl-wr6145)
Had this problem my self, try lowering the firewall on your router and make sure the network allows media sharing.
Apr 01, 2009 | Computers & Internet
TP-LINK TL-WR340G, No internet connection
Look for the MAC address clone feature on the router. If the router does not ahve the auto clone MAC feature, you'll need to manually input the MAC address of your computer.
To get the MAC address or Physical address of the computer do this
Click start>run>type in "cmd" and press okay (without the " ").
On the Command prompt type in ipconfig/all and then press enter, look for physical address.
Then input that on the MAC clone feature of the computer to your router and then power cycle everything (turn everything off and then turn on modem first-then router-then computer).
Sep 12, 2008 | Trendware TEW-630APB (TEW630APB)
TL-WR340G Wireless Router
You all can try contacting your you ISP while they will provide you with some configuration and than it would work smooth as on direct conneted to modem .... its mainly the problem from Static ip , dynamic ip and pppoe mainly the connection we get is of PPPOE... and you can try puting PPPOE up to then Dynamic Ip
Sep 12, 2008 | Computers & Internet
TP-LINK 54M Wireless Router
pls ckeck your connectivity status
use this command to test for connectivity from your isp 'ping <ip address>
Apr 23, 2008 | Computers & Internet
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
333 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
