Question about ASUS P4P800-E Deluxe Motherboard
I get a message over the speakers System failure from CPU overclo
I turned on my Asus P4P 800-E deluxe 3.20 Gb Compt with 1 GB ram 200 GB SATA HD this morning and got an audio message (System Failure due to CPU overclocking),I turned it off and on again and got another audio message that said (System failure due to CPU system input or PPU system input, (It will not boot up at all ) couldn't quite understand the second message. I have NOT made any changes to the computer. Does this sound like a major problem that I need to bring in for repairs or can I do it myself. I have the machine about 3 yrs and have not made any changes to it. I would appreciate any help I can get.
  • ddsent Jan 06, 2009
    Tried what you said, left the battery out for 1 hr, didn't work, but thanks for the try! Any other ideas? Could it be the memory? or do you think the CPU is dead!
    Tried cleaning the memory, didn't work, The audio message that I'm getting sounds like it says System Fail PP Impass. Does that make any sense?
  • ASUS Master
  • 4,806 Answers
Hi there
Try resetting the CMOS either by removing the battery from the motherboard for 20 mins and make sure the power cord is removed from the back of the machine. When you put the battery back you will have to set the time and date again
Good luck and kind regards
Posted on Jan 05, 2009
  • Lee Hodgson
    Lee Hodgson Jan 06, 2009
    Hi again
    Yes it could be the memory, its not the CPU as the machine starts up, take the memory out, clean the contacts and reseat the memory again see if that sorts the problem
System won't turn on
try to troubleshooting your power supply and ram first.
if problems still same. make troubleshooting on your processor or motherboard.
tq
Dec 30, 2011 | ASUS P4P800-E DELUXE ULTRA ATA133...
What arethe compatible components of this kind motherboard
CPU P5KPL-AM empty.jpg Valuable Intel G31 uATX solution with FSB overclocking 1600MHz!
- Intel® Core™2 Quad Ready
- Intel® 45nm CPU Ready
- FSB 1600(O.C.)/1333/1066/800 MHz
- Intel® G31/ICH7
- Dual channel DDR2 1066(O.C.)/800/667
- EZ Flash2 & CrashFree BIOS3
- 8 Channel High Definition Audio
Intel® Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® D/Pentium® 4/Celeron® E1000 Series and Celeron 400 Series Intel® Hyper-Threading Technology ready
*Refer to www.asus.com for Intel CPU support list
Chipset Intel® G31 Intel ICH7
Front Side Bus 1600*/1333/1066/800 MHz (*1600 is overclock speed) Memory 2 x DIMM, Max. 4 GB, DDR2 1066(O.C.)/800/667 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*Overclock speed
**Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
***When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended. Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
VGA Integrated Intel Graphics Media Accelerator (Intel® GMA 3100)
Max. resolution:2048x1536X32bpp, Horizontal:127.5KHz Vertical:85Hz Storage Southbridge
1 xUltraDMA 100/66/33
4 xSATA 3 Gb/s ports
LAN Realtek RTL8102EL 100/10 LAN
Audio VIA VT1708B 8 -Channel High-Definition Audio CODEC
Anti-Pop Function
Jack-detect & Multi-Streaming
Support S/PDIF Out connector USB 8 USB 2.0 ports (4 ports at mid-board, 4 ports at back panel) Overclocking Features SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz up to 600MHz at 1MHz increment
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS MyLogo 2
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Fan
Back Panel I/O Ports 1 x Parallel
1 x VGA
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x LAN(RJ45) port
4 x USB 2.0/1.1
1 x COM port
8 -Channel Audio I/O
Internal I/O Connectors 2 x USB connectors support additional 4 USB ports
1 x Floppy disk drive connector
1 x IDE connector
4 x SATA connectors
1 x internal speaker connector
1 x S/PDIF Out connector
1 x CPU/ Chassis/ Power Fan connector
1 x Front panel High Definition audio connector
1 x Chassis Intrusion connector
1 x CD audio in connector
24-pin EPS 12V Power connector
4-pin ATX 12V Power connector
1 x System Panel connector
BIOS 8 Mb Flash ROM
DMI 2.0
AMI BIOS
PnP
WfM 2.0
SM BIOS 2.5
ACPI 2.0
Manageability WOL,PXE,RPL,WOR ,PME Wake Up Accessories User's manual
1 x UltraDMA 133/100/66 cable
1 x Floppy disk drive cable
1 x SATA cable
1 x SATA power cable
I/O Shield
Support Disc Drivers
ASUS PC Probe II
Anti-virus software (OEM version)
ASUS Update
Form Factor uATX Form Factor
9.6 inch x8 inch ( 24.4 cm x 20.3 cm )
hope this helps
Jul 18, 2011 | ASUS P5KPL-AM - Motherboard - micro ATX -...
Asus A8V-E not start
Looking at this post, I think your Motherboard is bad.
Have you tried a different Video Card?
My other thought is the CPU is overheating due to incorrect seating of the FAN and heat sink.
Try cleaning the CPU off, and put new paste on the CPU, then re-seat the heat sink.
Be careful to make sure the anchors are pushed all the way down by slightly twisting or wiggling the heat sink.
Check for looseness.
Push down on all memory sticks to ensure they are seated all the way in.
They should click on both sides.
If it still gives you a red light, then contact the website of the manufacturer, and get an RMA number for a replacement.
Jul 24, 2009 | ASUS A8V-E Deluxe Motherboard
2nd sata connected and xp won't boot
It seems you have not made the second SATA the slave of first SATA. You'll have to fix the jumper pin in the designated slot to make the second SATA the slave. a1d66e3.jpg
Jul 07, 2009 | ASUS A8N32-SLI Deluxe Motherboard
Upgrading my computer
Dear Fried its possible.. Go the Boot Menu at your BIOS ( For go the BIOS Press DEL at startup your system) there you may se Hard Disk Priority Option. There you can change Hard disk Priority... you may need setup your sata as first one..
Thanks...
Mar 26, 2009 | ASUS K8V SE DELUXE,...
I get a Post audio message on boot up/but no bootup
i have just thrown out 3 ASUS boards for various problems. they seem to last approx 18months before they die.
video output goes wrong, cpu socket errors, all sorts of problems and a rubbish tech support at ASUS does not help.
Feb 23, 2009 | ASUS P4P800-E Deluxe Motherboard
Same problem, but not solved
Matias,
Please remove the jumper on the SATA drive. Boot to the bios & see if the SATA drive is listed. If it is you're good. If this is the first SATA you have tried in the Asus board & my suggestion also failed to show the SATA drive you are left with two options.
One the SATA drive is defective or the SATA motherboard controller is bad. You can call Asus tech M-F 8:00AM to 5:00PM EDT. At 1-812-282-2787, there is little wait time when calling Asus tech. Asus does not charge you for calling them.
Mike
Jul 13, 2008 | ASUS P4V8X-X Motherboard
Ram capacity
This motherboard supports RAM upto 8 GB but 32 bit Operatin system give support 4 GB. To know more about the mobo follow the link below
http://www.asus.com/products.aspx?l1=3&l2=12&l3=30&model=175&modelmenu=1
Jul 04, 2008 | Intel ASUS P4C800-E Deluxe 875P Socket 478...
AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
May 10, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Which GB ram seaport
\ x 184-Pin DIMM Sockets ddrsdram x 184-Pin DIMM Memory Type
DDR Maximum Memory 3 GB
Your board support maximum 3 gb ram with above mentioned details
Regards
Balisonu79
Feb 14, 2008 | ASUS A7N8X-E Deluxe : ATX Socket A FSB400...
ASUS P4P800-E Deluxe Motherboard Logo
156 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
